查看: 4221|回复: 8
51单片机STC15L100串口通信外部中断3
STC15L100的芯片与ZGB相连,做一个简单的串口发送数据,发送规定的数据,外部中断3进行控制,来一个外部中断,发送一次数据程序,下板之后,下板成功,链接串口助手,按下中断,第一组DATA数据正确,延时后,发送DATA2的数据,DATA2的数据变成了每一个数都延时一次,在发出下一个数,DATA2应该不延时,求大神看看程序,11.0592MHZ的内部晶振,9600波特率。
  1. #include <reg51.h>
  2. char  code DATA[19]={0x02, 0x6c, 0x62, 0x03, 0x03, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00,  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc1};        //显靶
  3. char  code DATA2[19]={0x03, 0x6c, 0x62, 0x03, 0x03, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00,  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc1};        //影靶
  4. //char *ch;
  5. unsigned char i,j;
  6. //-----------------------------------------
  7. //define baudrate const
  8. //BAUD = 65536 - FOSC/3/BAUDRATE/M (1T:M=1; 12T:M=12)
  9. //NOTE: (FOSC/3/BAUDRATE) must be greater then 98, (RECOMMEND GREATER THEN 110)
  10. #define BAUD  0xFE80    // 9600bps @ 11.0592MHz
  11. sfr AUXR = 0x8E;
  12. sfr INT_CLKO = 0x8f;
  13. sbit RXB = P3^0;       //define UART TX/RX port
  14. sbit TXB = P3^1;
  15. sbit T3 =  P3^5;
  16. sbit led = P3^4;
  17. typedef bit BOOL;
  18. typedef unsigned char BYTE;
  19. typedef unsigned int WORD;
  20. BYTE TBUF,RBUF;//字节
  21. BYTE TDAT,RDAT;
  22. BYTE TCNT,RCNT;
  23. BYTE TBIT,RBIT;
  24. BOOL TING,RING;
  25. BOOL TEND,REND;
  26. void UART_INIT();
  27. void uart1_TX();
  28. BYTE r;
  29. BYTE buf[16];
  30. unsigned int k=0;
  31. //-----------------------------------------
  32. //initial UART module variable
  33. void delay(unsigned int n)
  34. {
  35.     unsigned int w=0;
  36.     while(n--)
  37.         for(w=0;w<114;w++);
  38. }
  39. void UART_INIT()
  40. {
  41.     TING = 0;
  42.     RING = 0;
  43.     TEND = 1;
  44.     REND = 0;
  45.     TCNT = 0;
  46.     RCNT = 0;
  47. }
  48. void exint3() interrupt 11
  49. {
  50.   while(T3==0);
  51.    delay(10);
  52.    while(T3==0)
  53.    k = 1;
  54.    i = 0;
  55.    j = 0;
  56.    led = 0;
  57. }
  58. void uart3i()
  59. {
  60.                           if(i<19)
  61.                                   {
  62.                                         TEND = 0;                  //发送完一个字符清一次
  63.                         TBUF = DATA[i];//发送缓冲器 进行赋值
  64.                         TING = 1;
  65.                                         i++;
  66.                                  }
  67. }
  68. void uart3j()
  69. {
  70.                           if(j<19)
  71.                                   {
  72.                                         TEND = 0;                  //发送完一个字符清一次
  73.                         TBUF = DATA2[j];//发送缓冲器 进行赋值
  74.                         TING = 1;
  75.                                         j++;
  76.                                  }
  77. }
  78. void main()
  79. {
  80.     TMOD = 0x00;                        //timer0 in 16-bit auto reload mode定时器0在16位自动重新加载模式下
  81.     AUXR = 0x80;                        //timer0 working at 1T mode定时器0在1T模式下工作
  82.     TL0 = BAUD;
  83.     TH0 = BAUD>>8;                      //initial timer0 and set reload value初始计时器0并设置重新加载值
  84.     TR0 = 1;                            //tiemr0 start runningtimer0 tiemr0开始运行
  85.     ET0 = 1;                            //enable timer0 interrupt使timer0中断
  86.     PT0 = 1;                            //improve timer0 interrupt priority提高定时器0中断优先级
  87.     EA = 1;                                                         //总中断
  88.         led = 0;
  89.         INT_CLKO |= 0x20;
  90.     UART_INIT();
  91.         while (1)
  92.         {                                   //user's function
  93.         if (REND)
  94.         {
  95.                     REND = 0;
  96.             buf[r++ & 0x0f] = RBUF; //接收缓冲器 高四位清0低四位赋值
  97.         }
  98.        if(k == 1)
  99.                 {
  100.                         if (TEND)
  101.                 {
  102.                         {
  103.                         uart3i();
  104.                         }
