查看: 2933|回复: 0
AT89S52单片机8按键8路舵机控制器源程序
ID:41770 发表于 2018-1-16 16:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. /*舵机控制程序
  2. 8路舵机控制器
  3. 芯片:AT89S52
  4. 晶振:12MHz
  5. ===================================================================================*/
  6. #include<config.h>
  7. #define uint8  unsigned char
  8. #define uint16 unsigned int
  9. sbit key1=P3^2;
  10. sbit key2=P3^3;
  11. //PWM的输出端口
  12. sbit PWM_OUT0=P5^4;    //key1,key2
  13. sbit PWM_OUT1=P5^5;
  14. sbit PWM_OUT2=P0^2;
  15. sbit PWM_OUT3=P0^3;
  16. sbit PWM_OUT4=P0^4;
  17. sbit PWM_OUT5=P0^5;
  18. sbit PWM_OUT6=P0^6;
  19. sbit PWM_OUT7=P0^7;
  20. //PWM的数据值
  21. uint16 PWM_Value[8]={1500,1000,1500,1000,1750,2000,2500,2000}; uint8 order1;  //定时器扫描序列
  22. /*===================================================================================
  23.     定时器T0的中断服务程序
  24.     一个循环20MS  = 8*2.5ms
  25. =====================================================================================*/
  26. void timer0(void) interrupt 1 using 1
  27. {
  28. switch(order1)
  29. {
  30. case 1:  PWM_OUT0=1;
  31.           TH0=-PWM_Value[0]/256;
  32.           TL0=-PWM_Value[0]%256;
  33.           break;
  34. case 2:  PWM_OUT0=0;
  35.           TH0=-(2700-PWM_Value[0])/256;
  36.           TL0=-(2700-PWM_Value[0])%256;
  37.           break;
  38. case 3:  PWM_OUT1=1;
  39.           TH0=-PWM_Value[1]/256;
  40.           TL0=-PWM_Value[1]%256;
  41.           break;
  42. case 4:  PWM_OUT1=0;
  43.           TH0=-(2700-PWM_Value[1])/256;
  44.           TL0=-(2700-PWM_Value[1])%256;
  45.           break;
  46. case 5:  PWM_OUT2=1;
  47.           TH0=-PWM_Value[2]/256;
  48.           TL0=-PWM_Value[2]%256;
  49.           break;
  50. case 6:  PWM_OUT2=0 ;
  51.           TH0=-(2700-PWM_Value[2])/256;
  52.           TL0=-(2700-PWM_Value[2])%256;
  53.           break;
  54. case 7:  PWM_OUT3=1;
  55.           TH0=-PWM_Value[3]/256;
  56.           TL0=-PWM_Value[3]%256;
  57.           break;
  58. case 8:  PWM_OUT3=0;
  59.           TH0=-(2700-PWM_Value[3])/256;
  60.           TL0=-(2700-PWM_Value[3])%256;
  61.           break;
  62. case 9:  PWM_OUT4=1;
  63.           TH0=-PWM_Value[4]/256;
  64.           TL0=-PWM_Value[4]%256;
  65.                    break;
  66. case 10: PWM_OUT4=0;
  67.           TH0=-(2700-PWM_Value[4])/256;
  68.           TL0=-(2700-PWM_Value[4])%256;
  69.           break;
  70. case 11: PWM_OUT5=1;
  71.           TH0=-PWM_Value[5]/256;
  72.           TL0=-PWM_Value[5]%256;
  73.           break;
  74. case 12: PWM_OUT5=0;
  75.           TH0=-(2700-PWM_Value[5])/256;
  76.           TL0=-(2700-PWM_Value[5])%256;
  77.           break;
  78. case 13: PWM_OUT6=1;
  79.           TH0=-PWM_Value[6]/256;
  80.           TL0=-PWM_Value[6]%256;
  81.           break;
  82. case 14: PWM_OUT6=0;
  83.           TH0=-(2700-PWM_Value[6])/256;
  84.           TL0=-(2700-PWM_Value[6])%256;
  85.           break;
  86. case 15: PWM_OUT7=1;
  87.           TH0=-PWM_Value[7]/256;
  88.           TL0=-PWM_Value[7]%256;
  89.           break;
  90. case 16: PWM_OUT7=0;
  91.           order1=0;
  92.           TH0=-(2700-PWM_Value[7])/256;
  93.           TL0=-(2700-PWM_Value[7])%256;
  94.           order1=0;
  95.           break;
  96.           default : order1=0;
  97.     }
  98.     order1++;
  99. }
  100. /*===================================================================================
  101. 初始化中断
  102. =====================================================================================*/
  103. void InitPWM(void)
  104. {
  105.    order1=1;
  106.    TMOD |=0x11;
  107.    TH0=-1500/256;    TL0=-1500%256;
  108.    EA=1;
  109.    EX0=0;
  110.    ET0=1; TR0=1;PT0=1;PX0=0;
  111. }
  112. void delay(void)
  113. {
  114.   uint16 i=100;
  115.   while(i--);
  116. }
  117. void main(void)
  118. {
  119. ……………………
  120. …………限于本文篇幅 余下代码请从51黑下载附件…………
ok_8按键8路舵机控制器.rar (63.79 KB, 下载次数: 34)
收藏收藏1 分享淘帖 顶 踩
