查看: 8687|回复: 3
[求助]谁能帮我编写个时钟的程序啊
ID:2567 发表于 2008-6-6 05:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
要求:1.能显示时间和日期,而且是交替显示
        2.带蜂鸣器的,每隔10分钟想下
ID:7 发表于 2008-6-9 19:15 | 只看该作者
上学期写的一个时钟程序
可能很多可以优化的
不过你可以参考一下
#include<reg51.h>
unsigned char shows1[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char shows2[10]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
unsigned char i,j,num,temp;
unsigned int hour,minute,second,tens,units,second1,minute1,hour1;
void delay(unsigned int n)
 for(i=n;i>0;i--)
  for(j=0;j<110;j++);
void showtime(int x)
 tens=x/10;
 units=x%10;
void debughour()
 if(P3==0xbf)
  delay(1);
  while(P3==0xbf);
  hour++;
  if(hour==24)
   hour=0;
  showtime(hour);
  P0=shows1[tens];
  P2=0x01;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x02;
  delay(1);
  P2=0x00;
 if(P3==0xdf)
  delay(1);
  while(P3==0xdf);
  hour--;
  if(hour==-1)
   hour=23;
  showtime(hour);
  P0=shows1[tens];
  P2=0x01;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x02;
  delay(1);
  P2=0x00;
 if(P3==0x7f)
  delay(1);
  while(P3==0x7f);
  temp++;
void debugminute()
 if(P3==0xbf)
  delay(1);
  while(P3==0xbf);
  minute++;
  if(minute==60)
   minute=0;
  showtime(minute);
  P0=shows1[tens];
  P2=0x04;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x08;
  delay(1);
  P2=0x00;
 if(P3==0xdf)
  delay(1);
  while(P3==0xdf);
  minute--;
  if(minute==-1)
   minute=59;
  showtime(minute);
  P0=shows1[tens];
  P2=0x04;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x08;
  delay(1);
  P2=0x00;
 if(P3==0x7f)
  delay(1);
  while(P3==0x7f);
  temp++;
void keyscan1()
 while(temp<=2)
  if(P3==0x7f)
   delay(1);
   while(P3==0x7f);
   temp++;
  TR0=0;
  showtime(second);
  P0=shows1[tens];
  P2=0x10;
  delay(1);
  P2=0x00;
  P0=shows1[units];
  P2=0x20;
  delay(1);
  P2=0x00;
  showtime(minute);
  P0=shows1[tens];
  P2=0x04;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x08;
  delay(1);
  P2=0x00;
  showtime(hour);
  P0=shows1[tens];
  P2=0x01;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x02;
  delay(1);
  P2=0x00;
  if(temp==1)
   debughour();
  if(temp==2)
    debugminute();
  if(temp==3)
   TR0=1;
   temp=0;
   break;
void keyscan2()
 while(temp<=1)
  if(P3==0xef)
   delay(1);
   while(P3==0xef);
   temp++;
  if(num==18)
    num=0;
   P1=~P1;
   second1++;
   if(second1==60)
    second1=0;
    minute1++;
    if(minute1==60)
     minute1=0;
     hour1++;
     if(hour1==100)
      hour1=0;
   second++;
   if(second==60)
    second=0;
    minute++;
    if(minute==60)
     minute=0;
     hour++;
     if(hour==24)
      hour=0;
  showtime(second1);
  P0=shows1[tens];
  P2=0x10;
  delay(1);
  P2=0x00;
  P0=shows1[units];
  P2=0x20;
  delay(1);
  P2=0x00;
  showtime(minute1);
  P0=shows1[tens];
  P2=0x04;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x08;
  delay(1);
  P2=0x00;
  showtime(hour1);
  P0=shows1[tens];
  P2=0x01;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x02;
  delay(1);
  P2=0x00;
  if(temp==2)
   temp=0;
   hour1=0;
   minute1=0;
   second1=0;
   break;
void runtime()
  if(num==18)
   num=0;
  P1=~P1;
  second++;
  if(second==60)
   second=0;
   minute++;
   if(minute==60)
    minute=0;
    hour++;
    if(hour==24)
     hour=0;
main()
 TMOD=0x01;
 TH0=(65536-50000)/256;
 TL0=(65536-50000)%256;
 EA=1;
 ET0=1;
 TR0=1;
 P3=0xff;
 temp=0;
 hour=3;
 minute=58;
  runtime();
  showtime(second);
  P0=shows1[tens];
  P2=0x10;
  delay(1);
  P2=0x00;
  P0=shows1[units];
  P2=0x20;
  delay(1);
  P2=0x00;
  showtime(minute);
  P0=shows1[tens];
  P2=0x04;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x08;
  delay(1);
  P2=0x00;
  showtime(hour);
  P0=shows1[tens];
  P2=0x01;
  delay(1);
  P2=0x00;
  P0=shows2[units];
  P2=0x02;
  delay(1);
  P2=0x00;
  if(P3==0x7f)
   keyscan1();
  if(P3==0xef)
   keyscan2();
void timer0() interrupt 1 using 1
 num++;
ID:55629 发表于 2013-10-5 22:34 | 只看该作者
#include<reg52.h> #define uchar unsigned char #define uint unsigned int uchar code table[]=" 2013-09-23 MON";                          //设定开始显示的时间 uchar code table1[]="    00:00:01"; uchar code table2[7][3]= {{"MON"},{"TUE"},{"WED"},{"THU"},{"FRI"},{"SAT"},{"SUN"}};          //定义二维字符数组 sbit wr=P1^1;                                   //           1602液晶的读/写端 sbit lcden=P1^2;                           //           1602液晶使能端 sbit lcdrs=P1^0;                           //                1602液晶命令/数据端    sbit key1=P3^2;                                   //                声明s1按键时间调整 sbit key2=P3^3;                                          //         声明s2按键+1 sbit key3=P3^4;                                          //         声明s3按键-1 sbit key4=P3^5;                                          //         声明s4按键闹钟调整 sbit beep=P1^4;                                          //         声明蜂鸣器 uchar num1,shi=00,fen=00,miao=01,yue=9,ri=23,shi1,fen1,miao1,keynum1,week;                                //定义时分秒变量 uint nian=2013;                                                   //定义年变量 void delayms(uint x)                                                 {         uint i,j;         for(i=x;i>0;i--)                                           //定义带参数延时函数                 for(j=110;j>0;j--); }         void write_com(uchar com)                                 //1602液晶写指令函数         {        wr=0;                 lcdrs=0;                 P0=com;                 delayms(1);                 lcden=1;                 delayms(1);               lcden=0;                                  }         void write_date(uchar date)                                                   //1602液晶写数据函数         {           wr=0;                 lcdrs=1;                 P0=date;                 delayms(1);                 lcden=1;                 delayms(1);                 lcden=0;                          }                                                  void write_addate1(uchar add,uint date)                                //定义显示年的函数                 {                uint qian;                         uchar bai,shi,ge;                         qian=date/1000;                         bai=date%1000/100;                         shi=date%1000%100/10;                         ge=date%10;                         write_com(add+0x80);                         write_date(0x30+qian);                         write_date(0x30+bai);                         write_date(0x30+shi);                         write_date(0x30+ge);                 }                         void write_addate2(uchar add,uchar date)                                //定义显示月、日、时、分、秒函数                 {                         uchar shi,ge;                         shi=date/10;                         ge=date%10;                         write_com(add+0x80);                         write_date(0x30+shi);                         write_date(0x30+ge);                 }                 void write_rq(uchar i)        //定义显示星期的函数                 {         uchar x;                         for(x=0;x<3;x++)                                 {        write_date(table2[i][x]);                                         delayms(1);                                 }                         }        void init ()        //定义初始化函数                 {        TMOD=0x01;        //          定时器0工作方式为11.0592M晶振 16位                         TH0=(65536-45566)/256;                                                          //   装初值                         TL0=(65536-45566)%256;                         EA=1;        //          开总中断                         ET0=1;        //        开定时器0中断                         write_com(0x38);        // 设置16*2显示,5*7点阵,8位数据口                         write_com(0x06);        // 写一个字符后地址指针加1                         write_com(0x0c);        //        设置开显示,不显示光标                         write_com(0x01);        //           显示清0,数据清0                         write_com(0x80);        //   使指针指向第1行第1列                 }                 void keyscan()        // 定义按键函数                 {                                 uchar keynum;                         if(key1==0)                           //s1按键被按下                                 {        delayms(3);                                 //去抖延时                                         if(key1==0)                                   //确认s4按键被按下,进入调时间模式                                                 {                                                         keynum++;                                                         while(!key1);                            //松手检测                                                 }                                         if(keynum==1)                                                 //s1按下一次                                          {        TR0=0;                                                         //关闭定时器0                                                 write_com(0x81);                                  //指针指向第1行2列                                                  write_com(0x0f);                                   //开启光标显示,光标闪烁                                         }                                         if(keynum==2)        {                                                 write_com(0x86);                                         //光标跳到月份                                         }                                         if(keynum==3)        {        write_com(0x89);                                        //光标跳到日                                            }                                          if(keynum==4)                                          {                                                  write_com(0x8c);                                         //光标跳到星期                                       }                                           if(keynum==5)                                          {                                                  write_com(0xc4);                                         //光标跳到时                                       }                                          if(keynum==6)                                          {                                            write_com(0xc7);                                                 //光标跳到分                                          }                                          if(keynum==7)                                          {                                                  write_com(0xca);                                         //光标跳到秒                                       }                                        if(keynum==8)                                          {        keynum=0;                                                           //退出调时间模式                                                  TR0=1;        //开启定时器0                                                  write_com(0x0c);                                            //关闭光标显示                                       }                                   }                                            if(keynum)        //当进入调时间模式时                                            {                                                    if(key2==0)                                                          //s2按键按下                                                  {                                                          delayms(3);                                                           //去抖延时                                                         if(key2==0)                                                         {        if(keynum==1)        {        nian++;                                          //s2每按下一次年份加1        if(nian==10000)                          //  加满清0        nian=0;        write_addate1(1,nian);         //         显示年份        write_com(0x81);                 //写完数据指针指向年份原来位置        }        if(keynum==2)        {        yue++;                                 //s2每按下一次月份加1        if(yue==13)        yue=0;                                   //加满清0        write_addate2(6,yue);          //显示月份        write_com(0x86);                  //写完数据指针指向月份原来位置        }        if(keynum==3)        {        ri++;        if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12)   //1,3,5,7,8,10,12月有31天        if(ri==32)                                                            //加满还原        ri=1;        if(yue==4||yue==6||yue==9||yue==11)                //4,6,9,11月有30天        if(ri==31)        ri=1;        if(yue==2&&((nian%4==0&&nian%100!=0)||nian%400==0))                //闰年2月有30天        if(ri==30)        ri=1;        if(yue==2&&(nian%4!=0)||(nian%100==0&&nian%400!=0))           //非闰年2月有31天        if(ri==29)        ri=1;        write_addate2(9,ri);                   //显示日        write_com(0x89);                           //写完数据指针指向日原来位置        }        if(keynum==4)        {        week++;                                                   //s2每按下一次星期加1        if(week==7)                                                    //加满还原        week=0;        write_rq(week);                                    //显示星期        write_com(0x8c);                                    //写完数据指针指向星期原来位置        }        if(keynum==5)        {        shi++;                                          //s2每按下一次时加1        if(shi==24)        shi=0;                                           //加满还原        write_addate2(0x44,shi);   //显示时        write_com(0xc4);                   //写完数据指针指向时原来位置        }        if(keynum==6)        {        fen++;                                         //s2每按下一次分加1        if(fen==60)        fen=0;                                          //加满还原        write_addate2(0x47,fen);  //显示分        write_com(0xc7);                  //写完数据指针指向分原来位置        }        if(keynum==7)        {        miao++;                                                   //s2每按下一次秒加1        if(miao==60)        miao=0;                                                         //加满还原        write_addate2(0x4a,miao);           //显示秒        write_com(0xca);                          //写完数据指针指向秒原来位置        }        while(!key2);                                                         //松手检测                                                          }                                                            }        if(key3==0)        {        delayms(3);                                                         if(key3==0)        {        //s3按下时减1        if(keynum==1)        {        nian--;        if(nian==-1)        nian=9999;        write_addate1(1,nian);        write_com(0x81);        }        if(keynum==2)        {        yue--;        if(yue==-1)        yue=12;        write_addate2(6,yue);        write_com(0x86);        }        if(keynum==3)        {        ri--;        if(ri==0)        {        if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12)        ri=31;        if(yue==4||yue==6||yue==9||yue==11)        ri=30;        if(yue==2&&((nian%4==0&&nian%100!=0)||nian%400==0))        ri=29;        if(yue==2&&(nian%4!=0)||(nian%100==0&&nian%400!=0))        ri=28;        }        write_addate2(9,ri);        write_com(0x89);        }        if(keynum==4)        {        week--;        if(week==-1)        week=6;        write_rq(week);        write_com(0x8c);        }        if(keynum==5)        {        shi--;        if(shi==-1)        shi=23;        write_addate2(0x44,shi);        write_com(0xc4);        }        if(keynum==6)        {        fen--;        if(fen==-1)        fen=59;        write_addate2(0x47,fen);        write_com(0xc7);        }        if(keynum==7)        {        miao--;        if(miao==-1)        miao=59;        write_addate2(0x4a,miao);        write_com(0xca);        }        while(!key3);                                                           //松手检测                                                          }                                 }        }        if(key4==0)                                                          //s4被按下进入调闹钟模式        {  delayms(3);        if(key4==0)        {        keynum1++;        while(!key4);        }        if(keynum1==1)        {        write_com(0x01);                //清屏,指针清0        write_com(0xc6);                //在时分之间显示“:”        write_date(':');        write_com(0xc9);                        //在分秒之间显示“:”        write_date(':');        write_com(0x0f);                 //开启光标        write_com(0xc4);                 //光标指向时        }        if(keynum1==2)        {        write_com(0xc7);                                  //光标指向分        }        