查看: 7844|回复: 4
基于热敏电阻的单片机温度测量系统设计源码与电路图
ID:308992 发表于 2018-4-16 09:33 | 显示全部楼层 |阅读模式
本课题用一种基于单片机的数据采集系统方案,该方案根据热敏电阻随温度变化而变化的特性,采用串联分压电路。单片机采集热敏电阻的电压,通过A/D转换将模拟量电压信号转换成数字量电压信号,经过查表转换得到温度值,控制液晶屏实时显示温度值。本系统中所用到的器件是STC89C52单片机、NTC热敏电阻和LCD1602液晶显示屏。
原理图如下
图1 总体电路原理图
图1 总体电路原理图
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. sbit rs=P0^5;
  6. sbit rw=P0^6;
  7. sbit e=        P0^7;
  8. sbit ADCS=P1^0;
  9. sbit ADCLK=P1^1;
  10. sbit ADDI=P1^2;
  11. sbit ADDO=P1^2;
  12. uchar code tab3[]="Low-temperature ";
  13. uchar code tab4[]="Over-temperature";
  14. uchar code tab5[]="     Error      ";
  15. uchar code tab6[]="  Temp:";
  16. uchar code tab7[]="     Normal     ";
  17. uchar code tab1[]="0123456789";
  18. uchar code tab2[]=
  19.           {79,78,77,76,75,74,73,72,                   //温度补偿表
  20.            71,70,69,68,67,67,66,65,
  21.            64,63,63,62,61,60,60,59,
  22.            58,58,57,56,56,55,54,54,
  23.            53,53,52,52,51,50,50,49,
  24.            49,48,48,47,47,46,46,45,
  25.            45,44,44,43,43,43,42,42,
  26.            41,41,40,40,39,39,39,38,
  27.            38,37,37,36,36,36,35,35,
  28.            34,34,34,33,33,33,32,32,
  29.            31,31,31,30,30,30,29,29,
  30.            28,28,28,27,27,27,26,26,
  31.            26,26,25,25,24,24,23,23,
  32.            23,22,22,22,21,21,21,20,
  33.            20,20,19,19,19,18,18,18,
  34.            17,17,17,16,16,16,15,15,
  35.            15,14,14,13,13,13,12,12,
  36.            12,11,11,11,10,10,10,9,
  37.            9,9,8,8,7,7,7,6,
  38.            6,6,5,5,4,4,4,3,
  39.            3,3,2,2,1,1,1,0,
  40.            0,1,1,2,2,2,3,3,
  41.            4,4,5,5,6,6,7,7,
  42.            8,8,9,9,10,10,11,11,
  43.            12,12,13,14,15,15,16,17,
  44.            17,18,19,19,20};
  45. uint ad,ad1;
  46. //*********延时50us*t*******************
  47. void delay_50us(uint t)
  48. {
  49.         uchar j,z;
  50.         for(z=t;z>0;z--)
  51.                 for(j=19;j>0;j--);
  52. }
  53. //**************************************
  54. //**********延时1ms*z*******************
  55. void delay(uint z)
  56. {
  57.     uint x,y;
  58.     for(x=z;x>0;x--)
  59.         for(y=110;y>0;y--);
  60. }
  61. //**************************************
  62. //*********写指令****************
  63. void write_com(uchar com1)
  64. {
  65.         e=0;
  66.         rs=0;
  67.         rw=0;
  68.         P2=com1;
  69.         delay_50us(10);
  70.     e=1;
  71.         delay_50us(20);
  72.         e=0;
  73. }
  74. //**********写数据*******************
  75. void write_data(uchar dat1)
  76. {
  77.     e=0;
  78.     rs=1;
  79.     rw=0;
  80.     P2=dat1;
  81.     delay_50us(10);
  82.     e=1;
  83.     delay_50us(20);
  84.     e=0;
  85. }
  86. //*****液晶初始化*******************
  87. void lcd1602init()
  88. {
  89.         delay_50us(300);
  90.         write_com(0x38);
  91.         write_com(0x08);
  92.         write_com(0x01);
  93.     write_com(0x06);
  94.         write_com(0x0c);
  95. }
  96. //***********AD转换模块**************
  97. uint ADC0832(uchar channel)
  98. {
  99.         uchar i;
  100.         uint dat=0;
  101.         uchar ndat=0;
  102.         if(channel==0)channel=2;
  103.         if(channel==1)channel=3;
  104.         ADDI=1;
  105.         _nop_();
  106.         _nop_();
  107.         ADCS=0;//拉低CS端
  108.         _nop_();
  109.         _nop_();
  110.         ADCLK=1;//拉高CLK端
  111.         _nop_();
  112.         _nop_();
  113.         ADCLK=0;//拉低CLK端,形成下降沿1
  114.         _nop_();
  115.         _nop_();
  116.         ADCLK=1;//拉高CLK端
  117.         ADDI=channel&0x1;
  118.         _nop_();
  119.         _nop_();
  120.         ADCLK=0;//拉低CLK端,形成下降沿2
  121.         _nop_();
  122.         _nop_();
  123.         ADCLK=1;//拉高CLK端
  124.         ADDI=(channel>>1)&0x1;
  125.         _nop_();
