查看: 5011|回复: 1
基于单片机室内温度检测程序源码
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #define uint unsigned int
  5. #define noACK 0
  6. #define ACK   1
  7. #define STATUS_REG_W 0x06
  8. #define STATUS_REG_R 0x07
  9. #define MEASURE_TEMP 0x03
  10. #define MEASURE_HUMI 0x05
  11. #define RESET        0x1e
  12. enum {TEMP,HUMI};
  13. typedef union     //定义共用同类型
  14. {
  15. unsigned int i;
  16. float f;
  17. } value;
  18. sbit lcdrs=P2^0;
  19. sbit rw=P2^1;
  20. sbit lcden=P2^2;
  21. sbit SCK = P1^0;
  22. sbit DATA = P1^1;
  23. sbit t_low = P3^0;
  24. sbit t_high = P3^1;
  25. sbit r_low = P3^2;
  26. sbit r_high = P3^3;
  27. sbit zeng = P3^4;
  28. sbit jian = P3^5;
  29. sbit beep = P3^7;
  30. uchar table3[]="T:      ";
  31. uchar table4[]="R:";
  32. uchar table5[]=".";
  33. uchar wendu[5];
  34. uchar shidu[5];
  35. uchar t_fanwei[]="1050";
  36. uchar r_fanwei[]="1090";
  37. char t_a=10,t_b=50,r_a=10,r_b=90;
  38. uchar flag_tlow=0,
  39. flag_thigh=0,
  40. flag_rlow=0,
  41. flag_rhigh=0;
  42. void delay(uint z)
  43. {
  44. uint x,y;
  45. for(x=110;x>0;x--)
  46. for(y=z;y>0;y--);
  47. }
  48. void delay_50us(uint t)
  49. {
  50. uint j;
  51. for(;t>0;t--)
  52.   for(j=19;j>0;j--);
  53. }
  54. void delay_50ms(uint t)
  55. {
  56. uint j;
  57. for(;t>0;t--)
  58. for(j=6245;j>0;j--);
  59. }
  60. void write_data(uchar dataa)
  61. {
  62. rw=0;
  63. lcdrs=1;
  64. P0=dataa;
  65. delay(5);
  66. lcden=1;
  67. delay(20);
  68. lcden=0;
  69. }
  70. void write_con(uchar con)
  71. {
  72. rw=0;
  73. lcdrs=0;
  74. P0=con;
  75. delay(5);
  76. lcden=1;
  77. delay(20);
  78. lcden=0;
  79. }
  80. void init()
  81. {
  82.     rw=0;
  83. write_con(0x38);
  84. write_con(0x06);
  85. write_con(0x0c);
  86. write_con(0x01);
  87. }
  88. void display2(void)
  89. {
  90. uchar i;
  91. write_con(0x80);
  92. for(i=0;i<8;i++)
  93. {
  94. write_data(table3[i]);
  95. delay_50us(1);
  96. }
  97. write_con(0x86);
  98. write_data(0xdf);
  99. write_data('C');
  100. }
  101. void display3(void)
  102. {
  103. uchar i;
  104. write_con(0x80+0x40);
  105. for(i=0;i<2;i++)
  106. {
  107. write_data(table4[i]);
  108. delay_50us(1);
  109. }
  110. write_con(0x80+0x46);
  111. write_data('%');
  112. }
  113. void displaywendu(void)
  114. {
  115. uchar i;
  116. write_con(0x82);
  117. for(i=0;i<2;i++)
  118. {
  119. write_data(wendu[i]);
  120. delay_50us(1);
  121. }
  122. for(i=0;i<1;i++)
  123. {
  124. write_data(table5[i]);
  125. delay_50us(1);
  126. }
  127. for(i=3;i<4;i++)
  128. {
  129. write_data(wendu[i]);
  130. delay_50us(1);
  131. }
  132. }
  133. void displayshidu(void)
  134. {
  135. uchar i;
  136. write_con(0x80+0x42);
  137. for(i=0;i<2;i++)
  138. {
  139. write_data(shidu[i]);
  140. delay_50us(1);
  141. }
  142. for(i=0;i<1;i++)
  143. {
  144. write_data(table5[i]);      //.