if(keynum1==3)        {        write_com(0xca);                          //光标指向秒        }        if(keynum1==4)        {        keynum1=0;        write_com(0x0c);                  //关闭光标        }        }        if(keynum1)        {        if(key2==0)                                          //s2按下加1        {        delayms(3);        if(key2==0)        {        if(keynum1==1)        {        shi1++;        if(shi1==24)        shi1=0;        write_addate2(0x44,shi1);        write_com(0xc4);        }        if(keynum1==2)        {        fen1++;        if(fen1==60)        fen1=0;        write_addate2(0x47,fen1);        write_com(0xc7);        }        if(keynum1==3)        {        miao1++;        if(miao1==60)        miao1=0;        write_addate2(0x4a,miao1);        write_com(0xca);        }        while(!key2);        }        }        if(key3==0)                          //s3每按一次减1        {        delayms(3);        if(key3==0)        {        if(keynum1==1)        {        shi1--;        if(shi1==-1)        shi1=23;        write_addate2(0x44,shi1);        write_com(0xc4);        }        if(keynum1==2)        {        fen1--;        if(fen1==-1)        fen1=59;        write_addate2(0x47,fen1);        write_com(0xc7);        }        if(keynum1==3)        {        miao1--;        if(miao1==-1)        miao1=59;        write_addate2(0x4a,miao1);        write_com(0xca);        }        while(!key3);                                                //松手检测        }        }        }                           }        void main()                                                    {                uchar num;                                 init();                                 for(num=0;num<15;num++)                                 { write_date(table[num]);                                         delayms(5);                                 }        //显示初始时间                                 write_com(0xc0);                                 for(num=0;num<12;num++)                                 { write_date(table1[num]);                                         delayms(5);                                 }                                           TR0=1;        //开启定时器0                         while(1)                         {                                    if(shi==shi1&&fen==fen1&&miao==miao1)                                   //闹钟到了蜂鸣器响                                         beep=0;                  if(shi==shi1&&fen==fen1&&miao==miao1+30)                                   //闹钟到了蜂鸣器响                                         beep=1;                                                         keyscan();                                 //扫描键盘                         }        }                                       void time() interrupt  1                                 //中断函数                    {                            TH0=(65536-45566)/256;                                 TL0=(65536-45566)%256;                         //进入中断装初值                                 num1++;                                 if(num1==20)                                           //一秒到了                                         { num1=0;                                           //清0                                           miao++;                                           if(miao==60)                                         //一分到了                                                    { miao=0;        fen++;        }                                                   if(!keynum1)        write_addate2(0x4a,miao);                   //当调闹钟模式按下时不显示当前时间                                                         if(fen==60)                                                         { fen=0;                                                            shi++;                                                         }                                                           if(!keynum1)         write_addate2(0x47,fen);           //当调闹钟模式按下时不显示当前时间        if(shi==24)        {        shi=0;        ri++;        week++;        }        if(!keynum1)         write_addate2(0x44,shi);           //当调闹钟模式按下时不显示当前时间        if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12)        if(ri==32)        {        ri=1;        yue++;        }        if(yue==4||yue==6||yue==9||yue==11)        if(ri==31)        {        ri=1;         yue++; }        if(yue==2&&((nian%4==0&&nian%100!=0)||nian%400==0))        if(ri==30)        {        ri=1;          yue++;        }        if(yue==2&&(nian%4!=0)||(nian%100==0&&nian%400!=0))        if(ri==29)        {        ri=1;          yue++;        }        if(!keynum1)                          write_addate2(9,ri);                     //当调闹钟模式按下时不显示当前时间        if(week==7)        week=0;        if(!keynum1)                                                     //当调闹钟模式按下时不显示当前时间        {        write_com(0x8c);        write_rq(week);        }        if(yue==13)        {        yue=0;        nian++;        }        if(!keynum1)                                                            //当调闹钟模式按下时不显示当前时间        {        write_addate2(6,yue);        write_com(0x88);        write_date('-');        }        if(nian==10000)        nian=0;        if(!keynum1)        {        write_addate1(1,nian);                                   //当调闹钟模式按下时不显示当前时间        write_com(0x85);        write_date('-');        }        }                                                         }
ID:52286 发表于 2013-10-13 23:47 | 只看该作者
支持支持!!
