查看: 3639|回复: 2
基于单片机的数字式电能表
ID:308098 发表于 2018-4-14 17:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<REG52.H>
unsigned char code command[6][7]={
                                 0xB0,0xC0,0xA8,0x01,0x01,0x00,0x1A,//读取电压值
                                 0xB1,0xC0,0xA8,0x01,0x01,0x00,0x1B,//读取电流值
                                 0xB3,0xC0,0xA8,0x01,0x01,0x00,0x1D,//读取电量值
                                 0x7e,0x05,0x41,0x00,0x04,0x40,0xef,
                                 0x7e,0x05,0x41,0x00,0x05,0x41,0xef,
                                 0x7e,0x05,0x41,0x00,0x06,0x42,0xef
                                };//串口控制音乐指令
uchar shuju[8];
uchar jishu=0;
uchar CRC=0;
uchar j=0;
long  AA=0;
uint BB=0;
uint CC;
//******************LCD1602****************************//
sbit lcden=P1^2;
sbit lcdrw=P1^1;
sbit lcdrs=P1^0;
//////////////LCD1602///////////////////////////////////////
void delay1(uint z)
    uint x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void write_com(uchar com)
    lcdrs=0;
    P0=com;
    delay1(5);
    lcden=1;
    delay1(5);
    lcden=0;
void write_data(uchar date)
    lcdrs=1;
    P0=date;
    delay1(5);
    lcden=1;
    delay1(5);
    lcden=0;
void init1602()
    lcden=0;
    write_com(0x38);
    write_com(0x0c);//    write_com(0x0e);
    write_com(0x06);
    write_com(0x01);
    write_com(0x80+2);
///////////////LCD1602
void SendASC(uchar d)    //串口发送字符
    SBUF=d;                //数据赋值到缓冲区
    while(!TI);            //发送完
    TI=0;                //清零
void deal(void)
  //电压读取
           jishu=0;
           for(j=0;j<7;j++)
            {    shuju[j]=0;
                  SendASC(command[0][j]);
            delay1(200);
            delay1(20);
            if(jishu>0)
              {      CRC=0;
                  for(j=0;j<6;j++)
                       CRC=CRC+shuju[j];
                  if((CRC==shuju[6])&&(shuju[0]==0xa0))
                          AA=shuju[1]*256+shuju[2];
                          write_com(0x80+0x40);
                          if(AA>=100)
                               write_data(AA/100+0x30);
                          else write_data(' ');
                          delay1(20);
                          write_data(AA%100/10+0x30);
                          delay1(20);
                          write_data(AA%10+0x30);
                          delay1(20);
                          write_data('.');
                          delay1(20);
                          write_data(shuju[3]+0x30);
                          delay1(20);
                          write_data('V');
                          delay1(20);
   //电流读取
           jishu=0;
           for(j=0;j<7;j++)
            {    shuju[j]=0;
                  SendASC(command[1][j]);
            delay1(200);
            if(jishu>0)
              {      CRC=0;
                  for(j=0;j<6;j++)
                       CRC=CRC+shuju[j];
                  if((CRC==shuju[6])&&(shuju[0]==0xa1))
                          AA=shuju[2];
                          write_com(0x80+0x40+9);
                          if(AA>=100)
                          delay1(20);
                          delay1(20);
                          delay1(20);
                          write_data('.');
                          delay1(20);
                          write_data(shuju[3]/10+0x30);
                          delay1(20);
                          write_data(shuju[3]%10+0x30);
                          delay1(20);
                          write_data('A');
                          delay1(20);
    //电量读取
           jishu=0;
           for(j=0;j<7;j++)
            {    shuju[j]=0;
                  SendASC(command[2][j]);
            delay1(200);
            if(jishu>0)
              {      CRC=0;
                  for(j=0;j<6;j++)
                       CRC=CRC+shuju[j];
                  if((CRC==shuju[6])&&(shuju[0]==0xa3))
                          AA=shuju[1];
                          AA=AA<<16;
                          AA=AA+shuju[2]*256;
                          AA=AA+shuju[3];
                          write_com(0x80);
                          if(AA>=1000000)
                               write_data(AA/1000000+0x30);
                          delay1(20);
                          if(AA>=100000)
                               write_data(AA%1000000/100000+0x30);
                          delay1(20);
                          if(AA>=10000)
                               write_data(AA%100000/10000+0x30);
                          delay1(20);
                          if(AA>=1000)
                               write_data(AA%10000/1000+0x30);
                          delay1(20);
                          if(AA>=100)
                               write_data(AA%1000/100+0x30);
                          delay1(20);
                          if(AA>=10)
                          delay1(20);
                          delay1(20);
                          write_data('W');
                          delay1(20);
                          write_data('H');
                          delay1(20);
void main(void)
  lcdrw=0;
  init1602();
  //串口通信
   TMOD=0x21;//?????0?????1
   TH1=0Xfd;
   TL1=0Xfd;        //9600波特率
   TR1=1;             // 定时器1启动
   SM0=0;        // 设置串口的工作模式
   SM1=1;         //方式1
   REN=1;          // 允许串口接收数据
   ES=1;          // 串口中断应许
   EA=1;
            deal();
void ser() interrupt 4
    if(RI)
        RI=0;
        shuju[jishu++]=SBUF;
        if(jishu>7)
            jishu=0;
ID:313732 发表于 2018-4-25 17:25 | 只看该作者
小白在做设计,有没有仿真图啊
ID:1115953 发表于 2024-4-10 14:05 | 只看该作者
静净 发表于 2018-4-25 17:25
小白在做设计,有没有仿真图啊
哥给看看仿真图,我现在才做DIY小玩意,遇到难点了
