查看: 1965|回复: 0
状态机按键
ID:86145 发表于 2017-12-29 10:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit key_1 = P1^0;
sbit key_2 = P1^1;
bit key_evein ;
void key_scan()
        unsigned int mode, count;
//        mode =0;
//        count =0;
        switch(mode)
                case 0:
                        if(!key_1)
                                mode = 1;
                                P0=0x55;
                        break;
                case 1:
                        if(key_1==0)
                                count++;
                                if(count>50)
                                        count = 0;
                                        mode=2;
                        else if (key_1)
                                        mode=0;
                        break;
                case 2:
                        if(key_1)
                                P3=0xf0;
                                mode=0;
                        else if(key_1)
                                mode = 4;
                        break;
                case 4:
                        if(key_1==0)
                                count++;
                                if(count==5000)
                                        count = 0;
                                        mode = 5;
                        break;
                case 5:
                 if(key_1)
                                P3=0x0f;
                          mode=0;
void main ()
                TMOD = 0x01;
                TH0  = (65536-1000)/256;
          TL0  = (65536-1000)%256;
                TR0  = 1;
          EA = 1;
          ET0= 1;
        while (1)
                if(key_evein) key_scan();
void timer (void ) interrupt 1
          TR0 = 0;
          TR0 =1;
          key_evein=1;
