查看: 2187|回复: 1
自己制作的一个电子时钟
ID:300447 发表于 2018-4-1 17:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
sbit P0_0=P0^0;
sbit P0_1=P0^1;
sbit P0_2=P0^2;
sbit P0_3=P0^3;
sbit P0_4=P0^4;
sbit P0_5=P0^5;
sbit P0_6=P0^6;
sbit P0_7=P0^7;
sbit P3_5=P3^5;
sbit P3_6=P3^6;
sbit P3_7=P3^7;
sbit E=P2^2;
uint num=0,second,minute,hour,day,month,gewei,shiwei,m=0;
uchar code duanma[]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07};    //定义段码,用以送P2口
uchar code pianxuan[]={0xfe,0xfd,0xfb,0xf7,0xef};           //定义片选码,用以P1片选
void delay(uint i)           //延时程序
        {for(;i>0;i--);}
uchar right[10][8]={{0xff,0x81,0x81,0xff,0x00,0x00,0x00,0x00},
                      {0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
                                  {0x9f,0x91,0x91,0xf1,0x00,0x00,0x00,0x00},
                                     {0xff,0x91,0x91,0x91,0x00,0x00,0x00,0x00},
                                      {0xff,0x08,0x08,0x0f,0x00,0x00,0x00,0x00},
                                      {0xf1,0x91,0x91,0x9f,0x00,0x00,0x00,0x00},
                                      {0xf1,0x91,0x91,0xff,0x00,0x00,0x00,0x00},
                                      {0xff,0x01,0x01,0x01,0x00,0x00,0x00,0x00},
                                      {0xff,0x91,0x91,0xff,0x00,0x00,0x00,0x00},
                                      {0xff,0x91,0x91,0x9f,0x00,0x00,0x00,0x00}};
uchar code left[10][8]={{0x00,0x00,0x00,0x00,0xff,0x81,0x81,0xff},
                        {0x00,0x00,0x00,0x00,0xff,0x00,0x00,0x00},
                                    {0x00,0x00,0x00,0x00,0x9f,0x91,0x91,0xf1},
                                       {0x00,0x00,0x00,0x00,0xff,0x91,0x91,0x91},
                                        {0x00,0x00,0x00,0x00,0xff,0x08,0x08,0x0f},
                                        {0x00,0x00,0x00,0x00,0xf1,0x91,0x91,0x9f},
                                        {0x00,0x00,0x00,0x00,0xf1,0x91,0x91,0xff},
                                        {0x00,0x00,0x00,0x00,0xff,0x01,0x01,0x01},
                                        {0x00,0x00,0x00,0x00,0xff,0x91,0x91,0xff},
                                        {0x00,0x00,0x00,0x00,0xff,0x91,0x91,0x9f}};
//送段码显示
void display(uint n)
    int i;
        shiwei=n/10;
        gewei=n%10;
        for(i=0;i<8;i++)
                P2=duanma[i];
                P0=left[shiwei][i]|right[gewei][i];
                delay(100);
//用定时中T0定时一秒
void T0_int() interrupt 1 using 0
    TH0=(65536-50000)/256;           //重新装载初值
        TL0=(65536-50000)%256;
        num++;
        if(num==20)
            second++;
                num=0;
                if(second>59)
                    minute++;
                        second=0;
                        if(minute>59)
                            hour++;
                                minute=0;
                                if(hour>23)
                                    day++;
                                        hour=0;
                                        if(day>30)
                                            month++;
                                                day=1;
                                                if(month>12)
                                                    month=1;
//用外中断INT0进行校准
void int0() interrupt 0 using 1
    EA=0;
        if(P3_5==0)             //用P3_5口记录按键次数,选择需要修改的项目
            delay(6500);
                m++;
                if(m==5)
                    m=0;
        if(P3_6==0)                 //用P3_6口使得需要修改的项目数值增加
            delay(6500);
                switch(m)
                    case 0:second++;if(second>59){second=0;}break;
                    case 1:minute++;if(minute>59){minute=0;}break;
                    case 2:hour++;if(hour>23){hour=0;}break;
                    case 3:day++;if(day>30){day=1;}break;
                    case 4:month++;if(month>12){month=1;}break;
        if(P3_7==0)                        //用P3_7口使得需要修改的项目数值减少
            delay(6500);
                switch(m)
                    case 0:second--;if(second<0){second=59;}break;
                    case 1:minute--;if(minute<0){minute=59;}break;
                    case 2:hour--;if(hour<0){hour=23;}break;
                    case 3:day--;if(day<1){day=30;}break;
                    case 4:month--;if(month<1){month=12;}break;
        EA=1;
    TMOD=0x01;
        EA=1;
        EX0=1;
        ET0=1;
        TR0=1;
        IT0=1;
        P3=0xff;
        second=0;
    minute=0;
    hour=0;
    day=1;
    month=1;
                P1=pianxuan[0];
            display(second);
                P1=pianxuan[1];
                display(minute);
                P1=pianxuan[2];
                display(hour);
                P1=pianxuan[3];
                display(day);
                P1=pianxuan[4];
                display(month);
                delay(90);
ID:352921 发表于 2018-6-19 17:05 | 只看该作者
楼主棒棒哒
