查看: 1655|回复: 0
蓝牙与1602通信
ID:249463 发表于 2018-1-15 17:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
uint i;
uchar table[8]={0};
void delay(uint x)
        uchar i,j;
        for(i=x;i>0;i--)
                for(j=110;j>0;j--);
void init()
        TMOD = 0x20;                                           //֨ʱǷ٤ط׽ʽһ
        //SCON = 0x50;                                        //ԮࠚՊѭޓ˕˽ߝ
        TH1 = 0xfd;
        TL1 = 0xfd;
        TR1 = 1;
                SM0=0;
                SM1=1;
                EA=1;
void  send (uchar  dat)
        for(i=0;i<8;i++)
        table[i]=dat;
        if(dat==11)
        for(i=0;i<8;i++)
                ES=0;
                SBUF = table[i];
          while(!TI);
           TI = 0;
   ES=1;
/*4*4ߘֳݼƌP0ࠚìɨĨگ˽*/
void keyscan1()
        uchar temp,num;
        P3= 0xfe;        //1111 1110   ֚һПˤԶһٶ֍֧ƽ
        temp = P3;        //temp = 1111 1110
        temp = temp&0xf0;                                                         //1111 1110 & 1111 0000 = 1111 0000 =0xf0
       if(temp != 0xf0)                                         //ձԐдݼдЂìղP0ֵעʺلҤì
                delay(10);        //ғʱms
                temp = P3;
                temp = temp & 0xf0;
               if(temp != 0xf0)                                    //ՙՎȷɏˇرԐдݼдЂ
                        temp = P3;                                                   //ׁȡP0ࠚքֵ
        //ғʱ
                        switch(temp)                                                //޸ѐݼֵƐ׏
                                case 0xee:num =0;  break;
                                case 0xde:num =1;  break;
                                case 0xbe:num =2;  break;
                                case 0x7e:num =3;  break;
                while(temp != 0xf0)
                                temp = P3;
                                temp = temp&0xf0;
                                          send(num);
        P3 = 0xfd;                                                            // 1111 1101         ֚׾ПˤԶһٶ֍֧ƽ
        temp = P3;
        temp = temp&0xf0;
if(temp != 0xf0)
              delay(10);
        temp = P3;
        temp = temp&0xf0;
                if(temp != 0xf0)
                        temp = P3;
                        switch(temp)
                                case 0xed:num =4; break;
                                case 0xdd:num =5; break;
                                case 0xbd:num =6; break;
                                case 0x7d:num =7; break;
                while(temp != 0xf0)
                                        temp = P3;
                                        temp = temp&0xf0;
                                                 send(num);
        P3 = 0xfb;        // 1111 1011  ֚ɽПˤԶһٶ֍֧ƽ
        temp = P3;
        temp = temp&0xf0;
if(temp != 0xf0)
        delay(10);
        temp = P3;
        temp = temp&0xf0;
                if(temp != 0xf0)
                                        temp = P3;
                                switch(temp)
                                case 0xeb:num =8;  break;
                                case 0xdb:num =9;  break;
                                case 0xbb:num =10; break;
                                case 0x7b:num =11; break;
                while(temp != 0xf0)
                                temp = P3;
                                temp = temp&0xf0;
                                                 send(num);
/*׷گ˽*/
     init();                              //ַԃԮࠚԵʼۯگ˽
     keyscan1();           //ַԃߘֳݼƌɨĨگ˽
