查看: 6140|回复: 4
基于proteus的电子负载仿真与Arduino源程序
ID:141133 发表于 2018-1-1 08:23 | 显示全部楼层 |阅读模式
附件是基于proteus的电子负载仿真,主控芯片是AVR。
ElectronicLoad-master
Arduino单片机源程序如下:
  1. #define DEBUG
  2. #include <LiquidCrystal.h>
  3. #include <Encoder.h>
  4. #include "variables.h"
  5. #include "lcd.h"
  6. #include "pwm16Bit.h"
  7. #include "iSet.h"
  8. #include "timer2.h"
  9. #include "misc.h"
  10. #include "voltageAndCurrentSensors.h"
  11. void setup() {
  12.   #ifdef DEBUG
  13.     Serial.begin(115200);
  14.   #endif
  15.   //ILOAD_PIN as PWM output
  16.   setupPWM16();
  17.   //Configure TIMER2 so that it calls ISR(TIMER2_COMPA_vect) @ 500Hz (every 2mS)
  18.   //ISR(TIMER2_COMPA_vect) is used to update CC waveforms
  19.   setupTimer2();
  20.   //LCD Setup
  21.   lcd.begin(16, 2);
  22.   lcd.print("ElectronicLoad");
  23.   lcd.setCursor(0,1);
  24.   lcd.print("  [Version 1.07]");
  25.   lcd.createChar(0, ohm);
  26.   lcd.createChar(1, vLoad);
  27.   lcd.createChar(2, iLoad);
  28.   lcd.createChar(3, hi);
  29.   lcd.createChar(4, lo);
  30.   delay(1500);
  31.   //Button and Led pinmode setup
  32.   pinMode(OUTPUT, outputEnabledLed);
  33.   pinMode(INPUT, encBtn);
  34.   digitalWrite(encBtn, HIGH);                   //Enable internal pullup
  35.   pinMode(INPUT, modeSelectorBtn);
  36.   digitalWrite(modeSelectorBtn, HIGH);          //Enable internal pullup
  37.   pinMode(INPUT, outputEnableBtn);
  38.   digitalWrite(outputEnableBtn, HIGH);          //Enable internal pullup
  39.   //ISet calibration (Finds a proper ISetOneAmp value where IL=1A)
  40.   //calibrateISet();
  41.   ISetOneAmp=14280;
  42.   resetLcdToDefault();
  43.   lcd.setCursor(0, 0);
  44.   lcd.write("C.Cur:");
  45. }
  46. void loop() {
  47. if(mode == CONSTANT_CURRENT) {
  48.     int encoderPos = getEncoderMovement();       //getEncoderMovement() returns either -1, 0 or 1
  49.     if(encoderPos > 0 && ISetVal < ISET_CC_MAX)   //Encoder incremented
  50.       ISetVal+=ISET_CC_STEP;
  51.     else if (encoderPos < 0 && ISetVal >= ISET_CC_STEP)   //Encoder decremented
  52.       ISetVal-=ISET_CC_STEP;
  53.     lcd.setCursor(0, 1);
  54.     lcdPrintIntWhitespace(ISetVal, 4);
  55.     lcd.print(ISetVal);
  56.     lcd.write("mA");
  57.   }
  58.
  59. if(mode == CONSTANT_RESISTANCE) {
  60.     byte encoderPos = getEncoderMovement();       //getEncoderMovement() returns either -1, 0 or 1
  61.     if(encoderPos > 0 && ISetVal < ISET_CR_MAX)   //Encoder incremented
  62.       ISetVal+=ISET_CR_STEP;
  63.     else if (encoderPos < 0 && ISetVal >= ISET_CR_MIN)   //Encoder decremented
  64.       ISetVal-=ISET_CR_STEP;
  65.
  66.     lcd.setCursor(0, 1);
  67.     lcdPrintIntWhitespace(ISetVal, 4);
  68.     lcd.print(ISetVal);
  69.     lcd.write(byte(0)); //ohm char
  70.   }
  71.
  72. if(mode == CONSTANT_POWER) {
  73.     byte encoderPos = getEncoderMovement();       //getEncoderMovement() returns either -1, 0 or 1
  74.     if(encoderPos > 0 && ISetVal < ISET_CP_MAX)   //Encoder incremented
  75.       ISetVal+=ISET_CP_STEP;
  76.     else if (encoderPos < 0 && ISetVal >= ISET_CP_STEP)   //Encoder decremented
  77.       ISetVal-=ISET_CP_STEP;
  78.
