查看: 1653|回复: 0
STX3x Sensor sample code
ID:311370 发表于 2018-4-19 04:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <application.h>
#include <spark_wiring_i2c.h>
// SHT31 I2C address is 0x44(68)
#define Addr 0x44
int temp = 0;
double cTemp = 0.0, fTemp = 0.0, humidity = 0.0;
void setup()
  // Set variable
  Particle.variable("i2cdevice", "SHT31");
  Particle.variable("cTemp", cTemp);
  Particle.variable("humidity", humidity);
  // Initialise I2C communication as MASTER
  Wire.begin();
  // Initialise serial communication, set baud rate = 9600
  Serial.begin(9600);
  delay(300);
void loop()
  unsigned int data[6];
  // Start I2C Transmission
  Wire.beginTransmission(Addr);
  // Send 16-bit command byte
  Wire.write(0x2C);
  Wire.write(0x06);
  // Stop I2C transmission
  Wire.endTransmission();
  delay(300);
  // Select data register
  Wire.write(0x00);
  // Stop I2C Transmission
  // Request 6 bytes of data from the device
  Wire.requestFrom(Addr, 6);
  // Read 6 bytes of data
  // temp msb, temp lsb, crc, hum msb, hum lsb, crc
  if (Wire.available() == 6)
    data[0] = Wire.read();
    data[1] = Wire.read();
    data[2] = Wire.read();
    data[3] = Wire.read();
    data[4] = Wire.read();
    data[5] = Wire.read();
  // Convert the data
  temp = (data[0] * 256) + data[1];
  cTemp = -45.0 + (175.0 * temp / 65535.0);
  fTemp = (cTemp * 1.8) + 32;
  humidity = 100 * ((data[3] * 256) + data[4]) / 65535.0;
  // Output data to dashboard
  Particle.publish("Temperature in Celsius:  ",  String(cTemp));
  delay(1000);
  Particle.publish("Temperature in Fahrenheit:  ", String(fTemp));
  delay(1000);
  Particle.publish("Relative Humidity    :  ",  String(humidity));
  delay(1000);
