查看: 2384|回复: 2
基于STC89C52的ADC0832检测酒精12864显示改了个程序错误太多 大神帮忙看一下 谢谢
ID:300450 发表于 2018-4-17 09:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include<string.h>
#include<stdio.h>
#include<intrins.h>
#define uint unsigned int口定义
sbit CLK=P3^4;//ADC0832时钟端
sbit DIO=P3^3;//ADC832数据输入输出
sbit AD_CS=P3^5;//ADC0832片选端
#define jiaquan_CH  1
#define tianranqi_CH  0
sbit beep=P1^5;
#define LCD12864_DataPort P0
sbit LCD12864_EN=P2^1;
sbit LCD12864_RW=P2^2;
sbit LCD12864_RS=P2^3;
sbit LCD12864_PSB=P2^5;
void delay(unint time)//Time ms
uint j,k;
        for(k=time;k>0;k--)
           for(j=150;j>0;j--);
//AD转换函数
//ch--通道选择,
ch=0,0通
ch=1,1通道
uint sum;
uchar RH,RH_H=60,RH_L=20,state,ms,time_num,cs;
bit beep1,zt,s1;
void DelayUs2x(unsigned char t)
while(--t);
void DelayMs(unsigned char t)
while(t--)
    DelayUs2x(245);
         DelayUs2x(245);
unsigned int  A_D()
        unsigned char i;
        unsigned char dat;
        ADC0832_CS=1;
        ADC0832_CLK=0;
        ADC0832_CS=0;
        ADC0832_DIO=1;
        ADC0832_CLK=1;
        ADC0832_CLK=0;
        ADC0832_DIO=1;
        ADC0832_CLK=1;
        ADC0832_CLK=0;
        ADC0832_DIO=0;
        ADC0832_CLK=1;
        ADC0832_CLK=0;
        ADC0832_DIO=1;
        ADC0832_CLK=1;
        for(i=0;i<8;i++)
                ADC0832_CLK=1;
                ADC0832_CLK=0;
                dat<<=1;
                dat|=(unsigned char)ADC0832_DIO;
        ADC0832_CS=1;
        return dat;
void delay(uint T)
        while(T--);
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
_nop_();
EN_SET;
return (bit)(DataPort & 0x80);
void LCD_Write_Com(unsigned char com)
// while(LCD_Check_Busy());
DelayMs(5);
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
_nop_();
EN_CLR;
void LCD_Write_Data(unsigned char Data)
//while(LCD_Check_Busy());
DelayMs(5);
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
         LCD_Write_Com(0x80 + x);     //表示第一行
        LCD_Write_Com(0xC0 + x);      //表示第二行
while (*s)
LCD_Write_Data( *s);
s ++;
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
LCD12864功能函数
void LCD12864_delayms(unsigned int a)
        unsigned int x,y;
        for(x=a;x0;x--)
                for(y=110;y0;y--)
void LCD12864_write_cmd(unsigned char cmd)写命令
        LCD12864_RS=0;
        LCD12864_RW=0;
        LCD12864_EN=1;
        LCD12864_DataPort=cmd;
        LCD12864_delayms(1);
        LCD12864_EN=0;
                      清屏
void ClrScreen()
   LCD12864_write_cmd(0x01);
   LCD12864_delayms(15);
void LCD12864_write_data(unsigned char dat)        写数据
        LCD12864_RS=1;
        LCD12864_RW=0;
        LCD12864_EN=1;
        LCD12864_DataPort=dat;
        LCD12864_EN=0;
void LCD12864_write_String(unsigned char dat)写字符串,可写汉字
        for(;dat!='0';dat++)
                LCD12864_write_data(dat);
在固定的位置显示固定的数据
unsigned char x         第几行显示,从0开始
unsigned char y          第几个位置 从0开始
unsigned char dat 要显示的内容,可为汉字
void LCD12864_write_String_pos(unsigned char x,unsigned char y,unsigned char dat)
        if(x==0)第一行
                LCD12864_write_cmd(0x80+y);
                LCD12864_write_String(dat);
        if(x==1)第二行
                LCD12864_write_cmd(0x90+y);
        if(x==2) 第三行
                LCD12864_write_cmd(0x88+y);
        if(x==3)第四行
                LCD12864_write_cmd(0x98+y);
void LCD12864_init(void)初始化
        LCD12864_PSB=1;并行显示
        LCD12864_write_cmd(0x30);基本指令集
        LCD12864_write_cmd(0x0c);开显示,不显示光标
        LCD12864_Draw_Full(empty);写入一个空白的图形,防止数据干扰
主函数
void main(void)
        flag=0;
        LCD12864_init();//12864初始化
        start_display();
                keyscan();按键扫描函数
                jiaquan_ADCdat=ADC0832(jiaquan_CH);
                jiaquan_Disdat[0]=jiaquan_ADCdat100;          百位
                jiaquan_Disdat[1]=(jiaquan_ADCdat10)%10; 十位
                jiaquan_Disdat[2]=jiaquan_ADCdat%10;          个位
                delay(500);
                tianranqi_ADCdat=ADC0832(tianranqi_CH);
                tianranqi_Disdat[0]=tianranqi_ADCdat100;          百位
                tianranqi_Disdat[1]=(tianranqi_ADCdat10)%10; 十位
                tianranqi_Disdat[2]=tianranqi_ADCdat%10;          个位
                if(flag==1)
                        ADCresult_display();
                        jing_bao();
ID:300450 发表于 2018-4-17 10:03 | 只看该作者
求大神帮个忙
ID:300450 发表于 2018-4-21 17:13 | 只看该作者
这就沉了?