  145. delay_50us(1);
  146. }
  147. for(i=3;i<4;i++)
  148. {
  149. write_data(shidu[i]);
  150. delay_50us(1);
  151. }
  152. }
  153. char s_write_byte(unsigned char value)
  154. {
  155. unsigned char i,error=0;
  156. for (i=0x80;i>0;i>>=1)             //高位为1,循环右移
  157. {    if (i&value) DATA=1;          //和要发送的数相与,结果为发送的位
  158. else DATA=0;
  159. SCK=1;
  160.        _nop_();_nop_();_nop_();        //延时3us
  161. SCK=0;
  162. }
  163. DATA=1;                           //释放数据线
  164. SCK=1;
  165. error=DATA;                       //检查应答信号,确认通讯正常  _nop_();_nop_();_nop_();  SCK=0;
  166. DATA=1;
  167. return error;                     //error=1 通讯错误
  168. }
  169. char s_read_byte(unsigned char ack)
  170. {
  171. unsigned char i,val=0;
  172. DATA=1;                           //释放数据线
  173. for(i=0x80;i>0;i>>=1)             //高位为1,循环右移
  174. {
  175. SCK=1;
  176.    if(DATA) val=(val|i);             //读一位数据线的值
  177. SCK=0;
  178. }
  179. DATA=!ack;                        //如果是校验,读取完后结束通讯;
  180. SCK=1;
  181. _nop_();_nop_();_nop_();          //延时3us
  182. SCK=0;
  183. _nop_();_nop_();_nop_();
  184. DATA=1;                           //释放数据线
  185. return val;
  186. }
  187. void s_transstart(void)
  188. {
  189. DATA=1;
  190. SCK=0;                   //准备
  191. _nop_();
  192. SCK=1;
  193. _nop_();
  194. DATA=0;
  195. _nop_();
  196. SCK=0;
  197. _nop_();_nop_();_nop_();
  198. SCK=1;
  199. _nop_();
  200. DATA=1;
  201. _nop_();
  202. SCK=0;
  203. }
  204. void s_connectionreset(void)
  205. {
  206. unsigned char i;
  207. DATA=1; SCK=0;                    //准备
  208. for(i=0;i<9;i++)                  //DATA保持高,SCK时钟触发9次,发送启动传输,通迅即复位
  209. {
  210. SCK=1;
  211. SCK=0;
  212. }
  213.   s_transstart();                   //启动传输
  214. }
  215. char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
  216. {
  217. unsigned error=0;
  218. unsigned int i;
  219. s_transstart();                   //启动传输
  220. switch(mode)                     //选择发送命令
  221. {
  222. case TEMP : error+=s_write_byte(MEASURE_TEMP);
  223. break;     //测量温度
  224. case HUMI : error+=s_write_byte(MEASURE_HUMI); break;     //测量湿度
  225.       default     : break;
  226. }
  227. for (i=0;i<65535;i++) if(DATA==0) break;        //等待测量结束
  228. if(DATA) error+=1;                              // 如果长时间数据线没有拉低,说明测量错误
  229. *(p_value) =s_read_byte(ACK);      //读第一个字节,高字节 (MSB)  *(p_value+1)=s_read_byte(ACK);      //读第二个字节,低字节 (LSB)
  230. *p_checksum =s_read_byte(noACK);  //read CRC校验码
  231. return error;     // error=1 通讯错误
  232. }
  233. void calc_sth10(float *p_humidity ,float *p_temperature)
  234. {
  235. const float C1=-4.0;              // 12位湿度精度 修正公式
  236. const float C2=+0.0405;           // 12位湿度精度 修正公式
