查看: 3153|回复: 8
求高手能在不影响程序使用的前期下把两个程序合成一个程序
ID:271839 发表于 2018-1-9 22:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
程序一:数码管动态显示
#include <reg52.h>
*                数码管动态显示学号
*                          朱建康
sbit led1 = P3^7;
sbit led2 = P3^6;
sbit led3 = P3^5;
sbit led4 = P3^4;
//数码管0~9缓存
unsigned char code LedChar[]={
        0x82, 0xE7, 0x2A, 0x26, 0x47, 0x16, 0x12, 0xA7,
        0x02, 0x06};
//学号:150401114
unsigned char IDBuff[] = {
        0xFF, 0x7F, 0x7F, 0x7F, 0x43, 0x1a, 0xda, 0xda,
        0x82, 0x7F, 0x7F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF,
        0xFF};
unsigned char LedBuff[9];
unsigned char flag_200ms = 0;
*  主函数
void main(void)
        unsigned char t = 0;
        TMOD = 0X01;
        TH0 = 0XFC;
        TL0 = 0X67;
        TR0 = 1;
        EA = 1;
        ET0 = 1;
                if(flag_200ms == 1)
                        flag_200ms = 0;
                        LedBuff[0] = IDBuff[t];
                        LedBuff[1] = IDBuff[t+1];
                        LedBuff[2] = IDBuff[t+2];
                        LedBuff[3] = IDBuff[t+3];
                        t++;
                        if(t>=18) t = 0;
void InterruptTime0() interrupt 1
        static unsigned char i = 0;
        static unsigned char cnt = 0;
        TH0 = 0xFC;
        TL0 = 0X67;
        cnt++;
        if(cnt>200)
                cnt = 0;
                   flag_200ms = 1;
        P2 = 0xFF;        //消隐
        switch(i)
                case 0: led1=0; led2=1; led3=1; led4=1; i++; P2=LedBuff[0]; break;
                case 1: led1=1; led2=0; led3=1; led4=1; i++; P2=LedBuff[1]; break;
                case 2: led1=1; led2=1; led3=0; led4=1; i++; P2=LedBuff[2]; break;
                case 3: led1=1; led2=1; led3=1; led4=0; i=0; P2=LedBuff[3]; break;
                default: break;
程序二:蜂鸣器放歌
#include <STC15F2K60S2.h>
unsigned char Count;
sbit _Speak =P5^4;
unsigned char code SONG[] ={      //祝你平安
0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00
void Time1_Init()
TMOD = 0x10;
IE   = 0x82;
TH1  = 0xD8;
TL1  = 0xEF;  //12MZ晶振,10ms
void Time0_Int() interrupt 3
TH1 = 0xD8;
TL1 = 0xEF;
Count++;   //长度加1
功能:1MS延时子程序
void Delay_xMs(unsigned int x)
    unsigned int i,j;
    for( i =0;i < x;i++ )
        for( j =0;j<3;j++ );
void Play_Song(unsigned char i)
unsigned char Temp1,Temp2;
unsigned int Addr;
Count = 0;      //中断计数器清0
Addr = i * 217;
  Temp1 = SONG[Addr++];
     if ( Temp1 == 0xFF )          //休止符
      TR1 = 0;
      Delay_xMs(100);
     else if ( Temp1 == 0x00 )   //歌曲结束符
      return;
      Temp2 = SONG[Addr++];
      TR1 = 1;
       _Speak = ~_Speak;
       Delay_xMs(Temp1);
       if ( Temp2 == Count )
        Count = 0;
        break;
功能:主程序
Time1_Init();   //定时器0中断初始化
  Play_Song(0);  //播放
PS:我使用的是IAPF2K60S2(stc15F2K60S2)
ID:271839 发表于 2018-1-9 22:54 | 只看该作者
求各位大佬帮助 拜谢
ID:123289 发表于 2018-1-10 00:42 | 只看该作者
不要说是两个,十个八也不在话下。关键是你如何构思!
