查看: 9818|回复: 7
Pwm波形,频率,占空比,可调,且LCD1602显示占空比
#include <reg52.h>
#define uint unsigned int //float fosc=12000000;  //系统时钟频率
sbit key1=P1^1;       //控制周期的增加
sbit key2=P1^2;        //控制周期的减少
sbit key3=P1^3;       //控制占空比的增加
sbit key4=P1^4;        //控制占空比的减少
sbit clk=P1^0;                         //pwm输出
sbit wei=P2^7;
sbit duan=P2^6;
sbit RS = P3^5;
sbit RW = P3^6;
sbit EN = P3^4;
uint zkb=50;     //占空比初值,取值范围为1到99
uint shi,ge;
uint period=35;       //周期初值,取值范围为5ms到60ms
uint time0_H,time0_L,time1_H,time1_L;  //延时程序
  void delayms(uint z)
   {   uint i,j;
     for(i=z;i--;i>0)
            for(j=110;j--;j>0);
  //系统初始化
/*uint code leddata[]={
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄灭
                0x00  //自定义
//void display(uint i)
uint shi,ge;
shi=i/10;
ge=i%10;
P0=0xff;
wei=1;
P0=0xfe;//1111 1110
wei=0;
duan=1;
P0=leddata[shi];
duan=0;
delayms(10);
P0=0xff;
wei=1;
P0=0xfd;//1111 1101
wei=0;
duan=1;
P0=leddata[ge];
duan=0;
delayms(10);
  void init()
  {  TMOD=0x11;     //定时器0和1都工作在方式1
     time0_H=(65536-35000)/256;
     time0_L=(65536-35000)%256; //35ms定时
         time1_H=(65536-17500)/256;
     time1_L=(65536-17500)%256; //17.5ms定时,50%占空比
     TH0=time0_H;
   //定时器0装入初值,计数器计数35000次,35ms
     TL0=time0_L;
         TH1=time1_H; //定时器1装入初值,计数器计数17500次,17.5ms
         TL1=time1_L;
          IT0=1;      //外部中断0为下降沿触发
          EX0=1;      //开外部中断0允许位
          ET0=1;      //定时器T0中断允许
      ET1=1;      //定时器T1中断允许
      EA=1;       //开启总中断
      TR0=1;      //开启定时器0
//判断液晶忙,如果忙则等待           第一步:读状态
void Read_Busy()
        uchar busy;
        P0 = 0xff; //给P0送1111 1111
        RS = 0;
        RW = 1;
        do
                EN = 1;
                busy = P0;
                EN = 0;
        }while(busy & 0x80);//读写检测,判断STA7为是否位1,为1,则忙,循环等待。
//写LCD1602一个字节命令
void Write_Cmd(uchar cmd)         //第二步:写指令
        Read_Busy();//判断忙
        RS = 0;
        RW = 0;
        P0 = cmd;
        EN = 1;
        EN = 0;
//写一个字节数据
void Write_Dat(uint dat)                 //第三步:写数据
        Read_Busy();
        RS = 1;
        RW = 0;
        P0 = dat;
        EN = 1;
        EN = 0;
void LCD_init()
        Write_Cmd(0x38);//设置16*2显示
        Write_Cmd(0x0c);//开显示 显示光标,光标闪烁
        Write_Cmd(0x01);//清屏
        Write_Cmd(0x06);//地址指针移位命令
  //主程序
        uint num[2];
        init( );
                shi=zkb/10;
                ge=zkb%10;
            num[0]=shi;
        num[1]=ge;
            LCD_init();
        //Write_Cmd(0x80 | 0x00);//显示地址
            shi=zkb/10;
                ge=zkb%10;
            num[0]=shi;
        num[1]=ge;
        Write_Dat(25 + 'A');  //z
        Write_Dat(10 + 'A');  //k
        Write_Dat(1 + 'A');          //b
        Write_Dat(0x3A);          //:
        Write_Dat(num[0]+'0');        //十位
        Write_Dat(num[1]+'0');        //个位
        delayms(10);
  //TO中断程序
  void T0_time() interrupt 1    //控制PWM波的周期
      TR1=1;            //开定时器1
      TH0=time0_H;
      TL0=time0_L;
          clk=1;
         } //T1中断程序
  void T1_time() interrupt 3                 //控制PWM波的占空比
   {   TR1=0;             //关定时器1
       TH1=time1_H;
           TL1=time1_L;
           clk=0;
           } //键盘扫描程序
  void  keyscan()  interrupt 0 //外部中断0,用来查询是否有按键按下
         {   float TX,TZ; //定义浮点型变量,4字节长度
          EX0=0;             //关中断
          delayms(10);       //延时消抖
          if(P1!=0x1e)       //延时消抖完毕,判断的确有按键按下
                   if(key1==0)        //判断是哪个按键按下
                           period=period+5;
                           if(period>60)
                             period=5;
                                   if(key2==0)
                                    {     period=period-5;
                                                  if(period<5)
                                       period=60;
                                if(key3==0)
                                        zkb=zkb+1;
                                         if(zkb>99)
                             zkb=1;
                             if(key4==0)
                                  zkb=zkb-1;
                                 if(zkb<1)
                                 zkb=99;
                      TX=(65536-(period)*1000);//周期计算 !!!!
                      TZ=(65536-(period/2)*1000+(50-zkb)*period*10);//占空比计算???
                      time0_H=(uint)TX/256;
              time0_L=(uint)TX%256;
              time1_H=(uint)TZ/256;
                  time1_L=(uint)TZ%256;
                      P1=0x1e;  //P1口重新赋值,以便下次按键判断
                  EX0=1;   //开外部中断
                      TR0=1;  //开定时器0
                      TR1=1; //开定时器1
收藏收藏8 分享淘帖 顶顶 踩踩
ID:297159 发表于 2018-6-27 20:07 | 只看该作者
ID:360843 发表于 2018-7-11 16:55 | 只看该作者
不错   正在学习PWM   谢谢
ID:375055 发表于 2018-7-19 19:48 | 只看该作者
这个可以有
ID:243748 发表于 2018-7-21 22:56 来自触屏版 | 只看该作者
怎么下载?
ID:386237 发表于 2018-8-18 21:56 来自触屏版 | 只看该作者
楼主能不能把完整的电路图发出来?
ID:450227 发表于 2018-12-24 13:36 | 只看该作者
烧录进去怎么没有显示啊
ID:297159 发表于 2024-12-19 17:50 | 只看该作者
时间太久远了  我找一找  回头
