查看: 10707|回复: 3
ds3231的Arduino库文件及程序示例
发个ds3231高精度时钟模块的库文件及示例,用于Arduino开发版,精度不错。
  1. /*
  2. DS3231.cpp: DS3231 Real-Time Clock library
  3. original code by
  4. Eric Ayars
  5. 4/1/11
  6. updated to Arduino 1.0
  7. John Hubert
  8. Feb 7, 2012
  9. Released into the public domain.
  10. */
  11. #include <DS3231.h>
  12. #define CLOCK_ADDRESS 0x68
  13. // Constructor
  14. DS3231::DS3231() {
  15.         // nothing to do for this constructor.
  16. }
  17. /*****************************************
  18.         Public Functions
  19. *****************************************/
  20. void DS3231::getTime(byte& year, byte& month, byte& date, byte& DoW, byte& hour, byte& minute, byte& second) {
  21.         byte tempBuffer;
  22.         bool PM;
  23.         bool h12;
  24.         Wire.beginTransmission(CLOCK_ADDRESS);
  25.         Wire.write(uint8_t(0x00));
  26.         Wire.endTransmission();
  27.
  28.         Wire.requestFrom(CLOCK_ADDRESS, 7);
  29.         second = bcdToDec(Wire.read());
  30.         minute = bcdToDec(Wire.read());
  31.         tempBuffer = bcdToDec(Wire.read());
  32.         h12 = tempBuffer & 0b01000000;
  33.         if (h12) {
  34.                 PM = tempBuffer & 0b00100000;
  35.                 hour = bcdToDec(tempBuffer & 0b00011111);
  36.         } else {
  37.                 hour = bcdToDec(tempBuffer & 0b00111111);
  38.         }
  39.         DoW = bcdToDec(Wire.read());
  40.         date = bcdToDec(Wire.read());
  41.         month = bcdToDec(Wire.read() & 0b01111111);
  42.         year = bcdToDec(Wire.read());
  43. }
  44. byte DS3231::getSecond() {
  45.         Wire.beginTransmission(CLOCK_ADDRESS);
  46.         Wire.write(uint8_t(0x00));
  47.         Wire.endTransmission();
  48.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  49.         return bcdToDec(Wire.read());
  50. }
  51. byte DS3231::getMinute() {
  52.         Wire.beginTransmission(CLOCK_ADDRESS);
  53.         Wire.write(0x01);
  54.         Wire.endTransmission();
  55.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  56.         return bcdToDec(Wire.read());
  57. }
  58. byte DS3231::getHour(bool& h12, bool& PM) {
  59.         byte temp_buffer;
  60.         byte hour;
  61.         Wire.beginTransmission(CLOCK_ADDRESS);
  62.         Wire.write(0x02);
  63.         Wire.endTransmission();
  64.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  65.         temp_buffer = Wire.read();
  66.         h12 = temp_buffer & 0b01000000;
  67.         if (h12) {
  68.                 PM = temp_buffer & 0b00100000;
  69.                 hour = bcdToDec(temp_buffer & 0b00011111);
  70.         } else {
  71.                 hour = bcdToDec(temp_buffer & 0b00111111);
  72.         }
  73.         return hour;
  74. }
  75. byte DS3231::getDoW() {
  76.         Wire.beginTransmission(CLOCK_ADDRESS);
  77.         Wire.write(uint8_t(0x03));
  78.         Wire.endTransmission();
  79.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  80.         return bcdToDec(Wire.read());
  81. }
  82. byte DS3231::getDate() {
  83.         Wire.beginTransmission(CLOCK_ADDRESS);
  84.         Wire.write(uint8_t(0x04));
  85.         Wire.endTransmission();
  86.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  87.         return bcdToDec(Wire.read());
  88. }
  89. byte DS3231::getMonth(bool& Century) {
  90.         byte temp_buffer;
  91.         byte hour;
  92.         Wire.beginTransmission(CLOCK_ADDRESS);
  93.         Wire.write(uint8_t(0x05));
  94.         Wire.endTransmission();
  95.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  96.         temp_buffer = Wire.read();
  97.         Century = temp_buffer & 0b10000000;
  98.         return (bcdToDec(temp_buffer & 0b01111111)) ;
  99. }
  100. byte DS3231::getYear() {
  101.         Wire.beginTransmission(CLOCK_ADDRESS);
  102.         Wire.write(uint8_t(0x06));
  103.         Wire.endTransmission();
  104.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  105.         return bcdToDec(Wire.read());
  106. }
  107. void DS3231::setSecond(byte Second) {
  108.         // Sets the seconds
  109.         // This function also resets the Oscillator Stop Flag, which is set
  110.         // whenever power is interrupted.
