查看: 5572|回复: 0
单片机计时器Keil源程序文件
ID:303185 发表于 2018-4-7 15:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include <reg52.h>
  2. sbit ADDR0 = P1^0;
  3. sbit ADDR1 = P1^1;
  4. sbit ADDR2 = P1^2;
  5. sbit ADDR3 = P1^3;
  6. sbit ENLED = P1^4;
  7.         unsigned char code image[10][8] = {
  8.     {0xFF,0xE7,0xDB,0xDB,0xDB,0xDB,0xDB,0xE7},  //动画帧1
  9.     {0xFF,0xE7,0xE3,0xE7,0xE7,0xE7,0xE7,0xC3},  //动画帧2
  10.     {0xFF,0xC3,0xDF,0xDF,0xC3,0xFB,0xFB,0xC3},  //动画帧3
  11.     {0xFF,0xC3,0xDF,0xDF,0xC3,0xDF,0xDF,0xC3},  //动画帧4
  12.     {0xFF,0xDB,0xDB,0xDB,0xC3,0xDF,0xDF,0xDF},  //动画帧5
  13.     {0xFF,0xC3,0xFB,0xFB,0xC3,0xDF,0xDF,0xC3},  //动画帧6
  14.     {0xFF,0xC3,0xFB,0xFB,0xC3,0xDB,0xDB,0xC3},  //动画帧7
  15.     {0xFF,0xC3,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF},  //动画帧8
  16.     {0xFF,0xC3,0xDB,0xDB,0xC3,0xDB,0xDB,0xC3},  //动画帧9
  17.     {0xFF,0xC3,0xDB,0xDB,0xC3,0xDF,0xDF,0xC3},  //动画帧10
  18. };
  19.    unsigned char led=0xff;
  20. unsigned char code LedChar[] = {  //数码管显示字符转换表
  21.     0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
  22.     0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
  23. };
  24. unsigned char LedBuff[6] = {  //数码管显示缓冲区,初值0xFF确保启动时都不亮
  25.     0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
  26. };
  27. unsigned int cnt = 0;  //记录T1中断次数
  28.          unsigned int cnt1=0;
  29. void main()
  30. {
  31.     char j;  //循环变量
  32.         unsigned char m=0;
  33.     unsigned long sec = 100000;  //记录经过的秒数,倒计时初值为999999+1
  34.     unsigned char buf[6];   //中间转换缓冲区
  35.         unsigned char dir = 0;   //定义移位方向变量dir,用于控制移位的方向
  36.     unsigned char shift = 0x01;
  37.     EA = 1;       //使能总中断
  38.     ENLED = 0;    //使能U3
  39.
  40.     TMOD = 0x01;  //设置T1为模式1
  41.     TH0  = 0xFC;  //为T1赋初值0xFC67,定时1ms
  42.     TL0  = 0x67;
  43.     ET0  = 1;     //使能T1中断
  44.     TR0  = 1;     //启动T1
  45.
  46.     while (1)
  47.     {
  48.         if(cnt1>=1000)
  49.         {           cnt1=0;
  50.         led=~shift;
  51.          if (dir == 0)             //移位方向变量为0时,左移
  52.         {
  53.             shift = shift << 1;   //循环移位变量左移1位
  54.             if (shift == 0x80)    //左移到最左端后,改变移位方向
  55.             {
  56.                 dir = 1;
  57.             }
  58.         }
  59.         else                      //移位方向变量不为0时,右移
  60.         {
  61.             shift = shift >> 1;   //循环移位变量右移1位
  62.             if (shift == 0x01)    //右移到最右端后,改变移位方向
  63.             {
  64.                 dir = 0;
  65.             }
  66.         }
  67.                 }
  68.         if (cnt >= 1000)  //判断T1溢出是否达到1000次
  69.         {
  70.             cnt = 0;      //达到1000次后计数值清零
  71.             sec--;        //秒计数自减1
  72.             //将sec按十进制位从低到高依次提取到buf数组中
  73.             buf[0] = sec%60%10;
  74.             buf[1] = sec%60/10;
  75.             buf[2] = sec%3600/60%10;
  76.             buf[3] = sec%3600/60/10;
  77.             buf[4] = sec/3600%24%10;
  78.             buf[5] = sec/3600%24/10;
  79.             //从最高为开始,遇到0不显示,遇到非0退出循环
  80.             for (j=5; j>=1; j--)
  81.             {
  82.                 if (buf[j] == 0)
  83.                     LedBuff[j] = 0xFF;
  84.                 else
  85.                     break;
  86.             }
  87.             //将剩余的有效数字位如实转换
  88.             for ( ; j>=0; j--)  //for()起始未对j操作,j即保持上个循环结束时的值
  89.             {
  90.                 LedBuff[j] = LedChar[buf[j]];
  91.             }
  92.         }
  93.     }
  94.
  95. }
  96. /* 定时器1中断服务函数 */
  97. void InterruptTimer1() interrupt 1
  98. {
  99.         static unsigned char i = 0;  //动态扫描的索引
  100.     static unsigned int tmr = 0;  //1s软件定时器
  101.     static unsigned char index = 0;  //图片刷新索引
  102.     TH0 = 0xfe;  //重新加载初值
  103.     TL0 = 0x33;
  104.     cnt++;
  105.         cnt1++;       //中断次数计数值加1
  106.     //以下代码完成数码管动态扫描刷新
  107.     P0 = 0xFF;   //显示消隐
  108.     switch (i)
  109.     {
  110.         case 0: ADDR3 = 1;ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break;
  111.         case 1: ADDR3 = 1;ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break;
  112.         case 2: ADDR3 = 1;ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]&0x7f; break;
  113.         case 3: ADDR3 = 1;ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break;
  114.         case 4: ADDR3 = 1;ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]&0x7f; break;
  115.         case 5: ADDR3 = 1;ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=LedBuff[5]; break;
  116.                 case 6: ADDR3 = 0;ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=image[index][0]; break;
  117.         case 7: ADDR3 = 0;ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=image[index][1]; break;
  118.         case 8: ADDR3 = 0;ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=image[index][2]; break;
  119.         case 9: ADDR3 = 0;ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=image[index][3]; break;
  120.         case 10:ADDR3 = 0;ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=image[index][4]; break;
  121.         case 11:ADDR3 = 0;ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=image[index][5]; break;
  122.         case 12:ADDR3 = 0;ADDR2=1; ADDR1=1; ADDR0=0; i++; P0=image[index][6]; break;
  123.         case 13:ADDR3 = 0;ADDR2=1; ADDR1=1; ADDR0=1; i++; P0=image[index][7]; break;
  124.                 case 14: ADDR3 = 1;ADDR2=1; ADDR1=1; ADDR0=0; i=0; P0=led; break;
  125.         default: break;
  126.     }
  127.         tmr++;
  128.     if (tmr >= 2000)  //达到1s时改变一次图片索引
  129.     {
  130.         tmr = 0;
  131.         index++;
  132.         if (index >= 10)  //图片索引达到10后归零
  133.         {
  134.             index = 0;
  135.         }
  136.     }
  137. }
下载:
计时器.rar (22.59 KB, 下载次数: 11)
