查看: 2353|回复: 0
最近在看airkiss转个代码大家研究研究
ID:270866 发表于 2018-1-3 16:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <pthread.h>
#include <errno.h>
#include <sys/time.h>
#include <string.h>
#include <unistd.h>
#include <stdlib.h>
#include <signal.h>
#include "capture/common.h"
#include "capture/osdep.h"
#include "utils/utils.h"
#include "utils/wifi_scan.h"
#include "airkiss.h"
#define MAX_CHANNELS 13
#define DEBUG 0
static airkiss_context_t akcontex = {{0},{0}};
const airkiss_config_t akconf = {
(airkiss_memset_fn)&memset,
(airkiss_memcpy_fn)&memcpy,
(airkiss_memcmp_fn)&memcmp,
(airkiss_printf_fn)&printf };
airkiss_result_t ak_result;
struct itimerval my_timer;
char *wifi_if = NULL;
struct wif *wi = NULL;
int g_channel = 0;
unsigned char g_buf[RECV_BUFSIZE] = {0};
int second = 0;
int startTimer(struct itimerval *timer);
int stopTimer(struct itimerval *timer);
static char *getIP(void)
    int sock_get_ip;
   char ipaddr[50];
   struct   sockaddr_in *sin;
   struct   ifreq ifr_ip;
   if ((sock_get_ip=socket(AF_INET, SOCK_STREAM, 0)) == -1)
        LOG_TRACE("socket create failse...GetLocalIp!/n");
        return NULL;
   memset(&ifr_ip, 0, sizeof(ifr_ip));
   strncpy(ifr_ip.ifr_name, "wlan0", sizeof(ifr_ip.ifr_name) - 1);
   if( ioctl( sock_get_ip, SIOCGIFADDR, &ifr_ip) < 0 )
        close( sock_get_ip );
        return NULL;
   sin = (struct sockaddr_in *)&ifr_ip.ifr_addr;
   strcpy(ipaddr,inet_ntoa(sin->sin_addr));
   LOG_TRACE("local ip:%s /n",ipaddr);
    return ipaddr;
static void Connect_wifi(char *ssid,char *password)
  /*1.退出混杂模式*/
  system((char *)"iwconfig wlan0 mode auto");
  usleep( 10000 ); /* madwifi needs a second chance */
  /*2.添加配置文件*/
  sprintf((char *)g_buf,"wpa_passphrase \"%s\"  \"%s\" > /etc/ssidpwd.conf",ssid,password);
  LOG_TRACE("%s \r\n",g_buf);
  system((char *)g_buf);
  memset(g_buf,0x00,RECV_BUFSIZE);
   /*3.执行配置文件*/
  sprintf((char *)g_buf,"wpa_supplicant -B -iwlan0 -Dwext -c /etc/ssidpwd.conf");
/*开启DHCP*/
  system((char *)"udhcpc -iwlan0");
        do{
          LOG_TRACE("I have no IP,wait...\r\n");
          usleep(200000);
        } while(!getIP());
int udp_broadcast(unsigned char random, int port);
void switch_channel_callback(void)
   if(g_channel >= MAX_CHANNELS)
           g_channel = 1;
   }else
           g_channel++;
    wi->wi_set_channel(wi,g_channel);
   airkiss_change_channel(&akcontex);
int process_airkiss(const unsigned char *packet, int size)
    int ret;
        int num = 0;
    ret = airkiss_recv(&akcontex, (void *)packet, size);
    if(ret == AIRKISS_STATUS_CONTINUE)
      //LOG_TRACE("wi_get_channel =  %d\r\n", wi->wi_get_channel(wi));
    else if(ret == AIRKISS_STATUS_CHANNEL_LOCKED)
        LOG_TRACE("\r\n*****************Lock channel in %d*****************\r\n", g_channel);
        stopTimer(&my_timer);
    else if(ret == AIRKISS_STATUS_COMPLETE)
        airkiss_get_result(&akcontex, &ak_result);
        LOG_TRACE("******************Airkiss Complete******************\r\n"
                              "reserved:[%x]\npwd:[%s]\nssid:[%s]\nrandom:[0x%02x]",
            ak_result.reserved,
            ak_result.pwd,
            ak_result.ssid,
            ak_result.random);
        //TODO: scan and connect to wifi
        Connect_wifi(ak_result.ssid,ak_result.pwd);
        udp_broadcast(ak_result.random, 10000);
        #if DEBUG
    if(1) {
        /* print  header */
        printf("len:%4d, airkiss ret:%d [ ", size, ret);
        int i;
        unsigned char ch;
        for(i=0; i<24; i++)
            ch = (unsigned char)*(packet + i);
            printf("%02x ", ch);
        printf("]\n");
        #endif
    return ret;
       if(second == 0)
          second = 200;
    timer->it_interval.tv_sec = 0;
    timer->it_interval.tv_usec = second*1000;
    timer->it_value.tv_sec = 0;
    timer->it_value.tv_usec = second*1000;
