查看: 2223|回复: 2
想要数码管从0到f切换,但是没成功
ID:304233 发表于 2018-4-14 20:59 | 显示全部楼层 |阅读模式
AT89C52.pdf (596.3 KB, 下载次数: 6)
原理图QX-mini51.pdf (154.08 KB, 下载次数: 5)
程序①:
#include<reg52.h>
sbit P2_0 = P2^0;
sbit P2_1 = P2^1;
sbit P2_2 = P2^2;
sbit P2_3 = P2^3;
uchar num;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(uint z);
  for(num=0;num<16;num++)
    P0=table[num];
    P2_0=0;
    P2_0=1;
    P0=table[num];
    P2_1=0;
    P2_1=1;
    P0=table[num];
    P2_2=0;
    P2_2=1;
    P0=table[num];
    P2_3=0;
    P2_3=1;
    delay(1000);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
程序②:
#include <reg52.h>
sbit P2_0 = P2^0;
sbit P2_1 = P2^1;
sbit P2_2 = P2^2;
sbit P2_3 = P2^3;
uchar num;
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,
                        0xf8,0x80,0x90};
void delay(uint z);
     P0=table[num];
     P2_0 = 0;
     P2_0 = 1;
     P0=table[num];
     P2_1 = 0;
     P2_1 = 1;
     P0=table[num];
     P2_2 = 0;
     P2_2 = 1;
     P0=table[num];
     P2_3 = 0;
     P2_3 = 1;
     delay(1000);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
ID:213173 发表于 2018-4-15 07:04 | 显示全部楼层
4个数码管显示相同数字
#include <reg52.h>
uchar code table[]={                //共阳数码管段码"0~f"
                0x99,0x92,0x82,0xf8,
                0x80,0x90,0x88,0x83,
                0xc6,0xa1,0x86,0x8e};
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
          for(y=110;y>0;y--);
        uchar num;
        P2 &= 0xf0;
             P0=table[num];
             delay(1000);
ID:304233 发表于 2018-4-15 22:21 来自触屏版 | 显示全部楼层
wulin 发表于 2018-4-15 07:04
4个数码管显示相同数字
#include
谢谢你!