  237. const float C3=-0.0000028;        // 12位湿度精度 修正公式
  238. const float T1=+0.01;             // 14位温度精度 5V条件  修正公式
  239. const float T2=+0.00008;          // 14位温度精度 5V条件  修正公式
  240. float rh=*p_humidity;             // rh:      12位 湿度
  241. float t=*p_temperature;           // t:       14位 温度
  242. float rh_lin;                     // rh_lin: 湿度 linear值
  243. float rh_true;                    // rh_true: 湿度 ture值
  244. float t_C;                        // t_C   : 温度 ℃
  245. t_C=t*0.01 - 40;                  //补偿温度
  246. rh_lin=C3*rh*rh + C2*rh + C1;     //相对湿度非线性补偿
  247. rh_true=(t_C-25)*(T1+T2*rh)+rh_lin;   //相对湿度对于温度依赖性补偿  if(rh_true>100)rh_true=100;       //湿度最大修正
  248. if(rh_true<0.1)rh_true=0.1;       //湿度最小修正
  249. *p_temperature=t_C;               //返回温度结果
  250. *p_humidity=rh_true;              //返回湿度结果
  251. }
  252. void main(void)
  253. {
  254. unsigned int temp,humi,i,j;
  255. value humi_val,temp_val;  //定义两个共同体,一个用于湿度,一个用于温度
  256. unsigned char error;      //用于检验是否出现错误
  257. unsigned char checksum;   //  CRC
  258. init();
  259. //display1();
  260. display2();
  261. display3();
  262. beep=1;
  263. s_connectionreset();      //启动连接复位
  264. while(1)
  265. {
  266. error=0;        //初始化error=0,即没有错误
  267. error+=s_measure((unsigned char*)&temp_val.i,&checksum,TEMP); //温度测量
  268. error+=s_measure((unsigned char*)&humi_val.i,&checksum,HUMI); //湿度测量
  269. if(error!=0) s_connectionreset();                 ////如果发生错误,系统复位
  270. else
  271. {
  272. humi_val.f=(float)humi_val.i;                   //转换为浮点数
  273. temp_val.f=(float)temp_val.i;                   //转换为浮点数
  274. calc_sth10(&humi_val.f,&temp_val.f);            //修正相对湿度及温度
  275.    temp=temp_val.f*10;
  276. humi=humi_val.f*10; //
  277. wendu[0]=temp/1000+'0';       //温度百位
  278. wendu[0]=temp%1000/100+'0';      //温度十位
  279. wendu[1]=temp%100/10+'0';   //温度个位
  280. wendu[2]=0x2E;      //小数点
  281. wendu[3]=temp%10+'0';    //温度小数点后第一位
  282. displaywendu();          //
  283. shidu[0]=humi/1000+'0';       //湿度百位
  284. shidu[0]=humi%1000/100+'0';      //湿度十位
  285. shidu[1]=humi%100/10+'0';   //湿度个位
  286. shidu[2]=0x2E;      //小数点
  287. shidu[3]=humi%10+'0';    //湿度小数点后第一位
  288. displayshidu();
  289. }
  290. delay(800);                             //等待足够长的时间,以现行下一次转换
  291. if(t_low==0)
  292. {
  293. delay(10);
  294. if(t_low==0)
  295. {
  296. flag_tlow=1;
  297. flag_thigh=0;
  298. flag_rlow=0;
  299. flag_rhigh=0;
  300. }
  301. }
  302. if(t_high==0)
  303. {
  304. delay(10);
  305. if(t_high==0)
  306. {
  307. flag_tlow=0;
  308. flag_thigh=1;
  309. flag_rlow=0;
  310. flag_rhigh=0;
  311. }
  312. }
  313. if(r_low==0)
  314. {
  315. delay(10);
  316. if(r_low==0)
  317. {
