查看: 1306|回复: 0
LED5097英文pdf资料下载
ID:271277 发表于 2018-1-4 13:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The TLD5097EL is a LED boost controller with built in protection features. The main function of this device is to regulate
a constant LED current. The constant current regulation is especially beneficial for LED color accuracy and longer lifetime.
The controller concept of the TLD5097EL allows multiple configurations such as Boost, Buck, Buck-Boost, SEPIC and
Flyback by simply adjusting the external components. The TLD5097EL offers the most flexible dimming options. Dimming
can be achieved with analog or PWM input.The switching frequency is adjustable in the range of 100 kHz to 500 kHz and
can be synchronized to an external clock source. The TLD5097EL features an enable function reducing the shut-down
current consumption to Iq_OFF < 10 μA. The current mode regulation scheme of this device provides a stable regulation
loop maintained by small external compensation components. The integrated soft start feature limits the current peak as
well as voltage overshoot at start-up. This IC is suited for use in the harsh automotive environments and provides output
overvoltage protection and device overtemperature shutdown.
Infineon-TLD5097EL-DS-v01_00-EN.pdf
1017.15 KB, 下载次数: 3, 下载积分: 黑币 -5