  105.                      if(i==19)
  106.                                  delay(1000);
  107.                           {
  108.                                  uart3j();
  109.                                 if(j==19)
  110.                                  {
  111.                                    k = 0;
  112.                                  }
  113.                           }
  114.                         }
  115.                 }
  116.         }
  117. }
  118. //-----------------------------------------
  119. //Timer interrupt routine for UART计时器中断串口
  120. void tm0() interrupt 1 using 1
  121. { //****************接收数据******************/
  122.     if (RING) //正在接受数据
  123.     {
  124.         if (--RCNT == 0)
  125.         {
  126.             RCNT = 3;                   //reset send baudrate counter        复位发送波特率计数器
  127.             if (--RBIT == 0)
  128.             {
  129.                 RBUF = RDAT;            //save the data to RDAT数据保存到RBUF中
  130.                 RING = 0;               //stop receive        停止接受
  131.                 REND = 1;               //set receive completed flag设置接收完成标志
  132.             }
  133.             else
  134.             {
  135.                 RDAT >>= 1;                                //接收到的单bit数据暂存
  136.                 if (RXB) RDAT |= 0x80;  //shift RX data to RX buffer  将RX数据转移到RX缓冲区
  137.             }
  138.         }
  139.     }
  140.     else if (!RXB)//判断开始位RXB=0
  141.     {
  142.         RING = 1;                       //set start receive flag 设置开始接收标志
  143.         RCNT = 4;                       //initial receive baudrate counter 初始接收波特率计数器
  144.         RBIT = 9;                       //initial receive bit number (8 data bits + 1 stop bit) 初始接收位(8位数据位1停止位)
  145.     }
  146.     //*******************发送********************/
  147.     if (--TCNT == 0)
  148.     {
  149.         TCNT = 3;                       //reset send baudrate counter  复位发送波特率计数器
  150.         if (TING)                       //judge whether sending  判断是否发送
  151.         {
  152.             if (TBIT == 0)
  153.             {
  154.                 TXB = 0;                //send start bit  发送起始位
  155.                 TDAT = TBUF;            //load data from TBUF to TDAT  数据从TBUF加载到TDAT
  156.                 TBIT = 9;               //initial send bit number (8 data bits + 1 stop bit)初始发送位(8位数据位1停止位)
  157.             }
  158.             else
  159.             {
  160.                 TDAT >>= 1;             //shift data to CY将 数据右移1位,低位送给CY
  161.                 if (--TBIT == 0)
  162.                 {
  163.                     TXB = 1;                        //发送停止位数据
  164.                     TING = 0;           //stop send发送停止位
  165.                     TEND = 1;           //set send completed flag设置发送完成标志
  166.                 }
  167.                 else
  168.                 {
  169.                     TXB = CY;           //write CY to TX port 发送单bit数据
  170.                 }
  171.             }
  172.         }
  173.     }
  174. }
ID:213173 发表于 2018-3-19 21:53 | 只看该作者
芯片型号 : STC15L100
关于此芯片的重要说明:
  无硬件串口,可用软件模拟串口 (范例代码中有参考代码)
  有定时器0和定时器2 (注意:无定时器1)
ID:277550 发表于 2018-3-19 22:21 | 只看该作者
这系列的早期的产品,外部中断是有问题的,,,,,,先弄清楚是不是这个问题影响了
参与人数 1黑币 +60 收起 理由
admin + 60 回帖助人的奖励!
ID:289703 发表于 2018-3-20 08:27 | 只看该作者
我的外部中断写的应该有问题,不太明白,新手
ID:289703 发表于 2018-3-20 08:37 | 只看该作者
wulin 发表于 2018-3-19 21:53
芯片型号 : STC15L100
关于此芯片的重要说明:
资料里的中段3没看懂啊
ID:213173 发表于 2018-3-20 10:21 | 只看该作者
木易阳 发表于 2018-3-20 08:37
资料里的中段3没看懂啊
1.此芯片没有硬件串口, SBUF = DATA[a]; 有什么用?要用软件模拟串口
2.外部中断3允许位  INT_CLKO |= 0x20;  //(EX3 = 1)使能INT3中断
void exint3() interrupt 11          //INT3中断入口
    中断任务......
//  INT_CLKO &= 0xDF;   //若需要手动清除中断标志,可先关闭中断,此时系统会自动清除内部的中断标志
//  INT_CLKO |= 0x20;    //然后再开中断即可
ID:289703 发表于 2018-3-20 14:02 | 只看该作者
2.外部中断3允许位  INT_CLKO | ...
就是用的USB线连得串口线,data不能直接给SBUF吗?为什么?谢谢回答
ID:213173 发表于 2018-3-20 20:46 | 只看该作者
芯片没有硬件串口,也就是说没有与串口相关的寄存器,当然也就没有SBUF寄存器!