  318. flag_tlow=0;
  319. flag_thigh=0;
  320. flag_rlow=1;
  321. flag_rhigh=0;
  322. }
  323. }
  324. if(r_high==0)
  325. {
  326. delay(10);
  327. if(r_high==0)
  328. {
  329. flag_tlow=0;
  330. flag_thigh=0;
  331. flag_rlow=0;
  332. flag_rhigh=1;
  333. }
  334. }
  335. if( flag_tlow==1)    //1
  336. {
  337. if(zeng==0)
  338. {
  339. delay(10);
  340. if(zeng==0)
  341. {
  342. t_a++;
  343. if(t_a==99)
  344. t_a=0;
  345. if(t_a>=t_b)
  346. t_a=t_b;
  347. }
  348. }
  349. if(jian==0)
  350. {
  351. delay(10);
  352. if(jian==0)
  353. {
  354. t_a--;
  355. if(t_a<=0)
  356. t_a=0;
  357. }
  358. }
  359. }
  360. if( flag_thigh==1)
  361. {
  362. if(zeng==0)
  363. {
  364. delay(10);
  365. if(zeng==0)
  366. {
  367. t_b++;
  368. if(t_b==99)
  369. t_b=t_a;
  370. }
  371. }
  372. if(jian==0)
  373. {
  374. delay(10);
  375. if(jian==0)
  376. {
  377. t_b--;
  378. if(t_b<=t_a)
  379. t_b=t_a;
  380. }
  381. }
  382. }
  383. if( flag_rlow==1)   //3
  384. {
  385. if(zeng==0)
  386. {
  387. delay(10);
  388. if(zeng==0)
  389. {
  390. r_a++;
  391. if(r_a==99)
  392. r_a=0;
  393. if(r_a>=r_b)
  394. r_a=r_b;
  395. }
  396. }
  397. if(jian==0)
  398. {
  399. delay(10);
  400. if(jian==0)
  401. {
  402. r_a--;
  403. if(r_a<=0)
  404. r_a=0;
  405. }
  406. }
  407. }
  408. if(flag_rhigh==1)
  409. {
  410. if(zeng==0)
  411. {
  412. delay(10);
  413. if(zeng==0)
  414. {
  415. r_b++;
  416. if(r_b==99)
  417. r_b=r_a;
  418. }
  419. }
  420. if(jian==0)
  421. {
  422. delay(10);
  423. if(jian==0)
  424. {
  425. r_b--;
  426. if(r_b<=r_a)
  427. r_b=r_a;
  428. }
  429. }
  430. }
  431. t_fanwei[0]=t_a/10;
  432. t_fanwei[1]=t_a%10;
  433. t_fanwei[2]=t_b/10;
  434. t_fanwei[3]=t_b%10;
  435. r_fanwei[0]=r_a/10;
  436. r_fanwei[1]=r_a%10;
  437. r_fanwei[2]=r_b/10;
  438. r_fanwei[3]=r_b%10;
  439. write_con(0x80+9);
  440. for(i=0;i<2;i++)
  441. {
  442. write_data(t_fanwei[i]+0x30);       //
  443. write_data('1');
  444. delay_50us(1);
  445. }
  446. write_data('-');
  447. write_con(0x80+12);
  448. for(i=2;i<4;i++)
  449. {
  450. write_data(t_fanwei[i]+0x30);       //
  451. write_data('1');
  452. delay_50us(1);
  453. }
  454. write_data(0xdf);
  455. write_data('C');
  456. write_con(0x80+9+0x40);
  457. for(j=0;j<2;j++)
  458. {
  459. write_data(r_fanwei[j]+0x30);
  460. delay_50us(1);
  461. }
  462. write_data('-');   //
  463. write_con(0x80+12+0x40);
  464. for(j=2;j<4;j++)
  465. {
  466. write_data(r_fanwei[j]+0x30);
  467. delay_50us(1);
  468. }
  469. write_data('%');
  470. if(temp_val.f<t_a||temp_val.f>t_b||humi_val.f<r_a||humi_val.f>r_b)
  471. beep = 0;
  472. else beep = 1;
  473. }
  474. }
ID:668762 发表于 2019-12-19 22:09 | 只看该作者
显示不完整是怎么回事
