查看: 1847|回复: 0
步进电机仿真
ID:313067 发表于 2018-4-24 16:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
#include <intrins.h>
#define uint  unsigned int
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
unsigned char code FFW[8]={0xfe,0xfc,0xfd,0xf9,0xfb,0xf3,0xf7,0xf6}; //??
unsigned char code REV[8]={0xf6,0xf7,0xf3,0xfb,0xf9,0xfd,0xfc,0xfe}; //??
//unsigned char code FFW[8]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09}; //??
//unsigned char code REV[8]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01}; //??
sbit  K1   = P2^3;       //?????
sbit  K2   = P2^4;       //????
sbit  K3   = P2^5;       //????
sbit  K4   = P2^6;       //????
sbit  LCD_RS = P2^0;
sbit  LCD_RW = P2^1;
sbit  LCD_EN = P2^2;
bit  on_off=0;            //???????
bit  direction=1;         //????
bit  rate_dr=1;           //????
bit  snum_dr=1;           //????
uchar code  cdis1[ ] = {"Bi Ye She Ji "};
uchar code  cdis2[ ] = {"    LuoWeilan"};
uchar code  cdis3[ ] = {"    STOP        "};
uchar code  cdis4[ ] = {"NUM:    RATE:   "};
uchar code  cdis5[ ] = {"  RUNNING       "};
uchar   m,v=0,q=0;
uchar   number=0,number1=0;
uchar   snum=20,snum1=20;       //?????
uchar   rate=3;               //?????
uchar   data_temp,data_temP0,data_temp2;
/* ??t??
/* 11.0592MHz??,???1ms
void delay(uint t)
   uchar k;
   while(t--)
     for(k=0; k<124; k++)
void delayB(uchar x)    //x*0.14MS
   uchar i;
   while(x--)
     for (i=0; i<13; i++)
/*??LCD???
/*lcd_busy?1?,?,????0?,?,????????
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delayNOP();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
/*??????LCD
/*RS=L,RW=L,E=???,D0-D7=????
void lcd_wcmd(uchar cmd)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P0 = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*??????LCD
/*RS=H,RW=L,E=???,D0-D7=???
void lcd_wdat(uchar dat)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*  LCD?????
void lcd_init()
    delay(30);
    lcd_wcmd(0x38);      //16*2??,5*7??,8???
    delay(5);
    lcd_wcmd(0x38);
    delay(5);
    lcd_wcmd(0x38);
    delay(5);
    lcd_wcmd(0x0c);      //???,???
    delay(5);
    lcd_wcmd(0x06);      //????
    delay(5);
    lcd_wcmd(0x01);      //??LCD?????
    delay(5);
void lcd_pos(uchar pos)
  lcd_wcmd(pos | 0x80);  //????=80+????
/* LCD1602???????
void  LCD_init_DIS()
     delay(10);                 //??
     lcd_init();                //???LCD
     lcd_pos(0);                //????????????1???
     m = 0;
     while(cdis1[m] != '\0')
        lcd_wdat(cdis1[m]);
        m++;
     lcd_pos(0x40);             //???????????1???
     m = 0;
     while(cdis2[m] != '\0')
        lcd_wdat(cdis2[m]);      //????
        m++;
      delay(3000);               //??
      m = 0;
      while(cdis3[m] != '\0')
          lcd_wdat(cdis3[m]);
          m++;
      m = 0;
     while(cdis4[m] != '\0')
          lcd_wdat(cdis4[m]);    //????
          m++;
        for(m=0;m<2;m++)
       lcd_pos(0x0c+m);    //??????
             lcd_wdat(0x3e);
void  data_conv()
     data_temP0=data_temp/10;       //??
  if(data_temP0==0)
  {data_temP0=0x20;}             //???0???
  {data_temP0=data_temP0+0x30;}
   data_temp2=data_temp%10;       //??
     data_temp2=data_temp2+0x30;
void  data_dis()
    data_temp = snum;        //????
    data_conv();
       lcd_pos(0x44);
       lcd_wdat(data_temP0);
       lcd_pos(0x45);
       lcd_wdat(data_temp2);
    data_temp = rate;         //????
    data_conv();
       lcd_pos(0x4d);
       lcd_pos(0x4e);
void  motor_DR()
       if(direction==1)           //??????
        { for(m=0;m<2;m++)
            lcd_wdat(0x3e);
         { for(m=0;m<2;m++)       //??????
             lcd_wdat(0x3c);
void  motor_RUN()
      if(on_off==1)
    { TR0=1;
         m = 0;
         while(cdis5[m] != '\0')
          { lcd_wdat(cdis5[m]);      //RUNNING
            m++;   }
            motor_DR();              //
    { TR0=0; P0 =0x0f;
         m = 0;
          { lcd_wdat(cdis3[m]);      //STOP
            m++;   }
            motor_DR();              //
   snum=snum1;             //
   number1=0;              //??????
main()
         LCD_init_DIS();
   TMOD = 0x01;       //T0????1
   TL0  = 0x33;
   TH0  = 0xf5;
   EA   = 1;
   ET0  = 1;
   P1=0;
       if(K1==0)
         //beep();
      while(K1==0);       //?????
      on_off=~on_off;
         motor_RUN();
        }   //K1 end
      if(K2==0)
        if(snum_dr==1)
    { snum++;
        snum1=snum;
      if(snum==0x14)
            { snum_dr=~snum_dr;}
     {snum--;
   snum1=snum;
      if(snum==0x01)
   { snum_dr=~snum_dr; }
    } //K2  end
        if(K3==0)
   direction=~direction;
         motor_DR();
      }//K3 end
        if(K4==0)
   if(rate_dr==1)
    { rate++;
      if(rate==0x10)
            { rate_dr=~rate_dr;}
      rate--;
      if(rate==0x01)
   { rate_dr=~rate_dr; }
  } //K4 end
      if(number1==snum1)   //?????????
     { number1=0;
         on_off=0;
         TR0=0;
        snum=snum1;
   P1=0x0f;
    motor_RUN();
         data_dis();
}  // while(1) end
}  //main end
/*  ??? T0 ??
void  motor_onoff()  interrupt  1
       TL0  = 0x33;
       TH0  = 0xf5;
       q++;
    if(q < rate)
        { return; }
       {  q=0;
       number++;                  //????
      if(number==64)              //64????????
       { snum--;
      number=0;
            number1++; }          //??????
       { if(v<8)
         {P1 = FFW[v];v++;}       //???,??
        if(v==8)
        { v=0;
       { if(v<8)
         {P1 = REV[v];v++;}       //???,??
         if(v==8)
         { v=0; }