/* --- STC MCU Limited ------------------------------------------------*/
/* --- STC15Fxx 系列 软件模拟串口举例----------------------------------*/
/* --- Mobile: (86)13922805190 ----------------------------------------*/
/* --- Fax: 86-0513-55012956,55012947,55012969 ------------------------*/
/* --- Tel: 86-0513-55012928,55012929,55012966-------------------------*/
/* 如果要在程序中使用此代码,请在程序中注明使用了STC的资料及程序        */
/* 如果要在文章中应用此代码,请在文章中注明使用了STC的资料及程序        */
//本示例在Keil开发环境下请选择Intel的8058芯片型号进行编译
//若无特别说明,工作频率一般为11.0592MHz
#include "reg51.h"
//#define BAUD  0xF400                  // 1200bps @ 11.0592MHz
//#define BAUD  0xFA00                  // 2400bps @ 11.0592MHz
//#define BAUD  0xFD00                  // 4800bps @ 11.0592MHz
//#define BAUD  0xFE80                  // 9600bps @ 11.0592MHz
//#define BAUD  0xFF40                  //19200bps @ 11.0592MHz
#define BAUD  0xFFA0                    //38400bps @ 11.0592MHz
//#define BAUD  0xEC00                  // 1200bps @ 18.432MHz
//#define BAUD  0xF600                  // 2400bps @ 18.432MHz
//#define BAUD  0xFB00                  // 4800bps @ 18.432MHz
//#define BAUD  0xFD80                  // 9600bps @ 18.432MHz
//#define BAUD  0xFEC0                  //19200bps @ 18.432MHz
//#define BAUD    0xFF60                //38400bps @ 18.432MHz
//#define BAUD  0xE800                  // 1200bps @ 22.1184MHz
//#define BAUD  0xF400                  // 2400bps @ 22.1184MHz
//#define BAUD  0xFA00                  // 4800bps @ 22.1184MHz
//#define BAUD  0xFD00                  // 9600bps @ 22.1184MHz
//#define BAUD  0xFE80                  //19200bps @ 22.1184MHz
//#define BAUD  0xFF40                  //38400bps @ 22.1184MHz
//#define BAUD  0xFF80                  //57600bps @ 22.1184MHz
sfr AUXR = 0x8E;
sbit TXB = P3^1;
typedef bit BOOL;
BYTE TBUF,RBUF;
BYTE TDAT,RDAT;
BYTE TCNT,RCNT;
BYTE TBIT,RBIT;
BOOL TING,RING;
BOOL TEND,REND;
void UART_INIT();
BYTE t, r;
BYTE buf[16];
    TL0 = BAUD;
    EA = 1;                             //open global interrupt switch
    UART_INIT();
    while (1)
    {                                   //user's function
        if (REND)
            REND = 0;
        if (TEND)
            if (t != r)
                TEND = 0;
                TBUF = buf[t++ & 0x0f];
                TING = 1;
    if (RING)
        if (--RCNT == 0)
            if (--RBIT == 0)
                RBUF = RDAT;            //save the data to RBUF
                RDAT >>= 1;
    else if (!RXB)
    if (--TCNT == 0)
            if (TBIT == 0)
                if (--TBIT == 0)
                    TXB = 1;
void UART_INIT()
    TING = 0;
    RING = 0;
    TEND = 1;
    REND = 0;
    TCNT = 0;
    RCNT = 0;
ID:289703 发表于 2018-3-21 10:40 | 只看该作者
谢谢,就是他的外部中断3是怎么控制的,比如说我按下按键发出外部中断3信号,串口开始发送DATA里的数据,但是数据发送是乱码
#include <reg51.h>
char  code DATA[19]={0x02, 0x6c, 0x62, 0x03, 0x03, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00,  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc1}; //隐
unsigned char i=0;
sfr AUXR = 0x8E;
sbit TXB = P3^1;
sbit T3 =  P3^5;
sbit led = P3^4;
typedef bit BOOL;
BYTE TBUF,RBUF;//字节
BYTE TDAT,RDAT;
BYTE TCNT,RCNT;
BYTE TBIT,RBIT;
BOOL TING,RING;
BOOL TEND,REND;
void UART_INIT();
BYTE r;
BYTE buf[16];
  int k=0;
void UART_INIT()
    TING = 0;
    RING = 0;
    TEND = 1;
    REND = 0;
    TCNT = 0;
    RCNT = 0;
   k = 1;
   led = 1;
    TL0 = BAUD;
    EA = 1;        //总中断
led = 0;
INT_CLKO |= 0x20;
    UART_INIT();
while (1)
{                                   //user's function
        if (REND)
            REND = 0;
        if(k == 1)
   if (TEND)
     for(i=0;i<19;i++)//
                 TBUF = DATA;//发送缓冲器 进行赋值
                 TING = 1;
      k = 0;
    if (RING) //正在接受数据
        if (--RCNT == 0)
            if (--RBIT == 0)
    if (--TCNT == 0)
            if (TBIT == 0)
                if (--TBIT == 0)
                    TXB = 1;   //发送停止位数据
