查看: 3889|回复: 0
Modbus协议用下面的函数写51单片机的程序怎么写
ID:298743 发表于 2018-4-4 22:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
350黑币
//说明:例子中的变量请自己根据习惯定义,Voltage_data~Pf_data等数据除以对应的倍率,就得到实际的值
用51怎么写主机程序来读取模块的信息?
  1. unsigned int calccrc(unsigned charcrcbuf,unsigned int crc)
  2. {
  3.        unsignedchar i;
  4.        unsignedchar chk;
  5.        crc=crc^ crcbuf;
  6.        for(i=0;i<8;i++)
  7.        {
  8.               chk=(unsigned char)(crc&1);
  9.               crc=crc>>1;
  10.               crc=crc&0x7fff;
  11.               if(chk==1)
  12.               crc=crc^0xa001;
  13.               crc=crc&0xffff;
  14.        }
  15.        returncrc;
  16. }
  17. unsigned int chkcrc(unsigned char*buf,unsigned char len)
  18. {
  19.        unsignedchar hi,lo;
  20.        unsignedint i;
  21.        unsignedint crc;
  22.        crc=0xFFFF;
  23.        for(i=0;i<len;i++)
  24.        {
  25.              crc=calccrc(*buf,crc);
  26.               buf++;
  27.        }
  28.        hi=(unsigned char)(crc%256);
  29.        lo=(unsigned char)(crc/256);
  30.        crc=(((unsignedint)(hi))<<8)|lo;
  31.        returncrc;
  32. }
  33. void read_data(void)
  34. {
  35.        union      crcdata
  36.       {
  37.               unsignedint word16;
  38.               unsignedchar  byte[2];
  39.        }crcnow;
  40.        if((Clock.Second%2)==1)   //2秒读一次
  41.        {
  42.               Tx_Buffer[0]=Read_ID;   //抄读模块的ID号
  43.               Tx_Buffer[1]=0x03;
  44.               Tx_Buffer[2]=0x00;
  45.               Tx_Buffer[3]=0x48;
  46.               Tx_Buffer[4]=0x00;
  47.               Tx_Buffer[5]=0x06;
  48.               crcnow.word16=chkcrc(Tx_Buffer,6);
  49.               Tx_Buffer[6]=crcnow.byte[1];    //CRC效验低字节在前
  50.               Tx_Buffer[7]=crcnow.byte[0];
  51.               Send_data(8);   //发送8个数据,请根据单片机类型自己编程
  52.        }
  53. }
  54. void Analysis_data(void)
  55. {
  56.        unsignedchar i;
  57.        union      crcdata
  58.       {
  59.               unsignedint word16;
  60.               unsignedchar  byte[2];
  61.        }crcnow;
  62.        if(Comm[1].Status==2)  //接收完成
  63.        {
  64.               if(RX_Buffer[0]==Read_ID)  //确认ID正确
  65.               {
  66.                      crcnow.word16=chkcrc(RX_Buffer,Comm[1].nRx-2);  //Comm[1].nRx是接收数据长度
  67.                     if((crcnow.byte[0]==RX_Buffer[Comm[1].nRx-1])&&(crcnow.byte[1]==RX_Buffer[Comm[1].nRx-2]))   //CRC效验
  68.                     {
  69.                             Voltage_data=(((unsignedint)(RX_Buffer[3]))<<8)|RX_Buffer[4]; //Voltage_data为unsigned int型
  70.                             Current_data=(((unsignedint)(RX_Buffer[5]))<<8)|RX_Buffer[6]; //Current_data为unsigned int型
  71.                             Power_data=(((unsignedint)(RX_Buffer[7]))<<8)|RX_Buffer[8]; //Power_data为unsigned int型
  72.                             Energy_data=(((unsignedlong)(RX_Buffer[9]))<<24)|(((unsigned long)(RX_Buffer[10]))<<16)|(((unsignedlong)(RX_Buffer[11]))<<8)|RX_Buffer[12]; ////Energy_data为unsigned long型
  73.                             Pf_data=(((unsignedint)(RX_Buffer[13]))<<8)|RX_Buffer[14]; //Pf_data为unsigned int型
  74.                     }
  75.              }
  76.               Comm[1].Status=0; //切换回接收数据状态
  77.        }
  78. }