你不会构思,就先学画流程框图,一步步来,流程走通了,再依流程写程序。
记住写程序的关键不在写语句上,而是在构思流程上。试作画出框图吧。
看别人的案例,重点是看通他人的流程图,之后对照流程图看程序,这样才能理解,才能学到东西。
ID:231046 发表于 2018-1-10 08:55 | 只看该作者
对的,程序就是按要求实现特定的功能 ,要怎么实现完全看写程序人的思想,如去北京可以坐火车,也可以坐飞机,也可以走路,,一样的道理
ID:271839 发表于 2018-1-10 10:40 | 只看该作者
你不会构思,就先学画流程框图,一步步来,流程走通 ...
能不能先帮我合一下 暂时有点急
ID:258566 发表于 2018-1-10 10:53 | 只看该作者
楼主,首先程序要正确,才能合并。变量t没有定义,定时器1没有启动。tr1
ID:258566 发表于 2018-1-10 10:57 | 只看该作者
//#include <reg52.h>
*                数码管动态显示学号
*                          朱建康
sbit led1 = P3^7;
sbit led2 = P3^6;
sbit led3 = P3^5;
sbit led4 = P3^4;
unsigned char t;
//数码管0~9缓存
unsigned char code LedChar[] = {
        0x02, 0x06
//学号:150401114
unsigned char code IDBuff[] = {
        0xFF
*  主函数
//void main(void)
//unsigned char t = 0;
//TMOD = 0X01;
//TH0 = 0XFC;
//TL0 = 0X67;
//TR0 = 1;
//EA = 1;
//ET0 = 1;
//while(1)
//if(flag_200ms == 1)
//flag_200ms = 0;
//LedBuff[0] = IDBuff[t];
//LedBuff[1] = IDBuff[t+1];
//LedBuff[2] = IDBuff[t+2];
//LedBuff[3] = IDBuff[t+3];
//t++;
//if(t>=18) t = 0;
        TH0 = 0xFC;
        TL0 = 0X67;
        cnt++;
        if (cnt > 200)
//flag_200ms = 0;
                LedBuff[1] = IDBuff[t + 1];
                LedBuff[2] = IDBuff[t + 2];
                LedBuff[3] = IDBuff[t + 3];
                t++;
                if (t >= 18)
                        t = 0;
        P2 = 0xFF;        //消隐
        switch (i)
                case 0:
                        led1 = 0;
                        led2 = 1;
                        led3 = 1;
                        led4 = 1;
                        i++;
                        P2 = LedBuff[0];
                        break;
                case 1:
                        led1 = 1;
                        led2 = 0;
                        led3 = 1;
                        led4 = 1;
                        i++;
                        P2 = LedBuff[1];
                        break;
                case 2:
                        led1 = 1;
                        led2 = 1;
                        led3 = 0;
                        led4 = 1;
                        i++;
                        P2 = LedBuff[2];
                        break;
                case 3:
                        led1 = 1;
                        led2 = 1;
                        led3 = 1;
                        led4 = 0;
                        i = 0;
                        P2 = LedBuff[3];
                        break;
                default:
                        break;
//程序二:蜂鸣器放歌
//#include <STC15F2K60S2.h>
sbit _Speak = P5 ^ 4;
unsigned char code SONG[] = {        //祝你平安
        0x26, 0x20, 0x20, 0x20, 0x20, 0x20, 0x26, 0x10, 0x20, 0x10, 0x20, 0x80, 0x26, 0x20, 0x30, 0x20,
