查看: 5592|回复: 3
探索者STM32F4开发板 ATK-ESP8266WIFI模块实验
ID:309487 发表于 2018-4-16 19:10 | 显示全部楼层 |阅读模式
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "usmart.h"
  8. #include "malloc.h"
  9. #include "w25qxx.h"
  10. #include "sdio_sdcard.h"
  11. #include "ff.h"
  12. #include "exfuns.h"
  13. #include "fontupd.h"
  14. #include "text.h"
  15. #include "usmart.h"
  16. #include "touch.h"
  17. #include "usart3.h"
  18. #include "common.h"
  19. int main(void)
  20. {
  21.         u8 key,fontok=0;
  22.         Stm32_Clock_Init(336,8,2,7);//设置时钟,168Mhz
  23.         delay_init(168);                        //延时初始化
  24.         uart_init(84,115200);                //初始化串口波特率为115200
  25.         usart3_init(42,115200);  //串口3初始化
  26.         LED_Init();                                        //初始化LED
  27.         LCD_Init();                                        //LCD初始化
  28.         KEY_Init();                                        //按键初始化
  29.         W25QXX_Init();                                //初始化W25Q128
  30.         tp_dev.init();                                //初始化触摸屏
  31.         usmart_dev.init(168);                //初始化USMART
  32.         my_mem_init(SRAMIN);                //初始化内部内存池
  33.         my_mem_init(SRAMCCM);                //初始化CCM内存池
  34.         exfuns_init();                                //为fatfs相关变量申请内存
  35.           f_mount(fs[0],"0:",1);                 //挂载SD卡
  36.         f_mount(fs[1],"1:",1);                 //挂载FLASH.
  37.         key=KEY_Scan(0);
  38.         if(key==KEY0_PRES)                //强制校准
  39.         {
  40.                 LCD_Clear(WHITE);        //清屏
  41.                 TP_Adjust();                  //屏幕校准
  42.                 TP_Save_Adjdata();
  43.                 LCD_Clear(WHITE);        //清屏
  44.         }
  45.         fontok=font_init();                //检查字库是否OK
  46.         if(fontok||key==KEY1_PRES)//需要更新字库
  47.         {
  48.                 LCD_Clear(WHITE);                           //清屏
  49.                 POINT_COLOR=RED;                        //设置字体为红色
  50.                 LCD_ShowString(60,50,200,16,16,"ALIENTEK STM32");
  51.                 while(SD_Init())                        //检测SD卡
  52.                 {
  53.                         LCD_ShowString(60,70,200,16,16,"SD Card Failed!");
  54.                         delay_ms(200);
  55.                         LCD_Fill(60,70,200+60,70+16,WHITE);
  56.                         delay_ms(200);
  57.                 }
  58.                 LCD_ShowString(60,70,200,16,16,"SD Card OK");
  59.                 LCD_ShowString(60,90,200,16,16,"Font Updating...");
  60.                 key=update_font(20,110,16,"0:");//从SD卡更新
  61.                 while(key)//更新失败
  62.                 {
  63.                         LCD_ShowString(60,110,200,16,16,"Font Update Failed!");
  64.                         delay_ms(200);
  65.                         LCD_Fill(20,110,200+20,110+16,WHITE);
  66.                         delay_ms(200);
  67.                 }
  68.                 LCD_ShowString(60,110,200,16,16,"Font Update Success!");
  69.                 delay_ms(1500);
  70.                 LCD_Clear(WHITE);//清屏
  71.         }
  72.         atk_8266_test();
  73. }
(寄存器版本,适合探索者STM32F4开发板)扩展实验13 ATK-ESP8266WIFI模块实验.rar (927.85 KB, 下载次数: 56)
ID:316184 发表于 2018-4-25 16:21 | 显示全部楼层
你好 我想只控制灯的亮灭,在什么地方改程序应该。串口的接收么??
ID:335361 发表于 2019-4-10 15:51 | 显示全部楼层
感谢楼主分享,最近刚好用到
ID:483033 发表于 2019-4-30 19:05 | 显示全部楼层
谢谢分享
