查看: 5461|回复: 1
单片机万年历部分程序
ID:267055 发表于 2017-12-26 13:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
alarmflag=1;
//led=0;
lcdinit();//初始化液晶函数
ds1302_init();//DS1302时钟芯片初始化函数
init();//定时器初始化函数
beep=0;
delay(200);
beep=1;
//led=0;
  year1=(nian)/10*16+(nian)%10;//转换为bcd码
  month1=(yue)/10*16+(yue)%10;
  day1=(ri)/10*16+(ri)%10;
  chushihua();//初始化时间函数
     Conversion(0,year1,month1,day1);//
  timealarm();//报时程序
  keyscan();//不断扫面按键函数
  /*if(key2==1)//加键不按下时才有用
        ledcontrol();//背光控制
void timer0() interrupt 1//中断任务:取数据并显示
TH0=(65536-60000)/256;//重新赋初值
TL0=(65536-60000)%256;
//读取数据
flag=ReadTemperature();//读取温度(考虑是否放在此处)
miao=turnBCD(read_1302(0x81));//读出秒
fen=turnBCD(read_1302(0x83));//读出分
shi=turnBCD(read_1302(0x85));//读出时
ri=turnBCD(read_1302(0x87));//读出日
yue=turnBCD(read_1302(0x89));//读出月
nian=turnBCD(read_1302(0x8d));//读出年
week=turnBCD(read_1302(0x8b));//读出周
//显示数据
if(((0<=miao)&&(miao<15))||(((miao/10==2)||(miao/10==4))&&(miao%10<=5))||((54<=miao)&&(miao<60))) /*显示所有信息的时间段*/
  print(0x80,"20  /  /   W < >");
  writecom(h1+0x0c);
  writedata(0x7e);//→右箭头
  writeday(8,ri);//显示日
  writeday(5,yue);//显示月
  writeday(2,nian);//显示年
  writeweek(week);//显示星期
  print(0x40,"  :  :          ");
  writetemp(9,flag);//显示温度,第二行显示
  writetime(6,miao);//显示出秒
  writetime(3,fen);//显示出分
  writetime(0,shi);//显示出时,第二行第一个开始
//if(15<=miao)/*当秒大于15时才显示*/
  if(((miao/10==1)||(miao/10==3))&&(miao%10>=5))
  switch(flag/100)//取出温度的十位数
   case 0:print(0x80,"Pretty cold now!");
       break;
   case 1:print(0x80,"little cold now!");
       break;
   case 2:print(0x80,"It is warm now. ");
       break;
   case 3:print(0x80,"It's hot !!!    ");
       break;
   case 4:print(0x80,"Very very hot!!!");
       break;
   case 5:print(0x80,"Very very hot!!!");
       break;
   case 6:print(0x80,"Very very hot!!!");
       break;
  //print(0x80,"It is warm now. ");
  if(((miao/10==2)||(miao/10==4))&&(miao%10>=5))/*25-30 45-50*/
   if((5<=shi)&&(shi<=11)) flagT=1;//5-11时为早上
   if((11<shi)&&(shi<=14)) flagT=2;//11-14为中午
   if((14<shi)&&(shi<=18)) flagT=3;//14-18为下午
   if((18<shi)||(shi<5))   flagT=4;//18-24或者0-5为晚上
   switch(flagT)//分段时间
    case 1:print(0x80," Good Morning!  ");
        break;
    case 2:print(0x80,"   Good Noon!   ");
        break;
    case 3:print(0x80,"Good afternoon! ");
        break;
    case 4:print(0x80,"  Good night!   ");
        break;
  if(((30<=miao)&&(miao<35))||((50<=miao)&&(miao<54)))//30-35 50-54
  {//else改为范围
  festival();//选择显示节日
void timer1() interrupt 3//任务:计时用作报时
TH1=(65536-50000)/256;//中断后重新赋初值
TL1=(65536-50000)%256;
//count++;//计算时间
if(alarmflag==1)//设置键按下才有效
  if(fen==0 && miao<4)
  count++;
  ledcount=count/10;//分开时间段
   switch(ledcount)
    case 0:Gled=0;Yled=1;break;//从零开始
    case 1:Gled=1;Yled=0;break;
    case 2:Gled=0;Yled=1;break;
    case 3:Gled=1;Yled=0;break;
    case 4:Gled=0;Yled=0;break;
    case 5:Gled=1;Yled=1;break;
    case 6:Gled=0;Yled=0;break;
    case 7:Gled=0;Yled=0;count=0;break;//在这里面清零
  else if(fen==30 && miao<2)
   Gled=0;
   Yled=0;
  else {
  Gled=1;
  Yled=1;
ID:347352 发表于 2018-10-24 08:30 | 只看该作者
感谢大神