        if(setitimer(ITIMER_REAL, timer, NULL) < 0)
            LOG_TRACE("Set timer failed!\n");
    return 0;
    timer->it_interval.tv_usec = 0;
    timer->it_value.tv_usec = 0;
    return 0;
    int fd;
    int enabled = 1;
    int err;
    struct sockaddr_in addr;
    addr.sin_family = AF_INET;
    addr.sin_addr.s_addr = INADDR_BROADCAST;
    addr.sin_port = htons(port);
    fd = socket(AF_INET, SOCK_DGRAM, 0);
    if (fd < 0)
        LOG_TRACE("Error to create socket, reason: %s\r\n", strerror(errno));
        return 1;
    err = setsockopt(fd, SOL_SOCKET, SO_BROADCAST, (char *) &enabled, sizeof(enabled));
    if(err == -1)
        close(fd);
                LOG_TRACE("setsockopt socket SO_BROADCAST, reason: %s\r\n", strerror(errno));
        return 1;
    LOG_TRACE("Sending random to broadcast..\r\n");
    int i;
    useconds_t usecs = 1000*20;
    for(i=0;i<50;i++)
        sendto(fd, (unsigned char *)&random, 1, 0, (struct sockaddr*)&addr, sizeof(struct sockaddr));
        usleep(usecs);
    close(fd);
    return 0;
int main(int argc, char *argv[])
    int read_size;
    if(argc!=3)
        LOG_ERROR("Usage: %s <device-name> <change-channel-ZZZZZtime>", argv[0]);
        return 1;
    wifi_if = argv[1];
/*设置网卡模式*/
        second = atoi(argv[2]);
    LOG_ERROR("second = %d \r\n", second);
           strcpy((char *)g_buf,"iwconfig wlan0 mode auto");
/*禁止网络服务*/
        strcpy((char *)g_buf,"killall wpa_supplicant");
/*关闭dhcp服务*/
        strcpy((char *)g_buf," killall udhcpc");
/*卸载网卡*/
   strcpy((char *)g_buf,"rmmod 8723bu.ko");
/*装载网卡*/
  strcpy((char *)g_buf,"insmod /lib/modules/3.14.38-6UL_ga\+ge4944a5/kernel/drivers/net/wireless/realtek/rtl8723BU/8723bu.ko");
   //strcpy((char *)g_buf,"insmod 8723bu.ko");
/*使能网卡*/
   strcpy((char *)g_buf,"ifconfig wlan0 up");
#if 0
/*扫描周围热点,非必须,都为可见热点可以减少扫描信道的时间,遇到非可见热点就行不通了!!!!*/
    wireless_scan_head head;
    wireless_scan *presult = NULL;
    LOG_TRACE("Scanning accesss point...");
    if(wifi_scan(wifi_if, &head) == 0)
        LOG_TRACE("Scan success.");
        presult = head.result;
        while(presult != NULL) {
            char essid[MAX_ESSID_SIZE];
            char bssid[MAX_BSSID_SIZE];
            unsigned int freq;
            int channel,power;
            unsigned char essid_crc;
            get_essid(presult, essid, MAX_ESSID_SIZE);
            get_bssid(presult, bssid, MAX_BSSID_SIZE);
            freq = get_freq_mhz(presult);
            power = get_strength_dbm(presult);
            channel = getChannelFromFrequency(freq);
            LOG_TRACE("bssid:[%s], channel:[%2d], pow:[%d dBm], essid_crc:[%02x], essid:[%s]",
                    bssid, channel, power, essid_crc, essid);
            presult = presult->next;
        LOG_ERROR("ERROR to scan AP, init with all %d channels", MAX_CHANNELS);
#endif
    /* Open the interface and set mode monitor */
        /*设置网卡速率*/
        //strcpy((char *)g_buf,"iwconfig wlan0 rate 11M");
        strcpy((char *)g_buf,"iwconfig wlan0 rate auto");
        wi = wi_open(wifi_if);
        if (!wi) {
                LOG_ERROR("cannot init interface %s", wifi_if);
                return 1;
    /* airkiss setup */
    int result;
    result = airkiss_init(&akcontex, &akconf);
    if(result != 0)
        LOG_ERROR("Airkiss init failed!!");
        return 1;
    LOG_TRACE("Airkiss version: %s", airkiss_version());
    /* Setup channel switch timer */
    startTimer(&my_timer);
    signal(SIGALRM,(__sighandler_t)&switch_channel_callback);
        for(;;)
                read_size = wi->wi_read(wi, g_buf, RECV_BUFSIZE, NULL);
                if (read_size < 0) {
                        LOG_ERROR("recv failed, ret %d", read_size);
                        break;
          if((read_size >= 24) && (AIRKISS_STATUS_COMPLETE==process_airkiss(g_buf, read_size)))
             break;
    return 0;
