查看: 6447|回复: 0
使用hc595驱动双色点阵两处代码没看懂,请指教!!!
ID:27702 发表于 2011-1-9 18:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
51学习板中双色点阵有如下代码: /*------------------------------------------------ 发送字节程序 ------------------------------------------------*/ void SendByte(unsigned char dat) { unsigned char i; for(i=0;i<8;i++) { srclk="0; " ser="dat&0x80; " dat<<=1; srclk="1; " } } /*------------------------------------------------ 发送双字节程序 595级联,n个595,就需要发送n字节后锁存 ------------------------------------------------*/ void Send2Byte(unsigned char="char" dat1,unsigned char="char" dat2) { SendByte(dat1); SendByte(dat2); } ------------------------------------------------------------------------------------------------------------------------------- 为什么这里的dat1和dat2参数会分别控制两种颜色?是什么工作原理? -------------------------------------------------------------------------------------------------------------------------------- Send2Byte(~tab,0xff); Out595(); DelayMs(1); Send2Byte(0xff,0xff);//delay(10); //防止重影 Out595(); ------------------------------------------------------------------------------------------------------------------------------- 如果不执行Send2Byte(0xff,0xff);为什么会产生重影? ------------------------------------------------------------------------------------------------------------------------------- 初学者,请高手指教!!! [upload=c,双色点阵2种颜色测试.c]viewFile.asp?ID=781[/upload]
