查看: 6697|回复: 7
DS18B20+DS1302+LCD12864单片机课设
做的单片机课设
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. sbit RES1=P2^0;
  4. sbit A0=P2^1;
  5. sbit RW=P2^2;
  6. sbit E=P2^3;
  7. sbit B0=P0^0;
  8. sbit B1=P0^1;
  9. sbit B2=P0^2;
  10. sbit DQ=P3^0;
  11. sbit IO=P3^3;
  12. sbit SCLK=P3^2;
  13. sbit CE=P3^1;
  14. unsigned char state_button,time_jian;
  15. void delay(unsigned int i)
  16. {
  17.    while(i--);
  18. }
  19. void wendu_reset(void)
  20. {
  21.    unsigned char r=0;
  22.    DQ=1;
  23.    delay(8);
  24.    DQ=0;
  25.    delay(90);
  26.    DQ=1;
  27.    delay(14);
  28.    r=DQ;
  29.    delay(20);
  30.    }
  31.    void wendu_write(unsigned char date)
  32.    {
  33.       unsigned char i=0;
  34.          for(i=8;i>0;i--)
  35.    {
  36.       DQ=0;
  37.           DQ=date&0x01;
  38.           delay(7);
  39.           DQ=1;
  40.           date>>=1;
  41.           }
  42.                     }
  43. signed int wendu_read(void)
  44. {
  45.    unsigned char i=0,t=0,pn=0;
  46.    for(i=8;i>0;i--)
  47.    {
  48.      DQ=0;
  49.          t>>=1;
  50.          DQ=1;
  51.          if(DQ==1)
  52.          {
  53.            t=0x08;
  54.            }
  55.            delay(4);
  56.          }
  57.          return(t);
  58.          }
  59.          void time_write(unsigned char time_wd)
  60.          {
  61.            unsigned char i,j;
  62.            for(i=0;i<8;i++)
  63.            {
  64.               j=time_wd&0x01;
  65.                   IO=0;
  66.                   SCLK=0;
  67.                   if(j==1)
  68.                   {
  69.                     IO=1;
  70.                         }
  71.                         time_wd=time_wd>>1;
  72.                         SCLK=1;
  73.                         }
  74.                         SCLK=0;
  75.                         }
  76.                         unsigned char time_read()
  77.                         {
  78.                           unsigned char time_rd;
  79.                           unsigned char i;
  80.                           IO=1;
  81.                           for(i=0;i<8;i++)
  82.                           {
  83.                            SCLK=0;
  84.                            time_rd=time_rd>>1;
  85.                            if(IO==1)
  86.                            {
  87.                              time_rd=time_rd|0x80;
  88.                                  }
  89.                                  SCLK=0;
  90.                                  return(time_rd);
  91.                                  }
  92.                                  unsigned char get_time(unsigned char ord);
  93.                                  {
  94.                                    unsigned char dd=0;
  95.                                    SCLK=0;
  96.                                    CE=0;
  97.                                    CE=1;
  98.                                    time_write(ord);
  99.                                    dd=time_read();
  100.                                    CE=0;
  101.                                    return(dd);
  102.                                    }
  103.                                    void set_time(unsigned char ord,unsigned char dd)
  104.                                    {
  105.                                        SCLK=0;
  106.                                            CE=0;
  107.                                            CE=1;
  108.                                            time_write(ord);
  109.                                            time_write(dd);
  110.                                            CE=0;
  111.                                            }
  112.                                            void start(void)
  113.                                            {
  114.                                             unsigned char i;
  115.                                                 set_time(0x8e,0x00);
  116.                                                 set_time(0x80,0x00);
  117.                                                 set_time(0x84,0x00);
  118.                                                 set_time(0x90,0xa5);
  119.                                                 set_time(0x8e,0x80);
  120.                                                 RES1=0;
  121.                                                 RES1=1;
  122.                                                 dis_write_cmd(0xaf);
  123.                                                 clean();
  124.                                                 jianjie();
  125.                                                 for(i=1;i<20;i++)
  126.                                                 {
  127.                                                  delay(10000);
  128.                                                  }
  129.                                                  clean();
  130.                                                  tuxiang();
  131.                                                  }
  132.                                                  wendu_reset();
  133.                                                  wendu_write(0xcc);
  134.                                                  wendu_write(0x44);
  135.                                                  wendu_reset();
  136.                                                  wendu_write(0xcc);
  137.                                                  wendu_write(0xbe);
  138.                                                  a=wendu_read();
  139.                                                  b=wendu_read();
  140.                                                  pn=b&0x80;
  141. ……………………
  142. …………限于本文篇幅 余下代码请从51黑下载附件…………
单片机课程设计作业.zip (123.35 KB, 下载次数: 118)
收藏收藏1 分享淘帖 顶 踩
ID:267330 发表于 2018-1-2 11:00 | 只看该作者
能用不,我正在找啊
ID:269881 发表于 2018-1-2 17:13 | 只看该作者
想问一下你这个实现的功能是什么?
ID:269881 发表于 2018-1-2 18:34 | 只看该作者
您好,请问你这个的主要功能是什么。
ID:426284 发表于 2018-12-30 16:31 | 只看该作者
仿真不行
ID:100312 发表于 2019-1-6 19:29 | 只看该作者
hex没有,源码不全,啥都没有
ID:842752 发表于 2020-11-30 10:22 | 只看该作者
代码不全
ID:642727 发表于 2020-12-3 21:20 | 只看该作者
代码不全啊