  111.         Wire.beginTransmission(CLOCK_ADDRESS);
  112.         Wire.write(uint8_t(0x00));
  113.         Wire.write(decToBcd(Second));
  114.         Wire.endTransmission();
  115.         // Clear OSF flag
  116.         byte temp_buffer = readControlByte(1);
  117.         writeControlByte((temp_buffer & 0b01111111), 1);
  118. }
  119. void DS3231::setMinute(byte Minute) {
  120.         // Sets the minutes
  121.         Wire.beginTransmission(CLOCK_ADDRESS);
  122.         Wire.write(uint8_t(0x01));
  123.         Wire.write(decToBcd(Minute));
  124.         Wire.endTransmission();
  125. }
  126. void DS3231::setHour(byte Hour) {
  127.         // Sets the hour, without changing 12/24h mode.
  128.         // The hour must be in 24h format.
  129.         bool h12;
  130.         // Start by figuring out what the 12/24 mode is
  131.         Wire.beginTransmission(CLOCK_ADDRESS);
  132.         Wire.write(uint8_t(0x02));
  133.         Wire.endTransmission();
  134.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  135.         h12 = (Wire.read() & 0b01000000);
  136.         // if h12 is true, it's 12h mode; false is 24h.
  137.         if (h12) {
  138.                 // 12 hour
  139.                 if (Hour > 12) {
  140.                         Hour = decToBcd(Hour-12) | 0b01100000;
  141.                 } else {
  142.                         Hour = decToBcd(Hour) & 0b11011111;
  143.                 }
  144.         } else {
  145.                 // 24 hour
  146.                 Hour = decToBcd(Hour) & 0b10111111;
  147.         }
  148.         Wire.beginTransmission(CLOCK_ADDRESS);
  149.         Wire.write(uint8_t(0x02));
  150.         Wire.write(Hour);
  151.         Wire.endTransmission();
  152. }
  153. void DS3231::setDoW(byte DoW) {
  154.         // Sets the Day of Week
  155.         Wire.beginTransmission(CLOCK_ADDRESS);
  156.         Wire.write(uint8_t(0x03));
  157.         Wire.write(decToBcd(DoW));
  158.         Wire.endTransmission();
  159. }
  160. void DS3231::setDate(byte Date) {
  161.         // Sets the Date
  162.         Wire.beginTransmission(CLOCK_ADDRESS);
  163.         Wire.write(uint8_t(0x04));
  164.         Wire.write(decToBcd(Date));
  165.         Wire.endTransmission();
  166. }
  167. void DS3231::setMonth(byte Month) {
  168.         // Sets the month
  169.         Wire.beginTransmission(CLOCK_ADDRESS);
  170.         Wire.write(uint8_t(0x05));
  171.         Wire.write(decToBcd(Month));
  172.         Wire.endTransmission();
  173. }
  174. void DS3231::setYear(byte Year) {
  175.         // Sets the year
  176.         Wire.beginTransmission(CLOCK_ADDRESS);
  177.         Wire.write(uint8_t(0x06));
  178.         Wire.write(decToBcd(Year));
  179.         Wire.endTransmission();
  180. }
  181. void DS3231::setClockMode(bool h12) {
  182.         // sets the mode to 12-hour (true) or 24-hour (false).
  183.         // One thing that bothers me about how I've written this is that
  184.         // if the read and right happen at the right hourly millisecnd,
  185.         // the clock will be set back an hour. Not sure how to do it better,
  186.         // though, and as long as one doesn't set the mode frequently it's
  187.         // a very minimal risk.
  188.         // It's zero risk if you call this BEFORE setting the hour, since
  189.         // the setHour() function doesn't change this mode.
  190.
  191.         byte temp_buffer;
  192.         // Start by reading byte 0x02.