  126.         _nop_();
  127.         ADCLK=0;//拉低CLK端,形成下降沿3
  128.         ADDI=1;//控制命令结束
  129.         _nop_();
  130.         _nop_();
  131.         dat=0;
  132.         for(i=0;i<8;i++)
  133.         {
  134.                 dat|=ADDO;//收数据
  135.                    ADCLK=1;
  136.                    _nop_();
  137.                    _nop_();
  138.                    ADCLK=0;//形成一次时钟脉冲
  139.             _nop_();
  140.             _nop_();
  141.             dat<<=1;
  142.             if(i==7)dat|=ADDO;
  143.         }
  144.         for(i=0;i<8;i++)
  145.         {
  146.             ndat>>=1;
  147.                 if(ADDO==1)
  148.                 ndat|=0x80;
  149.             ADCLK=1;
  150.             _nop_();
  151.             _nop_();
  152.             ADCLK=0;//形成一次时钟脉冲
  153.             _nop_();
  154.             _nop_();
  155.         }
  156.
  157.         ADCS=1;//拉低CS端
  158.         ADCLK=0;//拉低CLK端
  159.         ADDO=1;//拉高数据端,回到初始状态
  160.     if(dat==ndat)
  161.         {
  162.             return(ndat);
  163.         }
  164.         else
  165.         {
  166.                 return(0x00);
  167.         }
  168. }
  169. //**************显示模块***********************
  170. void disp()
  171. {
  172.      ad1=ad-29;
  173.          write_com(0x80);
  174.          if(ad<29)
  175.          {
  176.               uchar i;
  177.                   for(i=0;i<16;i++)
  178.                   {
  179.                           write_data(tab4[i]);
  180.                   }
  181.                   write_com(0x80+0x40);
  182.                    for(i=0;i<16;i++)
  183.                   {
  184.                           write_data(tab5[i]);
  185.                   }
  186.          }
  187.                   else if(ad>233)
  188.          {
  189.                    uchar i;
  190.                   for(i=0;i<16;i++)
  191.                   {
  192.                           write_data(tab3[i]);
  193.                   }
  194.                    write_com(0x80+0x40);
  195.                    for(i=0;i<16;i++)
  196.                   {
  197.                           write_data(tab5[i]);
  198.                   }
  199.          }
  200.          else if(ad>=29&&ad<=233)
  201.          {
  202.               uchar i;
  203.                   for(i=0;i<16;i++)
  204.                   {
  205.                           write_data(tab7[i]);
  206.                   }
  207.                   write_com(0x80+0x40);
  208.                   for(i=0;i<7;i++)
  209.                           write_data(tab6[i]);
  210.                    if(ad>197)
  211.                   {
  212.                             write_data('-');
  213.                           write_data(tab1[(tab2[ad1])/10]);
  214.                           write_data(tab1[(tab2[ad1])%10]);
  215.                   }
  216.                   else
  217.                   {
  218.                           write_data(' ');
  219.                           write_data(tab1[tab2[ad1]/10]);
  220.                           write_data(tab1[tab2[ad1]%10]);
  221.                   }
  222.                   write_data(0xdf);                                 //显示温度符号
  223.                  write_data('C');
  224.          }
  225. }
  226. //***************主函数***********************
  227. void main()
  228. {
  229.         lcd1602init();                   //液晶初始化
  230.         while(1)
  231.         {
  232.                 ad=ADC0832(0);           //读取温度值
  233.                 disp();                  //调用显示程序
  234.         }
  235. }
完整的Word格式文档51黑下载地址:
基于单片机的温度测量仪的设计.docx (495.57 KB, 下载次数: 142)
ID:353425 发表于 2018-6-17 20:10 | 显示全部楼层
实用不过你用的是差分还是单通道
ID:669969 发表于 2020-1-19 14:52 来自触屏版 | 显示全部楼层
为什么液晶显示不出来啊
ID:741037 发表于 2020-4-29 16:29 | 显示全部楼层
很棒的 很实用
ID:763026 发表于 2020-5-28 09:15 | 显示全部楼层
好兄弟,led怎么不亮
