查看: 2839|回复: 0
矩阵键盘识别:实现按键出现数字和字母
ID:262427 发表于 2017-12-16 17:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
int i,a,b,c;
void KEY_16();
char code tab1[16]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E};
void delay(int z)
int x,y;
for(x=0;x<z;x++)
  for(y=0;y<120;y++);
  KEY_16();
  P0=tab1[i];
void KEY_16()
int a;
P1=0x0f;
if(P1!=0x0f)
delay(1);
  if(P1!=0x0f)
   P1=0x0f;
   switch(P1)
           case(0x0e):i=0;break;
        case(0x0d):i=4;break;
        case(0x0b):i=8;break;
        case(0x07):i=12;break;
   P1=0xf0;
   switch(P1)
           case(0x70):i=i+3;break;
        case(0xb0):i=i+2;break;
        case(0xd0):i=i+1;break;
        case(0xe0):i=i;break;
   while(P1!=0xf0)
                                delay(1);
                                a++;
                        a=0;
