查看: 5570|回复: 0
基于51的红外寻迹小车源代码
ID:265195 发表于 2017-12-22 10:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
unsigned char zkb1=0;             //**左前边电机的占空比**//
unsigned char zkb2=0;                //**右前边电机的占空比**//
unsigned char zkb3=0;              //**左后边电机的占空比**//
unsigned char zkb4=0;                //**右后边电机的占空比**//
unsigned char t=0;                 //**定时器中断计数器**//
//***传感器***//
sbit LSEN1=P2^0;
sbit LSEN2=P2^1;
sbit LSEN3=P2^2;
sbit RSEN1=P2^3;
sbit RSEN2=P2^4;
sbit RSEN3=P2^5;
//***电机***//IN1,2,3,4前轮,IN5,6,7,8后轮//
sbit IN1=P1^0;//左前//
sbit IN2=P1^1;
sbit IN3=P1^2;//右前//
sbit IN4=P1^3;
sbit IN5=P1^4;//左后//
sbit IN6=P1^5;
sbit IN7=P1^6;//右后//
sbit IN8=P1^7;
sbit QENA=P0^0;//QENA,B前驱动使能,HENA,B后驱动使能//
sbit QENB=P0^1;
sbit HENA=P0^2;
sbit HENB=P0^3;
int a;
a=1;
int i,j;//延时函数//
void delay(int z)
for(i=0;i<z;i++)
   for(j=0;j<110;j++);
void Timer0() interrupt 1
        TH0=(65536-100)/256; // 装入定时器的初值 10ms定时 //
        TL0=(65536-100)%256;
        if(t<zkb1)            QENA=1;
        else                  QENA=0;
        if(t<zkb2)      QENB=1;
        else                   QENB=0;
        if(t<zkb3)                HENA=1;
        else                        HENA=0;
        if(t<zkb4)                HENB=1;
        else                        HENB=0;
        t++;
        if(t>=100)
        t=0;
main ()
                //******初始化定时器******//
                TMOD=0x01; // 设定T0的工作模式为1 //
                EA=1; // 开中断 //
                ET0=1; //定时器0允许中断 //
                TR0=1; // 启动定时器0 //
                delay(100);//直行//
                zkb1=60;
                zkb2=60;
                zkb3=60;
                zkb4=60;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=1;
                delay(1000);
while (1)
        if ((LSEN1==1)&&(LSEN2==1)&&(LSEN3==1)&&(RSEN1==1)&&(RSEN2==1)&&(RSEN3==1))//直行//
                zkb1=60;
                zkb2=60;
                zkb3=60;
                zkb4=60;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=1;
        else if ((LSEN1==1)&&(LSEN2==1)&&(LSEN3==1)&&(RSEN1==1)&&(RSEN2==1)&&(RSEN3==0))//左转1//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=0;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=0;
                //delay(30);
        else if ((LSEN1==1)&&(LSEN2==1)&&(LSEN3==1)&&(RSEN1==1)&&(RSEN2==0)&&(RSEN3==0))//左转2//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=0;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=0;
                //delay(10);
        else if ((LSEN1==1)&&(LSEN2==1)&&(LSEN3==1)&&(RSEN1==1)&&(RSEN2==0)&&(RSEN3==1))//左转3//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=0;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=0;
                //delay(10);
        else if ((LSEN1==1)&&(LSEN2==1)&&(LSEN3==1)&&(RSEN1==0)&&(RSEN2==0)&&(RSEN3==1))//左转4//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=0;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=0;
                delay(50);
        else if ((LSEN1==1)&&(LSEN2==1)&&(LSEN3==1)&&(RSEN1==0)&&(RSEN2==1)&&(RSEN3==1))//左转5//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=0;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=0;
                delay(80);
                //delay(30);
        else if ((LSEN1==1)&&(LSEN2==1)&&(LSEN3==1)&&(RSEN1==0)&&(RSEN2==0)&&(RSEN3==0))//左转6//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=0;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=0;
                delay(120);
                //delay(30);
        else if ((LSEN1==0)&&(LSEN2==1)&&(LSEN3==1)&&(RSEN1==1)&&(RSEN2==1)&&(RSEN3==1))//右转1//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=0;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=0;
                IN7=0;
                IN8=1;
                //delay(30);
        else if ((LSEN1==0)&&(LSEN2==0)&&(LSEN3==1)&&(RSEN1==1)&&(RSEN2==1)&&(RSEN3==1))//右转2//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=0;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=0;
                IN7=0;
                IN8=1;
                //delay(10);
        else if ((LSEN1==1)&&(LSEN2==0)&&(LSEN3==1)&&(RSEN1==1)&&(RSEN2==1)&&(RSEN3==1))//右转3//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=0;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=0;
                IN7=0;
                IN8=1;
                //delay(10);
        else if ((LSEN1==1)&&(LSEN2==0)&&(LSEN3==0)&&(RSEN1==1)&&(RSEN2==1)&&(RSEN3==1))//右转4//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=0;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=0;
                IN7=0;
                IN8=1;
                delay(50);
        else if ((LSEN1==1)&&(LSEN2==1)&&(LSEN3==0)&&(RSEN1==1)&&(RSEN2==1)&&(RSEN3==1))//右转5//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=0;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=0;
                IN7=0;
                IN8=1;
                delay(80);
                //delay(30);
        else if ((LSEN1==0)&&(LSEN2==0)&&(LSEN3==0)&&(RSEN1==1)&&(RSEN2==1)&&(RSEN3==1))//右转6//
                zkb1=30;
                zkb2=30;
                zkb3=30;
                zkb4=30;
                IN1=0;
                IN2=0;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=0;
                IN7=0;
                IN8=1;
                delay(120);
                //delay(30);
        else if ((LSEN1==0)&&(RSEN1==0)||(LSEN1==0)&&(RSEN2==0)||(LSEN1==0)&&(RSEN3==0))//停止1//
                zkb1=50;
                zkb2=50;
                zkb3=50;
                zkb4=50;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=1;
                delay(500);
                zkb1=0;
                zkb2=0;
                zkb3=0;
                zkb4=0;
                delay(3000);
        else if ((LSEN2==0)&&(RSEN1==0)||(LSEN2==0)&&(RSEN2==0)||(LSEN2==0)&&(RSEN3==0))//停止2//
                zkb1=50;
                zkb2=50;
                zkb3=50;
                zkb4=50;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=1;
                delay(500);
                zkb1=0;
                zkb2=0;
                zkb3=0;
                zkb4=0;
                delay(3000);
        else if ((LSEN3==0)&&(RSEN1==0)||(LSEN3==0)&&(RSEN2==0)||(LSEN3==0)&&(RSEN3==0))//停止3//
                zkb1=50;
                zkb2=50;
                zkb3=50;
                zkb4=50;
                IN1=0;
                IN2=1;
                IN3=0;
                IN4=1;
                IN5=0;
                IN6=1;
                IN7=0;
                IN8=1;
                delay(500);
                zkb1=0;
                zkb2=0;
                zkb3=0;
                zkb4=0;
                delay(3000);