  79.     lcd.setCursor(0, 1);
  80.     lcdPrintIntWhitespace(ISetVal, 4);
  81.     lcd.print(ISetVal);
  82.     lcd.write("mW");
  83.   }
  84.    if(mode == SQUARE_CURRENT) {
  85.     int encoderPos = getEncoderMovement();       //encoderPos is either -1, 0 or 1
  86.     if(encoderPos != 0) {                        //Encoder changed
  87.       switch(SCCurrentParam) {
  88.       case SC_PARAM_IHI:
  89.         if(encoderPos > 0 && ISetSCIHi < ISET_SC_IMAX)
  90.           ISetSCIHi += ISET_SC_I_STEP;
  91.         else if(encoderPos < 0 && ISetSCIHi >= ISET_SC_I_STEP && ISetSCIHi > ISetSCILo)
  92.           ISetSCIHi -= ISET_SC_I_STEP;
  93.         break;
  94.       case SC_PARAM_ILO:
  95.         if(encoderPos > 0 && ISetSCILo < ISET_SC_IMAX && ISetSCILo < ISetSCIHi)
  96.           ISetSCILo += ISET_SC_I_STEP;
  97.         else if(encoderPos < 0 && ISetSCILo >= ISET_SC_I_STEP)
  98.           ISetSCILo -= ISET_SC_I_STEP;
  99.         break;
  100.       case SC_PARAM_THI:
  101.         if(encoderPos > 0 && ISetSCTHi < ISET_SC_TMAX)
  102.           ISetSCTHi += ISET_SC_T_STEP;
  103.         else if(encoderPos < 0 && ISetSCTHi >= ISET_SC_T_STEP)
  104.           ISetSCTHi -= ISET_SC_T_STEP;
  105.         break;
  106.       case SC_PARAM_TLO:
  107.       if(encoderPos > 0 && ISetSCTLo < ISET_SC_TMAX)
  108.           ISetSCTLo += ISET_SC_T_STEP;
  109.         else if(encoderPos < 0 && ISetSCTLo >= ISET_SC_T_STEP)
  110.           ISetSCTLo -= ISET_SC_T_STEP;
  111.         break;
  112.       }
  113.     }
  114.     lcd.setCursor(0, 1);
  115.     switch(SCCurrentParam) {
  116.       case SC_PARAM_IHI:
  117.         lcd.write("I");
  118.         lcd.write(byte(3));
  119.         lcdPrintIntWhitespace(ISetSCIHi, 4);
  120.         lcd.print(ISetSCIHi);
  121.         lcd.write("mA");
  122.         break;
  123.
  124.       case SC_PARAM_ILO:
  125.         lcd.write("I");
  126.         lcd.write(byte(4));
  127.         lcdPrintIntWhitespace(ISetSCILo, 4);
  128.         lcd.print(ISetSCILo);
  129.         lcd.write("mA");
  130.         break;
  131.
  132.       case SC_PARAM_THI:
  133.         lcd.write("T");
  134.         lcd.write(byte(3));
  135.         lcdPrintIntWhitespace(ISetSCTHi, 4);
  136.         lcd.print(ISetSCTHi);
  137.         lcd.write("mS");
  138.         break;
  139.