  193.         Wire.beginTransmission(CLOCK_ADDRESS);
  194.         Wire.write(uint8_t(0x02));
  195.         Wire.endTransmission();
  196.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  197.         temp_buffer = Wire.read();
  198.         // Set the flag to the requested value:
  199.         if (h12) {
  200.                 temp_buffer = temp_buffer | 0b01000000;
  201.         } else {
  202.                 temp_buffer = temp_buffer & 0b10111111;
  203.         }
  204.         // Write the byte
  205.         Wire.beginTransmission(CLOCK_ADDRESS);
  206.         Wire.write(uint8_t(0x02));
  207.         Wire.write(temp_buffer);
  208.         Wire.endTransmission();
  209. }
  210. float DS3231::getTemperature() {
  211.         // Checks the internal thermometer on the DS3231 and returns the
  212.         // temperature as a floating-point value.
  213.         byte temp;
  214.         Wire.beginTransmission(CLOCK_ADDRESS);
  215.         Wire.write(uint8_t(0x11));
  216.         Wire.endTransmission();
  217.         Wire.requestFrom(CLOCK_ADDRESS, 2);
  218.         temp = Wire.read();        // Here's the MSB
  219.         return float(temp) + 0.25*(Wire.read()>>6);
  220. }
  221. void DS3231::getA1Time(byte& A1Day, byte& A1Hour, byte& A1Minute, byte& A1Second, byte& AlarmBits, bool& A1Dy, bool& A1h12, bool& A1PM) {
  222.         byte temp_buffer;
  223.         Wire.beginTransmission(CLOCK_ADDRESS);
  224.         Wire.write(uint8_t(0x07));
  225.         Wire.endTransmission();
  226.         Wire.requestFrom(CLOCK_ADDRESS, 4);
  227.         temp_buffer        = Wire.read();        // Get A1M1 and A1 Seconds
  228.         A1Second        = bcdToDec(temp_buffer & 0b01111111);
  229.         // put A1M1 bit in position 0 of DS3231_AlarmBits.
  230.         AlarmBits        = AlarmBits | (temp_buffer & 0b10000000)>>7;
  231.         temp_buffer                = Wire.read();        // Get A1M2 and A1 minutes
  232.         A1Minute        = bcdToDec(temp_buffer & 0b01111111);
  233.         // put A1M2 bit in position 1 of DS3231_AlarmBits.
  234.         AlarmBits        = AlarmBits | (temp_buffer & 0b10000000)>>6;
  235.         temp_buffer        = Wire.read();        // Get A1M3 and A1 Hour
  236.         // put A1M3 bit in position 2 of DS3231_AlarmBits.
  237.         AlarmBits        = AlarmBits | (temp_buffer & 0b10000000)>>5;
  238.         // determine A1 12/24 mode
  239.         A1h12                = temp_buffer & 0b01000000;
  240.         if (A1h12) {
  241.                 A1PM        = temp_buffer & 0b00100000;                        // determine am/pm
  242.                 A1Hour        = bcdToDec(temp_buffer & 0b00011111);        // 12-hour
  243.         } else {
  244.                 A1Hour        = bcdToDec(temp_buffer & 0b00111111);        // 24-hour
  245.         }
  246.         temp_buffer        = Wire.read();        // Get A1M4 and A1 Day/Date
  247.         // put A1M3 bit in position 3 of DS3231_AlarmBits.
  248.         AlarmBits        = AlarmBits | (temp_buffer & 0b10000000)>>4;
  249.         // determine A1 day or date flag
  250.         A1Dy                = (temp_buffer & 0b01000000)>>6;
  251.         if (A1Dy) {
  252.                 // alarm is by day of week, not date.
  253.                 A1Day        = bcdToDec(temp_buffer & 0b00001111);
  254.         } else {
  255.                 // alarm is by date, not day of week.
  256.                 A1Day        = bcdToDec(temp_buffer & 0b00111111);
  257.         }
  258. }
  259. void DS3231::getA2Time(byte& A2Day, byte& A2Hour, byte& A2Minute, byte& AlarmBits, bool& A2Dy, bool& A2h12, bool& A2PM) {
  260.         byte temp_buffer;
  261.         Wire.beginTransmission(CLOCK_ADDRESS);
  262.         Wire.write(uint8_t(0x0b));
  263.         Wire.endTransmission();
  264.         Wire.requestFrom(CLOCK_ADDRESS, 3);
  265.         temp_buffer        = Wire.read();        // Get A2M2 and A2 Minutes
  266.         A2Minute        = bcdToDec(temp_buffer & 0b01111111);
  267.         // put A2M2 bit in position 4 of DS3231_AlarmBits.
