查看: 2840|回复: 0
MIC8055引脚图与datasheet下载
MIC8055芯片,扩展51管脚
MIC8055引脚图:
功能框图:
GENERAL  DESCRIPTION
The MSM81C55-5 has a 2k-bit static RAM (256 bytes) with parallel I/O ports and a timer.  It uses silicon gate CMOS technology and consumes a standby current of 100 micro ampere, maximum,while the chip is not selected.  Featureing a maximum access time of 400 ns, the MSM81C55-5
can  be used in an MSM80C85AH system without using wait states.  The parallel I/O consists of two 8-bit ports and one 6-bit port (both general purpose).
The MSM81C55-5 also contains a 14-bit programmable counter/timer which may be used for sequence-wave generation or terminal count-pulsing.
pdf格式的datasheet下载:
MSM81C55-5_datasheet.pdf (157.34 KB, 下载次数: 4)