  140.        case SC_PARAM_TLO:
  141.         lcd.write("T");
  142.         lcd.write(byte(4));
  143.         lcdPrintIntWhitespace(ISetSCTLo, 4);
  144.         lcd.print(ISetSCTLo);
  145.         lcd.write("mS");
  146.         break;
  147.     }
  148.   }
  149.    if(mode == TRIANGLE_CURRENT) {
  150.     int encoderPos = getEncoderMovement();       //encoderPos is either -1, 0 or 1
  151.     if(encoderPos != 0) {                        //Encoder changed
  152.       switch(TCCurrentParam) {
  153.       case TC_PARAM_IHI:
  154.         if(encoderPos > 0 && ISetTCIHi < ISET_TC_IMAX)
  155.           ISetTCIHi += ISET_TC_I_STEP;
  156.         else if(encoderPos < 0 && ISetTCIHi >= ISET_SC_I_STEP && ISetTCIHi > ISetTCILo)
  157.           ISetTCIHi -= ISET_TC_I_STEP;
  158.         break;
  159.       case TC_PARAM_ILO:
  160.         if(encoderPos > 0 && ISetTCILo < ISET_TC_IMAX && ISetTCILo < ISetTCIHi)
  161.           ISetTCILo += ISET_TC_I_STEP;
  162.         else if(encoderPos < 0 && ISetTCILo >= ISET_TC_I_STEP)
  163.           ISetTCILo -= ISET_TC_I_STEP;
  164.         break;
  165.       case TC_PARAM_THI:
  166.         if(encoderPos > 0 && ISetTCTHi < ISET_TC_TMAX)
  167.           ISetTCTHi += ISET_TC_T_STEP;
  168.         else if(encoderPos < 0 && ISetTCTHi >= ISET_TC_T_STEP)
  169.           ISetTCTHi -= ISET_TC_T_STEP;
  170.         break;
  171.       case TC_PARAM_TLO:
  172.       if(encoderPos > 0 && ISetTCTLo < ISET_TC_TMAX)
  173.           ISetTCTLo += ISET_TC_T_STEP;
  174.         else if(encoderPos < 0 && ISetTCTLo >= ISET_TC_T_STEP)
  175.           ISetTCTLo -= ISET_TC_T_STEP;
  176.         break;
  177.       }
  178.     }
  179.     lcd.setCursor(0, 1);
  180.     switch(TCCurrentParam) {
  181.       case TC_PARAM_IHI:
  182.         lcd.write("I");
  183.         lcd.write(byte(3));
  184.         lcdPrintIntWhitespace(ISetTCIHi, 4);
  185.         lcd.print(ISetTCIHi);
  186.         lcd.write("mA");
  187.         break;
  188.
  189.       case TC_PARAM_ILO:
  190.         lcd.write("I");
  191.         lcd.write(byte(4));
  192.         lcdPrintIntWhitespace(ISetTCILo, 4);
  193.         lcd.print(ISetTCILo);
  194.         lcd.write("mA");
  195.         break;
  196.
  197.       case TC_PARAM_THI:
  198.         lcd.write("T");
  199.         lcd.write(byte(3));
  200.         lcdPrintIntWhitespace(ISetTCTHi, 4);
  201.         lcd.print(ISetTCTHi);
  202.         lcd.write("mS");
  203.         break;
  204.
  205.        case TC_PARAM_TLO:
  206.         lcd.write("T");
  207.         lcd.write(byte(4));
  208.         lcdPrintIntWhitespace(ISetTCTLo, 4);
  209.         lcd.print(ISetTCTLo);
  210.         lcd.write("mS");
  211.         break;
  212.     }
  213.
  214.   }
  215.    if(mode == SINE_CURRENT) {
  216.   int encoderPos = getEncoderMovement();         //encoderPos is either -1, 0 or 1
  217.     if(encoderPos != 0) {                        //Encoder changed
  218.       switch(SNCCurrentParam) {
  219.       case SNC_PARAM_IHI:
  220.         if(encoderPos > 0 && ISetSNCIHi < ISET_SNC_IMAX)
  221.           ISetSNCIHi += ISET_SNC_I_STEP;
  222.         else if(encoderPos < 0 && ISetSNCIHi >= ISET_SNC_I_STEP && ISetSNCIHi > ISetSNCILo)
  223.           ISetSNCIHi -= ISET_SNC_I_STEP;
  224.         break;
  225.       case SNC_PARAM_ILO:
  226.         if(encoderPos > 0 && ISetSNCILo < ISET_SNC_IMAX && ISetSNCILo < ISetSNCIHi)
  227.           ISetSNCILo += ISET_SNC_I_STEP;
  228.         else if(encoderPos < 0 && ISetSNCILo >= ISET_SNC_I_STEP)
  229.           ISetSNCILo -= ISET_SNC_I_STEP;
  230.         break;
  231.       case SNC_PARAM_T:
  232.         if(encoderPos > 0 && ISetSNCT < ISET_SNC_TMAX)
  233.           ISetSNCT += ISET_SNC_T_STEP;
  234.         else if(encoderPos < 0 && ISetSNCT >= ISET_SNC_T_STEP)
  235.           ISetSNCT -= ISET_SNC_T_STEP;
  236.         break;
  237.       }
  238.     }
  239.     lcd.setCursor(0, 1);
  240.     switch(SNCCurrentParam) {
  241.       case SNC_PARAM_IHI:
  242.         lcd.write("I");
  243.         lcd.write(byte(3));
  244.         lcdPrintIntWhitespace(ISetSNCIHi, 4);
  245.         lcd.print(ISetSNCIHi);
  246.         lcd.write("mA");
  247.         break;
  248.