  268.         AlarmBits        = AlarmBits | (temp_buffer & 0b10000000)>>3;
  269.         temp_buffer        = Wire.read();        // Get A2M3 and A2 Hour
  270.         // put A2M3 bit in position 5 of DS3231_AlarmBits.
  271.         AlarmBits        = AlarmBits | (temp_buffer & 0b10000000)>>2;
  272.         // determine A2 12/24 mode
  273.         A2h12                = temp_buffer & 0b01000000;
  274.         if (A2h12) {
  275.                 A2PM        = temp_buffer & 0b00100000;                        // determine am/pm
  276.                 A2Hour        = bcdToDec(temp_buffer & 0b00011111);        // 12-hour
  277.         } else {
  278.                 A2Hour        = bcdToDec(temp_buffer & 0b00111111);        // 24-hour
  279.         }
  280.         temp_buffer        = Wire.read();        // Get A2M4 and A1 Day/Date
  281.         // put A2M4 bit in position 6 of DS3231_AlarmBits.
  282.         AlarmBits        = AlarmBits | (temp_buffer & 0b10000000)>>1;
  283.         // determine A2 day or date flag
  284.         A2Dy                = (temp_buffer & 0b01000000)>>6;
  285.         if (A2Dy) {
  286.                 // alarm is by day of week, not date.
  287.                 A2Day        = bcdToDec(temp_buffer & 0b00001111);
  288.         } else {
  289.                 // alarm is by date, not day of week.
  290.                 A2Day        = bcdToDec(temp_buffer & 0b00111111);
  291.         }
  292. }
  293. void DS3231::setA1Time(byte A1Day, byte A1Hour, byte A1Minute, byte A1Second, byte AlarmBits, bool A1Dy, bool A1h12, bool A1PM) {
  294.         //        Sets the alarm-1 date and time on the DS3231, using A1* information
  295.         byte temp_buffer;
  296.         Wire.beginTransmission(CLOCK_ADDRESS);
  297.         Wire.write(uint8_t(0x07));        // A1 starts at 07h
  298.         // Send A1 second and A1M1
  299.         Wire.write(decToBcd(A1Second) | ((AlarmBits & 0b00000001) << 7));
  300.         // Send A1 Minute and A1M2
  301.         Wire.write(decToBcd(A1Minute) | ((AlarmBits & 0b00000010) << 6));
  302.         // Figure out A1 hour
  303.         if (A1h12) {
  304.                 // Start by converting existing time to h12 if it was given in 24h.
  305.                 if (A1Hour > 12) {
  306.                         // well, then, this obviously isn't a h12 time, is it?
  307.                         A1Hour = A1Hour - 12;
  308.                         A1PM = true;
  309.                 }
  310.                 if (A1PM) {
  311.                         // Afternoon
  312.                         // Convert the hour to BCD and add appropriate flags.
  313.                         temp_buffer = decToBcd(A1Hour) | 0b01100000;
  314.                 } else {
  315.                         // Morning
  316.                         // Convert the hour to BCD and add appropriate flags.
  317.                         temp_buffer = decToBcd(A1Hour) | 0b01000000;
  318.                 }
  319.         } else {
  320.                 // Now for 24h
  321.                 temp_buffer = decToBcd(A1Hour);
  322.         }
  323.         temp_buffer = temp_buffer | ((AlarmBits & 0b00000100)<<5);
  324.         // A1 hour is figured out, send it
  325.         Wire.write(temp_buffer);
  326.         // Figure out A1 day/date and A1M4
  327.         temp_buffer = ((AlarmBits & 0b00001000)<<4) | decToBcd(A1Day);
  328.         if (A1Dy) {
  329.                 // Set A1 Day/Date flag (Otherwise it's zero)
  330.                 temp_buffer = temp_buffer | 0b01000000;
  331.         }
  332.         Wire.write(temp_buffer);
  333.         // All done!
  334.         Wire.endTransmission();
  335. }
  336. void DS3231::setA2Time(byte A2Day, byte A2Hour, byte A2Minute, byte AlarmBits, bool A2Dy, bool A2h12, bool A2PM) {
  337.         //        Sets the alarm-2 date and time on the DS3231, using A2* information
  338.         byte temp_buffer;
  339.         Wire.beginTransmission(CLOCK_ADDRESS);
  340.         Wire.write(uint8_t(0x0b));        // A1 starts at 0bh
  341.         // Send A2 Minute and A2M2
  342.         Wire.write(decToBcd(A2Minute) | ((AlarmBits & 0b00010000) << 3));
  343.         // Figure out A2 hour
  344.         if (A2h12) {
  345.                 // Start by converting existing time to h12 if it was given in 24h.
