查看: 7104|回复: 2
基于数字相关的时栅信号处理设计LPC2138源程序及proteus仿真
这是我大三时的课程设计,设计要求如下:
1.时栅传感器模拟器:通过输入两路时间和空间的信号。
(1) 设计一路正弦载波信号模拟信号输出 sina * cos(wt)
(2) 设计一路余弦信号模拟信号输出     cosa *sin(wt)
    (3) 设计两路信号的合成模拟信号输出   sin(wt+a)
2. 设计数据采集模块。(要求整周期采样)
3.  ARM硬件接口电路设计:显示路和键盘电路
4. 软件设计:数字相关算法求解角度、显示、按键、A/D.
5.  proteus仿真和实做。希望对大家有用!
LPC2138单片机源程序如下:
  1. #include  "config.h"
  2. //#include  "LPC21xx.h"
  3. #include "math.h"
  4. //#define Fpclk 12000000
  5. //typedef unsigned char  uint8;                   /* defined for unsigned 8-bits integer variable         无符号8位整型变量  */
  6. //typedef signed   char  int8;                    /* defined for signed 8-bits integer variable                有符号8位整型变量  */
  7. //typedef unsigned short uint16;                  /* defined for unsigned 16-bits integer variable         无符号16位整型变量 */
  8. //typedef signed   short int16;                   /* defined for signed 16-bits integer variable                 有符号16位整型变量 */
  9. //typedef unsigned int   uint32;                  /* defined for unsigned 32-bits integer variable         无符号32位整型变量 */
  10. //typedef signed   int   int32;                   /* defined for signed 32-bits integer variable                 有符号32位整型变量 */
  11. //typedef float          fp32;                    /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
  12. //typedef double         fp64;                    /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
  13. #define IO_RS   0x1000000
  14. #define IO_RW   0x2000000
  15. #define IO_EN   0x4000000
  16. #define LED 0X01
  17. #define KEY1 (IO0PIN&(1<<20))
  18. #define KEY2 (IO0PIN&(1<<21))
  19.
  20. int32  k=0,ADC_Data,tt1,tt2;
  21. uint32 A=1,FG1=1,FG2=2;
  22. uint32 a,i,h,j,p,q,m,n,u,v;
  23. double c,s,data_1=0,data_2=0,data_3=0,data_4=0;
  24. double x,y,PI=3.141592653589793238462643383279502;
  25. int32 Buffer[256];
  26. double SINCE[19]={
  27. 0.0000,0.0872,0.1736,0.2588,0.3420,0.4226,
  28. 0.5000,0.5736,0.6428,0.7071,0.7660,0.8192,
  29. 0.8660,0.9063,0.9397,0.9659,0.9848,0.9962,
  30. 1.0000,
  31. };
  32. double COSCE[19]={
  33. 1.0000,0.9962,0.9848,0.9659,0.9397,0.9063,
  34. 0.8660,0.8192,0.7660,0.7071,0.6428,0.5736,
  35. 0.5000,0.4226,0.3420,0.2588,0.1736,0.0872,
  36. 0.0000,
  37. };
  38.
  39. const int16 sindata[]={
  40. 0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,
  41. 0x98,0x9b,0x9e,0xa1,0xa4,0xa7,0xaa,0xad,
  42. …………
  43. …………限于本文篇幅 余下代码请从51黑下载附件…………
  44. 0xfc,0xfd,0xfd,0xfe,0xfe,0xfe,0xfe,0xfe,
  45. };
  46. #define RS_1    IO1SET=(IO_RS&0xFFFFFFFF)
  47. #define RS_0    IO1CLR=(IO_RS&0xFFFFFFFF)
  48. #define RW_1    IO1SET=(IO_RW&0xFFFFFFFF)
  49. #define RW_0    IO1CLR=(IO_RW&0xFFFFFFFF)
  50. #define EN_1    IO1SET=(IO_EN&0xFFFFFFFF)
  51. #define EN_0    IO1CLR=(IO_EN&0xFFFFFFFF)
  52. void delayms(unsigned int t)
  53. {
  54.         unsigned char u,v;
  55.         for(u=0;u<100;u++)
  56.          for(v=0;v<81;v++);
  57. }
  58. void LCD_write_com(unsigned char com)              //LCD写入命令函数
  59. {
  60.         RS_0;
  61.         RW_0;
  62.         EN_1;
  63.         IO1SET=com<<16;
  64.         delayms(5);
  65.         EN_0;
  66.         IO1CLR=0xFF0000;
  67. }
  68. void LCD_write_data(unsigned char data)           //写入数据函数
  69. {
  70.         RS_1;
  71.   RW_0;
  72.   EN_1;
  73.   IO1SET=data<<16;
  74.         delayms(5);
  75.   EN_0;
  76.         IO1CLR=0xFF0000;
  77. }
  78. void LCD_clear()                                  //LCD清屏函数
  79. {
  80.         LCD_write_com(0x01);
  81.         delayms(5);
  82. }
  83. void LCD_write_char(unsigned char x,unsigned char y,unsigned char s)    //写入字符函数
  84. {
  85. if (y == 0)
  86.          {
  87.          LCD_write_com(0x80+x);
  88.          }
  89. else
  90.          {
  91.          LCD_write_com(0xC0+x);
  92.          }
  93. LCD_write_data(s);
  94. }
  95. void LCD_write_string(unsigned char x,unsigned char y,unsigned char *s)   //写入字符串函数
