查看: 7590|回复: 1
ST三轴gsensor传感器LIS2DS12引脚图与功能介绍及datasheet下载
供大家参考
LIS2DS12引脚图:
LIS2DS12管脚功能介绍
Description
The LIS2DS12 is an ultra-low-power high-performance three-axis linear accelerometer belonging to the “pico” family which leverages on the robust and mature manufacturing processes already used for the production of micromachined accelerometers.
The LIS2DS12 has user-selectable full scales of 2g/4g/8g/16g and is capable of measuring accelerations with output data rates from 1 Hz to 6400 Hz.
The LIS2DS12 has an integrated 256-level first-in, first-out (FIFO) buffer allowing the user to store data in order to limit intervention by the host processor.
The embedded self-test capability allows the user to check the functioning of the sensor in the final application.
The LIS2DS12 has a dedicated internal engine architecture in order to process internally motion and acceleration detection including free-fall, wakeup, single and double-tap detection, activity-inactivity, portrait and landscape detection, step counter and step detection along with significant motion detection.
The LIS2DS12 is available in a small thin plastic land grid array package (LGA) and it is
guaranteed to operate over an extended temperature range from -40 °C to +85 °C.
完整的pdf格式datasheet文档51黑下载地址:
LIS2DS12.pdf (1.3 MB, 下载次数: 27)
收藏收藏2 分享淘帖 顶顶 踩踩
ID:385811 发表于 2021-5-20 09:37 | 只看该作者
资料是英文原版