  346.                 if (A2Hour > 12) {
  347.                         // well, then, this obviously isn't a h12 time, is it?
  348.                         A2Hour = A2Hour - 12;
  349.                         A2PM = true;
  350.                 }
  351.                 if (A2PM) {
  352.                         // Afternoon
  353.                         // Convert the hour to BCD and add appropriate flags.
  354.                         temp_buffer = decToBcd(A2Hour) | 0b01100000;
  355.                 } else {
  356.                         // Morning
  357.                         // Convert the hour to BCD and add appropriate flags.
  358.                         temp_buffer = decToBcd(A2Hour) | 0b01000000;
  359.                 }
  360.         } else {
  361.                 // Now for 24h
  362.                 temp_buffer = decToBcd(A2Hour);
  363.         }
  364.         // add in A2M3 bit
  365.         temp_buffer = temp_buffer | ((AlarmBits & 0b00100000)<<2);
  366.         // A2 hour is figured out, send it
  367.         Wire.write(temp_buffer);
  368.         // Figure out A2 day/date and A2M4
  369.         temp_buffer = ((AlarmBits & 0b01000000)<<1) | decToBcd(A2Day);
  370.         if (A2Dy) {
  371.                 // Set A2 Day/Date flag (Otherwise it's zero)
  372.                 temp_buffer = temp_buffer | 0b01000000;
  373.         }
  374.         Wire.write(temp_buffer);
  375.         // All done!
  376.         Wire.endTransmission();
  377. }
  378. void DS3231::turnOnAlarm(byte Alarm) {
  379.         // turns on alarm number "Alarm". Defaults to 2 if Alarm is not 1.
  380.         byte temp_buffer = readControlByte(0);
  381.         // modify control byte
  382.         if (Alarm == 1) {
  383.                 temp_buffer = temp_buffer | 0b00000101;
  384.         } else {
  385.                 temp_buffer = temp_buffer | 0b00000110;
  386.         }
  387.         writeControlByte(temp_buffer, 0);
  388. }
  389. void DS3231::turnOffAlarm(byte Alarm) {
  390.         // turns off alarm number "Alarm". Defaults to 2 if Alarm is not 1.
  391.         // Leaves interrupt pin alone.
  392.         byte temp_buffer = readControlByte(0);
  393.         // modify control byte
  394.         if (Alarm == 1) {
  395.                 temp_buffer = temp_buffer & 0b11111110;
  396.         } else {
  397.                 temp_buffer = temp_buffer & 0b11111101;
  398.         }
  399.         writeControlByte(temp_buffer, 0);
  400. }
  401. bool DS3231::checkAlarmEnabled(byte Alarm) {
  402.         // Checks whether the given alarm is enabled.
  403.         byte result = 0x0;
  404.         byte temp_buffer = readControlByte(0);
  405.         if (Alarm == 1) {
  406.                 result = temp_buffer & 0b00000001;
  407.         } else {
  408.                 result = temp_buffer & 0b00000010;
  409.         }
  410.         return result;
  411. }
  412. bool DS3231::checkIfAlarm(byte Alarm) {
  413.         // Checks whether alarm 1 or alarm 2 flag is on, returns T/F accordingly.
  414.         // Turns flag off, also.
  415.         // defaults to checking alarm 2, unless Alarm == 1.
  416.         byte result;
  417.         byte temp_buffer = readControlByte(1);
  418.         if (Alarm == 1) {
  419.                 // Did alarm 1 go off?
  420.                 result = temp_buffer & 0b00000001;
  421.                 // clear flag
  422.                 temp_buffer = temp_buffer & 0b11111110;
  423.         } else {
  424.                 // Did alarm 2 go off?
  425.                 result = temp_buffer & 0b00000010;
  426.                 // clear flag
  427.                 temp_buffer = temp_buffer & 0b11111101;
  428.         }
  429.         writeControlByte(temp_buffer, 1);
  430.         return result;
  431. }
  432. void DS3231::enableOscillator(bool TF, bool battery, byte frequency) {
  433.         // turns oscillator on or off. True is on, false is off.