  96. {
  97. if (y == 0)
  98.          {
  99.          LCD_write_com(0x80 + x);     //表示第一行
  100.          }
  101. else
  102.          {
  103.          LCD_write_com(0xC0 + x);      //表示第二行
  104.          }
  105. while (*s)
  106.          {
  107.     LCD_write_data( *s);
  108.     s++;
  109.          }
  110. }
  111. void LCD_init()      //LCD初始化
  112. {
  113.         LCD_write_com(0x38);          //显示模式设置
  114.         delayms(5);
  115.         LCD_write_com(0x38);
  116.         delayms(5);
  117.         LCD_write_com(0x38);
  118.         delayms(5);
  119.         LCD_write_com(0x38);
  120.         LCD_write_com(0x08);               //显示关闭
  121.         LCD_write_com(0x01);         //清屏
  122.         LCD_write_com(0x06);         //显示光标移动设置
  123.         delayms(5);
  124.         LCD_write_com(0x0C);         //显示开及光标设置
  125.
  126. }
  127. /*
  128. void  UART0Init(uint32 bps)
  129. {
  130.     uint16 Fdiv;
  131.     PINSEL0 = (PINSEL0 & (~0x0F)) | 0x05;
  132.     U0LCR = 0x83;
  133.     Fdiv = (Fpclk / 16) / bps;
  134.     U0DLM = Fdiv / 256;
  135.     U0DLL = Fdiv % 256;
  136.     U0LCR = 0x03;
  137. }
  138. */
  139.    void __irq IRQ_Timer0 (void)
  140. {
  141. //            for(i=0;i<256;i++)
  142. //            {
  143. //                                y=COSCE[a];
  144. //                                x=SINCE[a];
  145. //                                s=(y*sindata[i]);
  146. //                                c=(x*cosdata[i]);
  147. //
  148. //                                sindata[i]=sin(2.0*acos(-1.0)/256*i);
  149. //                                cosdata[i]=cos(2.0*acos(-1.0)/256*i);
  150. //
  151. //                                h=(s*0x1ff+0x1ff);
  152. //                                h=s+c;
  153. //                                DACR=((sindata[i]<<6))|(1<<16);
  154. //                                for(j=0;j<0x20;j++);
  155.
  156.                         if((IO0PIN&KEY1)==0)
  157.        {
  158.                            if(FG1!=(A-5))
  159.                            {
  160.                                FG1=A;A+=5;i=0;
  161.                                            if(A>360) A=0;
  162.                            }
  163.                          }
  164.
  165.       if((IO0PIN&KEY1)!=0){ FG1=1; }
  166.                           a=A*180/PI;
  167.                   if((IO0PIN&KEY2)==0)
  168.        {
  169.                              if(FG2!=(A+5))
  170.                          {FG2=A;A-=5;i=0;
  171.                          if(A>360)A=0;}
  172.                          }
  173.                         if((IO0PIN&KEY2)!=0){ FG2=1; }
  174.                         if(A<=90)   a=A/5;
  175.                         if(A>90&A<=180)  a=36-A/5;
  176.                         if(A>180&A<270)  a=A/5-36;
  177.                         if(A>=270&A<360) a=72-A/5;
  178.
  179.                         y=COSCE[a];
  180.                   x=SINCE[a];
  181.                         s=(y*sindata[i]);
  182.                         c=(x*cosdata[i]);
  183.
  184. //                        sindata[i]=sin(2.0*acos(-1.0)/256*i);
  185. //                        cosdata[i]=cos(2.0*acos(-1.0)/256*i);
  186.
  187. //                        h=(s*0x1ff+0x1ff);
  188.                         h=s+c;
  189.                         DACR=((h<<6))|(1<<16);
  190.                         for(j=0;j<0x20;j++);
  191.
  192.
  193.                         AD0CR = (AD0CR&0x00FFFF00)|0x01|(1 << 24);        // 设置AD0.0,并进行第一次转换
  194.                         while( (AD0DR&0x80000000)==0 );                    // 等待转换结束
  195.                         ADC_Data = AD0DR;                                                        // 读取ADC结果
  196.                         ADC_Data = (ADC_Data>>6) & 0x3FF;           // 提取AD转换值
  197.
  198.                         Buffer[i]=ADC_Data;
  199.
