查看: 4947|回复: 0
STM32 HALL驱动
ID:282777 发表于 2018-2-7 10:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
两种方案:第一种就时STM32每个IO口都用按键中断,你可以牺牲一个定时器,当一个中断过来就计数,等待下一个中断进来后两者的差就得出了一个与速度相关的值,说句实话编码器没用过,我用的是HALL接口。这种方法是比较简单的,
第二种方法就是楼主所说的,定时器里面有hall接口,同时可以捕获定时器的值,还是以HALL为例,配置好后会每60度(电角度)进入中断一次,同事进入后捕获开始,也就是定时器开始计数。计数出来的值就是电机转过60度的时间(电角度)。配置我会截图给你,其实还可以计数跑了多少个PWM周期。在PWM中断里计数。通常他们是这莫做的,应为在FOC中可以简化运算。不知道你的编码器是咋样回事了,但是都应该通用的。
配置如下:
  //GPIO
  GPIO_InitTypeDef  GPIO_InitStructure;
  //Interrupt
  NVIC_InitTypeDef NVIC_InitStructure;
  //Tmer
  TIM_BDTRInitTypeDef  TIM_BDTRInitStructure;           //死区刹车结构体变量定义
  TIM_OCInitTypeDef TIM_OCInitStructure;
  TIM_ICInitTypeDef TIM_ICInitStructure;           //定义结构体变量
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  //---------------------------------TMER3 HALL------------------------------
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_0);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_0);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_0);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  TIM_DeInit(TIM3);
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_OCStructInit(&TIM_OCInitStructure);
  TIM_TimeBaseStructure.TIM_Prescaler = 47;        //TIM基本初始化
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period =65535;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;            //选择通道1
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //输入上升沿捕获
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_TRC ; //配置通道为输入,并映射到哪里
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;       //输入捕获预分频值
  TIM_ICInitStructure.TIM_ICFilter = 10;                      //输入滤波器带宽设置
  TIM_ICInit(TIM3, &TIM_ICInitStructure);                     //输入通道配置
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;         //TIM输出通道初始化
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;
  TIM_OCInitStructure.TIM_Pulse =65535;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC4Init(TIM3,&TIM_OCInitStructure);
  TIM_SelectHallSensor(TIM3,ENABLE);                          //使能TIMx的霍尔传感器接口
  TIM_SelectInputTrigger(TIM3, TIM_TS_TI1F_ED);               //输入触发源选择
  TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Reset);             //从模式选择
  TIM_SelectMasterSlaveMode(TIM3, TIM_MasterSlaveMode_Enable);//主从模式选择
  //        TIM_SelectOutputTrigger(TIM3, TIM_TRGOSource_OC2Ref );//选择输出触发模式(TRGO端)
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;              //开TIM3中断
  NVIC_InitStructure.NVIC_IRQChannelPriority = 2;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  TIM_ITConfig(TIM3, TIM_IT_Trigger|TIM_IT_CC4, ENABLE);   //开定时器中断
  TIM_ClearFlag(TIM3, TIM_FLAG_Trigger);
  TIM_ClearFlag(TIM3, TIM_FLAG_CC4);
  TIM_Cmd(TIM3,ENABLE);
//中断入口。
void TIM3_IRQHandler(void)
  if((TIM_GetFlagStatus(TIM3,TIM_FLAG_Trigger)) != RESET )
    TIM_ClearITPendingBit(TIM3, TIM_FLAG_Trigger);
    HallPLLCtrl();
