查看: 3731|回复: 0
arduino_wifi上传到串口调试助手程序
ID:298766 发表于 2018-3-29 10:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <TimerOne.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <IR_Thermometer_Sensor_MLX90614.h>
SoftwareSerial DebugSerial(10, 11); // RX, TX
void set()
     Serial.flush();
    Serial.print("AT\r\n");
    delay(10);
    Serial.print("AT+CWMODE=1\r\n");
    delay(10);
      Serial.print("AT+RST\r\n");
     delay(10);
     Serial.print("AT+CWJAP=\"Redmi Note 4X\",\"SB1234567SB\"\r\n");
       delay(500);
       Serial.print("AT+CIFSR\r\n");
       delay(100);
          Serial.print("AT+CIPSTART=\"TCP\",\"192.168.43.1\",8090\r\n");
          delay(5000);
           DebugSerial.print("AT+CIPMODE=1\r\n");
           delay(1000);
       delay(200);
         Serial.print("AT+CIPSEND\r\n");//开始发送数据
          delay(200);
          Serial.println();
  void setup()
  Serial.begin(115200);
  pinMode(DHpin, OUTPUT);
   set();
void loop()
int yd,tr,a;
int data_1,data_2;
int data_3;
char send_buf[100] = {0};
send_buf[0] = 0x1a;
  while(true)
      int wendua = 0, wendub = 0;
      int shidux = 0;
      int shiduy = 0;
      String tmpString = "";
      wendua = random(100);
      tmpString = String(wendua);
      cnt += tmpString.length();//加上温度数据的长度
      //hum = data_1;//产生       //设置成湿度
      wendub = random(100);//产生       //设置成湿
      tmpString = String(wendub);
      cnt += tmpString.length();//加上湿度数据长度
      //noise = tr;//产生     //设置成土壤值
       shidux = random(100);//产生     //设置成土壤值
       tmpString = String(shidux);
      cnt += tmpString.length();//加上噪音数据长度
      //light = yd;                        //设置成雨滴值
       shiduy = random(100);
      tmpString = String(shiduy);
      delay(20);
      Serial.print(wendub);
      delay(200);
      Serial.print(data_1);
     delay(100);
     delay(2000);
     Serial.println();
      delay(2000);
     /* Serial.println(data_1);
      Serial.println(data_2);
      Serial.println(tr);
      Serial.println(data_3);*/
      delay(300);
      delay(500);
收藏收藏2 分享淘帖 顶 踩