  249.       case SNC_PARAM_ILO:
  250.         lcd.write("I");
  251.         lcd.write(byte(4));
  252.         lcdPrintIntWhitespace(ISetSNCILo, 4);
  253.         lcd.print(ISetSNCILo);
  254.         lcd.write("mA");
  255.         break;
  256.
  257.       case SNC_PARAM_T:
  258.         lcd.write("T:");
  259.         lcdPrintIntWhitespace(ISetSNCT, 4);
  260.         lcd.print(ISetSNCT);
  261.         lcd.write("mS");
  262.         break;
  263.     }
  264.
  265.
  266.   }
  267.   //Always update and print VLoad and ILoad
  268.   updateVLoad();
  269.   updateILoad();
  270.   printVLoadAndILoad();
  271.   //Handle Mode change button press
  272.   if(digitalRead(modeSelectorBtn) == LOW)  {
  273.     handleModeSelection();
  274.     //Prevent double triggering?
  275.     delay(400);
  276.   }
  277.   //Handle Output Enable/Disable button press
  278.   if(digitalRead(outputEnableBtn) == LOW)  {
  279.
  280.     outputEnabled = !outputEnabled;
  281.     if(outputEnabled) {
  282.       digitalWrite(outputEnabledLed, HIGH);
  283.       enableTimer2();
  284.     } else {
  285.       digitalWrite(outputEnabledLed, LOW);
  286.       disableTimer2();
  287.       writeISet(0);
  288.     }
  289.
  290.     //Prevent double triggering?
  291.     delay(400);
  292.   }
  293.   //Handle Encoder button press (toggle parameter change)
  294.   if(digitalRead(encBtn) == LOW)  {
  295.       if(mode == SQUARE_CURRENT) {
  296.           switch(SCCurrentParam) {
  297.             case SC_PARAM_IHI:
  298.               SCCurrentParam = SC_PARAM_ILO;  break;
  299.             case SC_PARAM_ILO:
  300.               SCCurrentParam = SC_PARAM_THI;  break;
  301.             case SC_PARAM_THI:
  302.               SCCurrentParam = SC_PARAM_TLO;  break;
  303.             case SC_PARAM_TLO:
  304.               SCCurrentParam = SC_PARAM_IHI;  break;
  305.           }
  306.       } else if(mode == TRIANGLE_CURRENT) {
  307.           switch(TCCurrentParam) {
  308.             case TC_PARAM_IHI:
  309.               TCCurrentParam = TC_PARAM_ILO;  break;
  310.             case TC_PARAM_ILO:
  311.               TCCurrentParam = TC_PARAM_THI;  break;
  312.             case TC_PARAM_THI:
  313.               TCCurrentParam = TC_PARAM_TLO;  break;
  314.             case TC_PARAM_TLO:
  315.               TCCurrentParam = TC_PARAM_IHI;  break;
  316.           }
  317.       } else if(mode == SINE_CURRENT) {
  318.           switch(SNCCurrentParam) {
  319.             case SNC_PARAM_IHI:
  320.               SNCCurrentParam = SNC_PARAM_ILO;  break;
  321.             case SNC_PARAM_ILO:
  322.               SNCCurrentParam = SNC_PARAM_T;  break;
  323.             case SNC_PARAM_T:
  324.               SNCCurrentParam = SNC_PARAM_IHI;  break;
  325.           }
  326.       }
  327.     //Prevent double triggering?
  328.     delay(200);
  329.   }
  330. //A little delay for good luck
  331. delay(100);
  332. }
ElectronicLoad-master.zip (154.42 KB, 下载次数: 62)
ID:61724 发表于 2020-3-10 17:06 | 显示全部楼层
谢谢分享  学习一下
ID:742301 发表于 2020-5-19 00:50 来自触屏版 | 显示全部楼层
楼主,可以教我一下嘛
ID:250384 发表于 2023-5-1 20:46 | 显示全部楼层
学习下,在准备DIY个电子负载。
ID:138707 发表于 2023-7-29 17:43 | 显示全部楼层
楼主,可以教我一下嘛
