查看: 1439|回复: 0
我的超声波测距程序
ID:271530 发表于 2018-1-4 18:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
void delay(uchar xms);//延时大概x毫秒
void display(uchar number);
void main(void);
void count(void);
void didi();
sbit Trig=P1^3; //超声波发射端
sbit Echo=P1^2; //接
sbit g=P2^5;
sbit s=P2^4;
sbit beep=P2^2;         //报警
sbit led=P2^0;
bit flag=0;
uint time=0;
uint timer=0;
uint M;
code uchar buf[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40}; //{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40}共阳
void delay(uint z)
        uint i,j;
        for(i=z;i>0;i--)
         for(j=640;j>0;j--);
        g = 0;
        s = 1;
        P0 = buf[number%10];
        delay(1);
        P0 = 0xff;
    g = 1;
        s = 0;
        P0 = buf[number/10%10];
        delay(1);
void main(void)
      TMOD=0X11; //定时器工作方式1,GATE=1;
      TH0=0;
      TL0=0;
               ET0=1;         //T0中断
          ET1=1;         //T1中断
          TR1=0;         //开启定时器
      EA=1; //开总中断
    while(!Echo); //当RX为零时等待
    while(Echo); //当RX为1时计数并等待
  didi();
void count(void)
    time=TH0*256+TL0;
    TH0=0;
    TL0=0; //清零
    M=(time*1.7)/100;//厘米
    for(M>=1;M<=20;flag==1)//范围0--5米
          int k;
         for(k=0;k<=999;k++)
        display(k);
