查看: 3790|回复: 0
基于8051的8位共阴数码管显示24小时时钟的时钟序程
#include<reg52.h>
sbit W_lock=P3^6;
sbit S_lock=P3^7;
sbit key1=P1^0;
sbit key2=P1^1;
uchar key_pr1,key_pr2,key_flag;
uchar flag,sec,min,hr;
uchar code table_s[]={0x3f,0x06,0x5b,0x4f,0x66,
                                          0x6d,0x7d,0x07,0x7f,0x6f,0x40};
uchar code table_w[]={0xfe,0xfd,0xf7,0xef,0xbf,0x7f,0xfb,0xdf};
uchar tab[8]={0,0,0,0,0,0,10,10};
void Delay(uint time);
void Deel_date();
void display();
void key_scan();          //键盘扫描
        TMOD=0x11;                   //定时器0以工作方式1工作
        EA=1;                           //开启总中断
        ET0=1;                           //开定时器0中断
        TR0=1;                       //开启定时器0
        ET1=1;                            //开启定时器1中断
        TR1=1;                                 //开启定时器1
        TH0=(65536-46086)/256;          //定时器0的中断服务程序
        TL0=(65536-46083)%256;
        TH1=(65536-2000)/256;          //定时器1的中断服务程序
        TL1=(65536-2000)%256;
                key_scan();
                Deel_date();
                if(flag>=20)
                        flag=0;                           // 按键按下的标志
                        sec++;
                        if(60==sec)
                                sec=0;
                                min++;
                                if(60==min)
                                        min=0;
                                        hr++;
                                        if(24==hr)
                                                hr=0;
void Deel_date()
        tab[4]=sec/10;
        tab[5]=sec%10;
        tab[2]=min/10;
        tab[3]=min%10;
        tab[0]=hr/10;
        tab[1]=hr%10;
void display()
        static i;
        P0=table_w[i];
        W_lock=1;
        W_lock=0;
        P0=table_s[tab[i]];
        S_lock=1;
        S_lock=0;
        i++;
        if(8==i)
                i=0;
        uint x,y;
        for(x=125;x>0;x--)
                for(y=time;y>0;y--);
void key_scan()
        if(0==key1)
                Delay(5);
                if(0==key1)
                        key_pr1=1;
        if((1==key1)&&(1==key_pr1))
                key_pr1=0;
                key_flag++;
                TR0=0;
        if(4==key_flag)
                key_flag=0;
                TR0=1;
        if(0==key2)
                Delay(5);
                if(0==key2)
                        key_pr2=1;
        if((1==key2)&&(1==key_pr2))
                key_pr2=0;
                if(key_flag==1)
                        sec++;
                        if(sec==60)
                                sec=0;
                if(key_flag==2)
                        min++;
                        if(min==60)
                                min=0;
                if(key_flag==3)
                        hr++;
                        if(hr==24)
                                hr=0;
void  Timer_0() interrupt 1
        flag++;
void  Timer_1() interrupt 3
        display();
