查看: 2080|回复: 0
99倒计时程序
ID:263377 发表于 2017-12-30 19:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
仿真电路图:http://www.51hei.com/bbs/dpj-103626-1.html
#include<reg51.h>
#include<intrins.h>
#define dat P0
code uchar d[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uint second=99;
uint sshi,sge;
static char court=0;
void delay(uint number)              /*单个LED延时函数*/
{uchar i,j;
     for(i=0;i<number;i++)
       for(j=0;j<200;j++);
void int0() interrupt 1 using 2            /*中断1为内部中断,0为外部中断*/           /*中断服务程序*/
  TH0=0x5c;
  TL0=0xb0;
  court++;
            TMOD=0X01;
            TH0=0x5c;
            TL0=0xb0;
            ET0=1;
//            EX0=1;
//            EX1=1;
//            IT0=1;
//            IT1=1;              /*开计数器中断*/
            EA=1;
            TR0=1;          /*开定时器*/
      while(1)                  /*中断不能放循环中*/
             sshi=second/10;
              sge=second%10;
             dat=d[sge];         /*第一个数码管*/
             P2=0x80;
             delay(2);
             P2=0x00;
             dat=d[sshi];
             P2=0x40;
             delay(2);
             P2=0x00;
if(court==20)
       {court=0;
           second--;
             if(second==0)
                {second=100;second--;
