查看: 4768|回复: 7
求助。怎么用STC12C5A60S2的蜂鸣器放音乐
ID:278182 发表于 2018-1-21 22:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助各位大神,怎么用STC12C5A60S2的蜂鸣器放音乐啊,虽然有学过C语言,但是看到好多类似的单片机程序还是一脸蒙蔽。。。头一次接触单片机。谢谢各位大神了
ID:210244 发表于 2018-1-21 23:29 | 只看该作者
通过控制蜂鸣器的开关时间来生成调子,网上有很多蜂鸣器的曲谱,改改用就好了
ID:278453 发表于 2018-1-22 01:05 | 只看该作者
从网上直接搜索例程,现在这种做蜂鸣器的很简单
ID:164602 发表于 2018-1-22 08:32 | 只看该作者
给你一个例程看看。
本实例利用无源蜂鸣器发出音乐声音。
还用到了定时计数器0
#include <reg51.h>
sbit voice=P1^5;//蜂鸣器接口
uchar code sound[]={0xff,
0x30,0x10,0x2b,0x10,0x26,0x80,0xff,0x40,0x30,0x20,0x30,0x10,0x39,0x10,
0x40,0x80,0xff,0x40,0xff,0x20,0x40,0x20,0x26,0x20,0x26,0x10,0x2b,0x10,
0x2b,0x40,0xff,0x20,0x40,0x20,0x26,0x20,0x2b,0x20,0x2b,0x80,0xff,0x40,
0xff,0x10,0x40,0x10,0x40,0x10,0x40,0x10,0x1c,0x20,0x20,0x20,0x1c,0x20,
0x26,0x20,0x26,0x20,0xff,0x20,0x2b,0x30,0x30,0x10,0x26,0x10,0x2b,0x60,
0xff,0x20,0x39,0x20,0x30,0x20,0x39,0x20,0x30,0x40,0xff,0x20,0xff,0x20,
0xff,0x20,0x39,0x10,0x39,0x10,0x2b,0x20,0x2b,0x20,0x30,0x40,0xff,0x40,
0x26,0x80,0xff,0x20,0x2b,0x20,0x30,0x20,0x30,0x10,0x39,0x10,0x40,0x80,
0xff,0x40,0xff,0x20,0x40,0x10,0x40,0x10,0x1c,0x20,0x20,0x60,0xff,0x20,
0x30,0x20,0x2b,0x20,0x26,0x10,0x2b,0x10,0x2b,0x80,0xff,0x40,0xff,0x20,
0x40,0x10,0x40,0x10,0x39,0x20,0x40,0x20,0x1c,0x30,0x20,0x10,0xff,0x20,
0x1c,0x20,0x20,0x20,0x1c,0x20,0x26,0x80,0xff,0x30,0x2b,0x10,0x2b,0x20,
0x30,0x10,0x26,0x20,0x2b,0x60,0xff,0x40,0x39,0x20,0x30,0x20,0x30,0x80,
0xff,0x40,0xff,0x40,0x40,0x20,0x39,0x20,0x30,0x20,0x2b,0x20,0x26,0x20,
0x1c,0x20,0x20,0x40,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x1c,0x10,0x20,0x10,
0x20,0x20,0x20,0x10,0x26,0x10,0x26,0x40,0x26,0x20,0x26,0x20,0x26,0x20,
0x26,0x10,0x2b,0x10,0x2b,0x20,0x30,0x10,0x33,0x10,0x39,0x40,0x30,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x40,0x10,0x40,0x80,0x40,0x20,0x39,0x20,
0x30,0x20,0x2b,0x20,0x26,0x20,0x1c,0x20,0x20,0x40,0x1c,0x20,0x1c,0x20,
0x1c,0x20,0x1c,0x10,0x20,0x10,0x20,0x20,0x20,0x10,0x26,0x10,0x26,0x40,
0x26,0x20,0x26,0x20,0x26,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x10,
0x30,0x10,0x39,0x40,0x2b,0x20,0x2b,0x20,0x2b,0x20,0x2b,0x10,0x30,0x10,
0x30,0x80,0x00};
uchar zdjs=0, jp;
void del(yj);
void main(void)
        uint dpjs=0;
        uchar yj;
        TMOD=0x01;
        IE=0x82;
        TL0=0xf0;
        TR0=1;
                zdjs=0;
                dpjs++; yj=sound[dpjs];
                dpjs++; jp=sound[dpjs];
                while(zdjs!=jp)
                        if(yj!=0xff)
                                if(yj!=0)
                                        voice=!voice;
                                        del(yj);
                                        dpjs=0;
                                        break;
                                voice=1;
                                del(jp);
void time0() interrupt 1
        TH0=0xd8;
        TL0=0xf0;
        zdjs++;
void del(yj)
        uchar yj2=2;
        while(yj!=0)
                while(yj2!=0)
                        yj2--;
                        yj2=2;
                        yj--;
ID:123289 发表于 2018-1-22 13:06 | 只看该作者
先读通单片机原理,C语言再好只是语言好,与懂不懂单片机无关!
ID:267935 发表于 2018-1-22 15:01 | 只看该作者
利用IO口输出PWM波来驱动三极管,从而驱动蜂鸣器,曲子的话,网上都能百度到的
ID:278182 发表于 2018-1-22 21:53 | 只看该作者
谢谢各位,太感谢了
ID:247467 发表于 2018-1-23 08:50 | 只看该作者
找到你需要的曲谱在稍微修改,在单片机中运行看看看看效果咋样。
