查看: 2086|回复: 1
单片机控制点阵 为什么我这个函数正确,却不能正确显示0啊
ID:261485 发表于 2018-4-13 08:26 来自触屏版 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. typedef unsigned char u8;
  4. typedef unsigned int u16;
  5. sbit SRCLK=P3^6;                 //宏定义sbit RCLK=P3^5;
  6. sbit SER=P3^4;
  7. void delay(u16 i)                  //延时函数
  8. {
  9. while(i--);
  10. }
  11. u8 ledduan[]=(0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00);                  //段选   横向选中一排
  12. u8 ledwei[]=(0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfb,0xfe);                  //位选   纵向选中一列
  13. void hc595sendbaty(u8 dat)
  14. {      u8 a;
  15. SRCLK=0;                                 //为上升沿做准备          RCLK=0;                                           for(a=0;a<8;a++)          {}   SER=dat>>7;
  16.    dat<<=1;
  17.    SRCLK=1;                                 //产生上升沿                   _nop_();
  18.    _nop_();
  19.    SRCLK=0;                                 //为下一个上升沿做准备          }
  20.           RCLK=1;
  21.   _nop_();
  22.   _nop_();
  23.   RCLK=0;}void main()
  24. {    u8 i;    P0=0x7f;                   //不理解为什么要先点亮第一排??
  25. while(1)                {                                                              for(i=0;i<8;i++)
  26.         {    P0=ledwei[i];                        hc595sendbaty(ledduan[i]);                        delay(100);
  27.         hc595sendbaty(0x00);                }                 }          }
ID:164602 发表于 2018-4-13 09:52 | 只看该作者
你的程序正确才怪!!!!!
第一:编译有错:RCLK没申明。所以没能编译出可执行文件.HEX,你真的下载起了?那么就不是这个程序,当然不会显示正确了。
第二:主函数都没有,还说“函数正确”
不知道是不是你没有发全部程序。显示0的程序我也有一个,看看吧。
#include<reg51.h>
#include<intrins.h>
sbit SRCLK=P3^6;
sbit RCLK=P3^5;
sbit SER=P3^4;
unsigned char code TAB[8]  = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
unsigned char code CHARCODE[20][8]=
{0x00,0x00,0x00,0x3E,0x41,0x41,0x41,0x3E}, //0
{0x00,0x00,0x00,0x00,0x21,0x7F,0x01,0x00}, //1
{0x00,0x00,0x00,0x21,0x43,0x45,0x49,0x31}, //2
{0x00,0x00,0x00,0x42,0x41,0x51,0x69,0x46}, //3
{0x00,0x00,0x00,0x0C,0x14,0x24,0x7F,0x04}, //4
{0x00,0x00,0x00,0x72,0x51,0x51,0x51,0x4E}, //5
{0x00,0x00,0x00,0x1E,0x29,0x49,0x49,0x06}, //6
{0x00,0x00,0x00,0x40,0x40,0x4F,0x50,0x60}, //7
{0x00,0x00,0x00,0x36,0x49,0x49,0x49,0x36}, //8
{0x00,0x00,0x00,0x30,0x49,0x49,0x4A,0x3C}, //9
{0x00,0x00,0x01,0x1F,0xE4,0x3C,0x07,0x01}, //A
{0x00,0x00,0x00,0x81,0xFF,0x91,0x91,0x6e}, //B
{0x00,0x00,0x00,0x7E,0x81,0x81,0x81,0xc2}, //C
{0x00,0x00,0x00,0x81,0xFF,0x81,0x81,0x7e}, //D
{0x00,0x00,0x00,0x81,0xFF,0x91,0xb9,0xc3}, //E
{0x00,0x00,0x00,0x81,0xFF,0x91,0xb8,0xc0}, //F
{0x00,0x00,0x3C,0x42,0x81,0x89,0xce,0x08}, //G
{0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00},  //中
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},  //全灭
{0x3C,0x62,0xB1,0xAB,0x87,0xB1,0x62,0x3C}//人脸
void delay(unsigned int time)//0.0001766s延时,约0.2ms
  unsigned int j;
  for(time;time>0;time--)
    for(j=0;j<20;j++);
void Hc595SendByte(unsigned char dat)
        unsigned char a;
        SRCLK=0;
        RCLK=0;
        for(a=0;a<8;a++)
                if ((dat<<a)&0x80)
                        SER=1;
                        SER=0;
                SRCLK=1;
                _nop_();
                _nop_();
                SRCLK=0;
        RCLK=1;
        _nop_();
        _nop_();
        RCLK=0;
void main ()
        unsigned char i,j,k;
        P0=0xff;
        while (1)
                for (i=0;i<20;i++)
                        for (j=0;j<100;j++)
                                for (k=0;k<8;k++)
                                        P0=0xff;
                                        Hc595SendByte(CHARCODE[i][k]);
                                        P0=TAB[k];
                                        delay(5);