  434.         // if battery is true, turns on even for battery-only operation,
  435.         // otherwise turns off if Vcc is off.
  436.         // frequency must be 0, 1, 2, or 3.
  437.         // 0 = 1 Hz
  438.         // 1 = 1.024 kHz
  439.         // 2 = 4.096 kHz
  440.         // 3 = 8.192 kHz (Default if frequency byte is out of range)
  441.         if (frequency > 3) frequency = 3;
  442.         // read control byte in, but zero out current state of RS2 and RS1.
  443.         byte temp_buffer = readControlByte(0) & 0b11100111;
  444.         if (battery) {
  445.                 // turn on BBSQW flag
  446.                 temp_buffer = temp_buffer | 0b01000000;
  447.         } else {
  448.                 // turn off BBSQW flag
  449.                 temp_buffer = temp_buffer & 0b10111111;
  450.         }
  451.         if (TF) {
  452.                 // set ~EOSC to 0 and INTCN to zero.
  453.                 temp_buffer = temp_buffer & 0b01111011;
  454.         } else {
  455.                 // set ~EOSC to 1, leave INTCN as is.
  456.                 temp_buffer = temp_buffer | 0b10000000;
  457.         }
  458.         // shift frequency into bits 3 and 4 and set.
  459.         frequency = frequency << 3;
  460.         temp_buffer = temp_buffer | frequency;
  461.         // And write the control bits
  462.         writeControlByte(temp_buffer, 0);
  463. }
  464. void DS3231::enable32kHz(bool TF) {
  465.         // turn 32kHz pin on or off
  466.         byte temp_buffer = readControlByte(1);
  467.         if (TF) {
  468.                 // turn on 32kHz pin
  469.                 temp_buffer = temp_buffer | 0b00001000;
  470.         } else {
  471.                 // turn off 32kHz pin
  472.                 temp_buffer = temp_buffer & 0b11110111;
  473.         }
  474.         writeControlByte(temp_buffer, 1);
  475. }
  476. bool DS3231::oscillatorCheck() {
  477.         // Returns false if the oscillator has been off for some reason.
  478.         // If this is the case, the time is probably not correct.
  479.         byte temp_buffer = readControlByte(1);
  480.         bool result = true;
  481.         if (temp_buffer & 0b10000000) {
  482.                 // Oscillator Stop Flag (OSF) is set, so return false.
  483.                 result = false;
  484.         }
  485.         return result;
  486. }
  487. /*****************************************
  488.         Private Functions
  489. *****************************************/
  490. byte DS3231::decToBcd(byte val) {
  491. // Convert normal decimal numbers to binary coded decimal
  492.         return ( (val/10*16) + (val%10) );
  493. }
  494. byte DS3231::bcdToDec(byte val) {
  495. // Convert binary coded decimal to normal decimal numbers
  496.         return ( (val/16*10) + (val%16) );
  497. }
  498. byte DS3231::readControlByte(bool which) {
  499.         // Read selected control byte
  500.         // first byte (0) is 0x0e, second (1) is 0x0f
  501.         Wire.beginTransmission(CLOCK_ADDRESS);
  502.         if (which) {
  503.                 // second control byte
  504.                 Wire.write(uint8_t(0x0f));
  505.         } else {
  506.                 // first control byte
  507.                 Wire.write(uint8_t(0x0e));
  508.         }
  509.         Wire.endTransmission();
  510.         Wire.requestFrom(CLOCK_ADDRESS, 1);
  511.         return Wire.read();
  512. }
  513. void DS3231::writeControlByte(byte control, bool which) {
  514.         // Write the selected control byte.
  515.         // which=false -> 0x0e, true->0x0f.
  516.         Wire.beginTransmission(CLOCK_ADDRESS);
  517.         if (which) {
  518.                 Wire.write(uint8_t(0x0f));
  519.         } else {
  520.                 Wire.write(uint8_t(0x0e));
  521.         }
  522.         Wire.write(control);
  523.         Wire.endTransmission();
  524. }
DS3231.rar (498.21 KB, 下载次数: 164)
收藏收藏2 分享淘帖 顶 踩
ID:762132 发表于 2020-5-27 06:55 | 只看该作者
谢谢楼主提供
ID:279488 发表于 2020-6-7 05:32 | 只看该作者
好东西,感谢分享!!
ID:667692 发表于 2024-7-23 17:04 | 只看该作者
非常不错,值得分析借鉴,非常感谢分享。
