查看: 1432|回复: 0
计算器设计JAVA
ID:306754 发表于 2018-4-12 17:23 | 显示全部楼层 |阅读模式
package Calculator;
import java.util.*;
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
public class Calculator{
   public static void main(String[] args){
  new  Interface();
class Interface extends JFrame {
   ArrayList<String> list = new ArrayList<String>();//用来存该运算中的数,以及运算结果,由文本编辑框得到
   ArrayList<String> lists = new ArrayList<String>();//用来存该运算中使用了的运算符,当点击运算符按钮存起集合lists
   int cout = 0;                                     //计数运算符,用来作为集合中各元素的下标
   JPanel inputpanel;                                //GUI组件的布局包括如下三个过程:1。创建面板,确定面板中的布局管理
   JTextField inputField;                            //                     2.给面板添加标签
   JButton button;                                   //                     3.为面板添加按钮,文本编辑框等组件
   JButton btn1,btn2,btn3,btn4;
   JButton btn5,btn6,btn7,btn8;
   JButton btn9,btn10,btn11,btn12;
   JButton btn13,btn14,btn15,btn16;
   public Interface(){
inputpanel = new JPanel();
inputField = new JTextField(9);               //文本框长度为9
button = new JButton("清零");
inputpanel.add(inputField);
inputpanel.add(button);
this.add(inputpanel);
JPanel panel = new JPanel(new GridLayout(4,4));//设置panel面板的布局管理为GridLayout管理器,为一个4*4的网格
btn1 = new JButton("7");
btn2 = new JButton("8");
btn3 = new JButton("9");
btn4 = new JButton("+");
btn5 = new JButton("4");
btn6 = new JButton("5");
btn7 = new JButton("6");
btn8 = new JButton("-");
btn9 = new JButton("1");
btn10 = new JButton("2");
btn11 = new JButton("3");
btn12 = new JButton("×");
btn13 = new JButton("0");
btn14 = new JButton(".");
btn15 = new JButton("=");
btn16 = new JButton("÷");  //定义Button按钮
panel.add(btn1);
panel.add(btn2);
panel.add(btn3);
panel.add(btn4);
panel.add(btn5);
      panel.add(btn6);
panel.add(btn7);
panel.add(btn8);
      panel.add(btn9);
      panel.add(btn10);
      panel.add(btn11);
      panel.add(btn12);
      panel.add(btn13);
panel.add(btn14);
panel.add(btn15);
panel.add(btn16);            //将按钮添加进panel面板
btn1.addActionListener(new ActionListener () {
public void actionPerformed(ActionEvent e){
    inputField.setText(inputField.getText()+"7");
btn2.addActionListener(new ActionListener () {
inputField.setText(inputField.getText()+"8");
btn3.addActionListener(new ActionListener () {
inputField.setText(inputField.getText()+"9");
btn5.addActionListener(new ActionListener () {
    inputField.setText(inputField.getText()+"4");
btn6.addActionListener(new ActionListener () {
inputField.setText(inputField.getText()+"5" );
btn7.addActionListener(new ActionListener () {
inputField.setText(inputField.getText()+"6");
btn9.addActionListener(new ActionListener () {
   inputField.setText(inputField.getText()+"1");
btn10.addActionListener(new ActionListener () {
inputField.setText(inputField.getText()+"2");
btn11.addActionListener(new ActionListener () {
inputField.setText(inputField.getText()+"3");
btn13.addActionListener(new ActionListener () {
inputField.setText(inputField.getText()+"0");
btn14.addActionListener(new ActionListener () {
inputField.setText(inputField.getText()+".");
});                    //为数字按钮和小数点按钮添加点击事件,点击之后按钮所代表数字显示在文本编辑框
btn4.addActionListener(new ActionListener () {
list.add(inputField.getText()); //运算的实现,获取在文本编辑框上显示的文本,并存入集合list中
lists.add("+");     //获取运算符,存入lists中
cout++;             //标记运算符的个数,也就是要进行运算的次数
inputField.setText("");
//将编辑框置为空的,方便下一个数据的额输入
btn8.addActionListener(new ActionListener () {
lists.add("-");
cout++;
     btn12.addActionListener(new ActionListener () {
lists.add("×");
cout++;
btn16.addActionListener(new ActionListener () {
lists.add("÷");
cout++;
btn15.addActionListener(new ActionListener () {
list.add(inputField.getText());           //点击按钮=时,把此事编辑框显示的数据存入list
inputField.setText(Operator(lists.get(cout-1)));//把运算得到的结果存入list,作为下一个运算符运算的前一个数
button.addActionListener(new ActionListener () {
   list.clear();
   //将list和lists集合保存的上一次运算的各要素清空
lists.clear();
cout = 0;              //把cout的值还原
this.add(panel);
     this.setTitle("计算器");
     this.setSize(185,205);
     this.setLayout(new FlowLayout());
     this.setVisible(true);                 //GUI窗体
public String  Operator(String str){
Double result = 0.0 ;
Double a = Double.parseDouble(list.get(2*cout-2));//将list中记录的第一个运算符前一个数据转化为Double类型
Double b = Double.parseDouble(list.get(2*cout-1));//将list中记录的第一个运算符后一个数据转化为Double类型
switch(str){                                      //cout表示第几个字符
case "+" : result = a + b;
          break;
case "-" : result = a - b;
               break;
case "×" : result = a * b;
               break;
case "÷" : result = a / b;
               break;
String res = String.valueOf(result);
return res; //通过switch语句得到各种运算之后的返回值并转化为String类型
