查看: 1976|回复: 1
这是我做的单片机设计代码,实现密码锁功能
ID:278453 发表于 2018-1-22 01:09 | 显示全部楼层 |阅读模式
#include <REG51.h>
#include<intrins.h>
//宏定义
#define LCM_Data  P0                  //将P0口定义为LCM_Data
#define uint  unsigned int
#define w 6                                //定义密码位数
//1602的控制脚
sbit lcd1602_rs=P2^7;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^5;
sbit Scl=P3^4;                        //24C02串行时钟
sbit Sda=P3^5;                        //24C02串行数据
sbit ALAM = P2^1;                //报警
sbit KEY = P3^6;                //开锁
sbit open_led=P2^2;                //开锁指示灯(选配)
bit  operation=0;                //操作标志位
bit  pass=0;                        //密码正确标志
bit  ReInputEn=0;                //重置输入允许标志
bit  s3_keydown=0;                //3秒按键标志位
bit  key_disable=0;                //锁定键盘标志
unsigned char countt0,second;        //t0中断计数器,秒计数器
void Delay5Ms(void);                //声明延时函数
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盘扫描控制表
//液晶显示数据数组
unsigned char code start_line[]        = {"password:       "};
unsigned char code name[]                  = { "===Coded Lock==="};        //显示名称
unsigned char code Correct[]         = {"     correct    "};                //输入正确
unsigned char code Error[]           = {"      error     "};          //输入错误
unsigned char code codepass[]        = {"      pass      "};
unsigned char code LockOpen[]        = {"      open      "};                //OPEN
unsigned char code SetNew[]         = {"SetNewWordEnable"};
unsigned char code Input[]           = {"input:          "};                //INPUT
unsigned char code ResetOK[]         = {"ResetPasswordOK "};
unsigned char code initword[]        = {"Init password..."};
unsigned char code Er_try[]                = {"error,try again!"};
unsigned char code again[]                = {"input again     "};
unsigned char InputData[6];        //输入密码暂存区
unsigned char CurrentPassword[6]={1,3,1,4,2,0};                         //管理员密码(只可在程序中修改)
unsigned char TempPassword[6];
unsigned char N=0;                                //密码输入位数记数
unsigned char ErrorCont;                        //错误次数计数
unsigned char CorrectCont;                        //正确输入计数
unsigned char ReInputCont;                         //重新输入计数
unsigned char code initpassword[6]={0,0,0,0,0,0};                        //输入管理员密码后将密码初始为000000
//=====================5ms延时==============================
void Delay5Ms(void)
        unsigned int TempCyc = 5552;
        while(TempCyc--);
//===================400ms延时==============================
void Delay400Ms(void)
unsigned char TempCycA = 5;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
//================================24C02========================================================
void mDelay(uint t) //延时
        uchar i;
           while(t--)
                   for(i=0;i<125;i++)
void Nop(void)                  //空操作
         _nop_();                  //仅作延时用一条语句大约1us
         _nop_();
        _nop_();
/*****24c02程序参照24c02时序图*****/
/*起始条件*/
void Start(void)
        Scl=1;
         Nop();
         Sda=0;
         Nop();
/*停止条件*/
void Stop(void)
         Sda=0;
         Scl=1;
         Nop();
         Sda=1;
         Nop();
/*应答位*/
void Ack(void)
        Sda=0;
        Nop();
        Scl=1;
        Nop();
        Scl=0;
/*反向应答位*/
void NoAck(void)
         Sda=1;
         Nop();
         Scl=1;
         Nop();
         Scl=0;
/*发送数据子程序,Data为要求发送的数据*/
void Send(uchar Data)
           uchar BitCounter=8;
           uchar temp;
           do
                   temp=Data;                                           //将待发送数据暂存temp
                   Scl=0;
                   Nop();
                   if((temp&0x80)==0x80)                   //将读到的数据&0x80
                   Sda=1;
                   Sda=0;
                   Scl=1;
                   temp=Data<<1;                                   //数据左移
                   Data=temp;                                           //数据左移后重新赋值Data
                   BitCounter--;                                   //该变量减到0时,数据也就传送完成了
           while(BitCounter);                                   //判断是否传送完成
           Scl=0;
/*读一字节的数据,并返回该字节值*/
uchar Read(void)
    uchar temp=0;
        uchar temp1=0;
        uchar BitCounter=8;
        Sda=1;
        do
                Scl=0;
                Nop();
                Scl=1;
                Nop();
                if(Sda)                                   //数据位是否为1
                        temp=temp|0x01;           //为1 temp的最低位为1(|0x01,就是将最低位变为1)
                else                                   //如果为0
                        temp=temp&0xfe;           //temp最低位为0(&0xfe(11111110)最低位就是0)
                if(BitCounter-1)           //BitCounter减1后是否为真
                        temp1=temp<<1;           //temp左移
                        temp=temp1;
                BitCounter--;                   //BitCounter减到0时,数据就接收完了
        while(BitCounter);                   //判断是否接收完成
        return(temp);
大家可以试一试