        0x30, 0x20, 0x39, 0x10, 0x30, 0x10, 0x30, 0x80, 0x26, 0x20, 0x20, 0x20, 0x20, 0x20, 0x1c, 0x20,
        0x20, 0x80, 0x2b, 0x20, 0x26, 0x20, 0x20, 0x20, 0x2b, 0x10, 0x26, 0x10, 0x2b, 0x80, 0x26, 0x20,
        0x30, 0x20, 0x30, 0x20, 0x39, 0x10, 0x26, 0x10, 0x26, 0x60, 0x40, 0x10, 0x39, 0x10, 0x26, 0x20,
        0x30, 0x20, 0x30, 0x20, 0x39, 0x10, 0x26, 0x10, 0x26, 0x80, 0x26, 0x20, 0x2b, 0x10, 0x2b, 0x10,
        0x2b, 0x20, 0x30, 0x10, 0x39, 0x10, 0x26, 0x10, 0x2b, 0x10, 0x2b, 0x20, 0x2b, 0x40, 0x40, 0x20,
        0x20, 0x10, 0x20, 0x10, 0x2b, 0x10, 0x26, 0x30, 0x30, 0x80, 0x18, 0x20, 0x18, 0x20, 0x26, 0x20,
        0x20, 0x20, 0x20, 0x40, 0x26, 0x20, 0x2b, 0x20, 0x30, 0x20, 0x30, 0x20, 0x1c, 0x20, 0x20, 0x20,
        0x20, 0x80, 0x1c, 0x20, 0x1c, 0x20, 0x1c, 0x20, 0x30, 0x20, 0x30, 0x60, 0x39, 0x10, 0x30, 0x10,
        0x20, 0x20, 0x2b, 0x10, 0x26, 0x10, 0x2b, 0x10, 0x26, 0x10, 0x26, 0x10, 0x2b, 0x10, 0x2b, 0x80,
        0x18, 0x20, 0x18, 0x20, 0x26, 0x20, 0x20, 0x20, 0x20, 0x60, 0x26, 0x10, 0x2b, 0x20, 0x30, 0x20,
        0x30, 0x20, 0x1c, 0x20, 0x20, 0x20, 0x20, 0x80, 0x26, 0x20, 0x30, 0x10, 0x30, 0x10, 0x30, 0x20,
        0x39, 0x20, 0x26, 0x10, 0x2b, 0x10, 0x2b, 0x20, 0x2b, 0x40, 0x40, 0x10, 0x40, 0x10, 0x20, 0x10,
        0x20, 0x10, 0x2b, 0x10, 0x26, 0x30, 0x30, 0x80, 0x00
//void Time1_Init()
        //TMOD = 0x10;
        //IE = 0x82;
        //TH1 = 0xD8;
        //TL1 = 0xEF;        //12MZ晶振,10ms
        TH1 = 0xD8;
        TL1 = 0xEF;
        Count++;        //长度加1
   功能:1MS延时子程序
        unsigned int i, j;
        for (i = 0; i < x; i++)
                for (j = 0; j < 3; j++) ;
        unsigned char Temp1, Temp2;
        unsigned int Addr;
        Addr = i * 217;
        while (1)
                if (Temp1 == 0xFF)        //休止符
                        TR1 = 0;
                        Delay_xMs(100);
                else if (Temp1 == 0x00)        //歌曲结束符
                        return;
                        TR1 = 1;
                        while (1)
                                _Speak = ~_Speak;
                                Delay_xMs(Temp1);
                                if (Temp2 == Count)
                                        Count = 0;
                                        break;
   功能:主程序
        TMOD = 0X11;
        TH0 = 0XFC;
        TL0 = 0X67;
        TR0 = 1;
        EA = 1;
        ET0 = 1;        ET1 = 1;
        //IE = 0x82;//8a
        TH1 = 0xD8;
        TR1 = 1;
//Time1_Init();   //定时器0中断初始化
        while (1)
                Play_Song(0);        //播放
//PS:我使用的是IAPF2K60S2(stc15F2K60S2)
ID:271839 发表于 2018-1-10 11:26 | 只看该作者
能不能帮我操作一下 我现在急着用
ID:271839 发表于 2018-1-10 11:52 | 只看该作者
我刚开始学这个 是小白  能不能帮我弄一下 谢谢