  200.            LCD_write_char(9,0,A/100%10+0X30);
  201.            LCD_write_char(10,0,A/10%10+0X30);
  202.            LCD_write_char(11,0,A%10+0X30);
  203.                 for(u=0;u<256;u++)
  204.                 {
  205.                         data_1 = data_1 +(Buffer[u]-0x7f)*(cosdata[u]-0x7f)/256;//-5170)*PI/128;
  206.                         data_2 = data_2 +(Buffer[u]-0x7f)*(sindata[u]-0x7f)/256;//-5170)*PI/128;
  207.                 }
  208.                         data_4 = atan(data_1 /data_2)*180/acos(-1.0);
  209.                         tt1=data_4*10;//1;
  210.
  211.                         if(A>90&A<180)   tt1=1800-tt1;
  212.                         if(A>180&A<270)  tt1=1800+tt1;
  213.                         if(A>270&A<360)  tt1=3600-tt1;
  214.
  215.                         LCD_write_char(9,1,tt1/1000%10+0X30);
  216.                         LCD_write_char(10,1,tt1/100%10+0X30);
  217.                         LCD_write_char(11,1,tt1/10%10+0X30);
  218.                         LCD_write_char(12,1,'.');
  219.                         LCD_write_char(13,1,tt1%10+0X30);
  220.
  221. //        LCD_write_char(6,1,tt2/1000%10+0X30);
  222. //        LCD_write_char(7,1,tt2/100%10+0X30);
  223. //    LCD_write_char(8,1,tt2/10%10+0X30);
  224. //    LCD_write_char(9,1,'.');
  225. //        LCD_write_char(10,1,tt2%10+0X30);
  226.     i++;
  227.     if(i>=256) i=0;
  228.           T0IR = 0x02;                                /* 清除中断标志        */
  229.           VICVectAddr = 0x00;                        /* 通知VIC中断处理结束                                                        */
  230. //}
  231. }
  232. void  Time0Init(void)
  233. {
  234.            T0TC   = 0;                              // 定时器T0初始化
  235.            T0PR = 10;              // 设置定时器0分频为100分频,得120000Hz
  236.     T0MCR = 0x03<<3;                // 匹配通道MR1匹配中断并复位TC
  237.           T0MR0 = Fpclk/12000;          // MR0比较值(0.5秒定时值)
  238.           T0MR1 = Fpclk/1200;          // MR1比较值(0.5秒定时值)
  239.     T0EMR = 0x30;                    // 设置定时器0的MR0匹配输出,输出方式为翻转
  240.           T0TCR = 0x03;           // 启动并复位T0TC
  241.           T0TCR = 0x01;
  242.     T0IR = 0x02;
  243.    /* 设置定时器0中断IRQ */
  244.    VICIntSelect = 0x00;                                        // 所有中断通道设置为IRQ中断
  245.    VICVectCntl0 = 0x20 | 0x04;                         // 分配定时器0中断到通道0(最高优先级)
  246.    VICVectAddr0 = (uint32)IRQ_Timer0;         // 设置中断服务程序地址向量
  247.    VICIntEnable = (1<<4);                    // 使能定时器0中断
  248. //   IRQEnable();                                                 // 使能IRQ中断
  249. }
  250. int  main(void)
  251. {
  252.     PINSEL0|=0x00000000;
  253.            PINSEL1 |= 0x01400000;
  254.           PINSEL1 = (PINSEL1&(~(0x03<<18))) | (0x02<<18); // P0.25 连接Aout
  255. //    UART0Init(9600);
  256.     IO0DIR|=0X01;
  257.           IO1DIR|=0x07ff0000;
  258.            LCD_init();
  259.           Time0Init();
  260.     AD0CR = (1 << 0)                    |
  261.            ((Fpclk / 1000000 - 1) << 8) |
  262.            (0 << 16)                    |
  263.            (0 << 17)                    |
  264.            (1 << 21)                    |
  265.            (0 << 22)                    |
  266.            (1 << 24)                    |
  267.            (0 << 27);
  268.     delayms(10);
  269.     ADC_Data = AD0DR;
  270.           LCD_write_string(0,0,"in:");
  271.           LCD_write_string(0,1,"out:");
  272.
  273.     while(1)
  274.     {
  275. //                   y=COSCE[a];
  276. //                                x=SINCE[a];
  277. //                                s=(y*sindata[i]);
  278. //                                c=(x*cosdata[i]);
  279.
  280. //                                sindata[i]=sin(2.0*acos(-1.0)/256*i);
  281. //                                cosdata[i]=cos(2.0*acos(-1.0)/256*i);
  282.
  283. ……………………
  284. …………限于本文篇幅 余下代码请从51黑下载附件…………
数字信号处理课程设计.zip (343.14 KB, 下载次数: 77)
收藏收藏2 分享淘帖 顶顶 踩踩
ID:858959 发表于 2021-3-27 20:50 来自触屏版 | 只看该作者
有错误,不能直接使用
需要修改,不知道是电路问题还是代码问题
