查看: 4187|回复: 2
基于51单片机的乒乓球游戏源码
ID:311903 发表于 2018-4-26 08:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
资料有点老了,但发现最近挺多人找51单片机的乒乓球游戏系统设计,所以找出来上传到论坛里
  1. #define uchar unsigned char
  2. #define uint unsigned int
  3. //sbit BALL=P1;
  4. sbit key1=P3^1;
  5. sbit key2=P3^2;
  6. sbit BUZZER = P3^3;
  7. int red=0,green=0,aa;
  8. uint nms;
  9. void Delay(int z)
  10. {
  11.         int x;
  12.         for(x=z;x>0;x--);
  13. }
  14. void Buzzer()
  15. {
  16.         int i;
  17.         while(1)
  18.         {
  19.                 BUZZER = 0;
  20.                 Delay(5);
  21.                 BUZZER = 1;
  22.                 Delay(5);
  23.                 i++;
  24.                 if(i>500)
  25.                 {
  26.                         i = 0;
  27.                         break;
  28.                 }
  29.         }
  30. }
  31. int beatscan()
  32. {
  33.         if(key1==0)
  34.         {
  35.                 delayms(10);
  36.                 if(key1==0)
  37.                 {
  38.                         Buzzer();
  39.                         Buzzer();
  40.                         Buzzer();
  41.                         while(!key1);
  42.                         return 1;
  43.                 }
  44.         }
  45.         if(key2==0)
  46.         {
  47.                 delayms(10);
  48.                 if(key2==0)
  49.                 {
  50.                         Buzzer();
  51.                         Buzzer();
  52.                         Buzzer();
  53.                         while(!key1);
  54.                         return 2;
  55.                 }
  56.         }
  57.         return 0;
  58. }
  59. int left()
  60. {
  61.         uint i;
  62.         aa=0xfe;
  63.         while(1)
  64.         {
  65.                 P1=aa;
  66.                 for(i=0;i<nms;i++)
  67.                         {
  68.                                 if(beatscan()==2)
  69.                                         {
  70.                                                 if(aa!=0x7f)
  71.                                                         return 0;
  72.                                                 else
  73.                                                         return 1;
  74.                                         }
  75.                                 delayms(10);
  76.                         }
  77.                 aa=_crol_(aa,1);
  78.                 if(aa==0xfe)
  79.                         return 0;
  80.         }
  81. }
  82. int right()
  83. {
  84.         uint i;
  85.         aa=0x7f;
  86.         while(1)
  87.         {
  88.                 P1=aa;
  89.                 for(i=0;i<nms;i++)
  90.                         {
  91.                                 if(beatscan()==1)
  92.                                         {
  93.                                                 if(aa!=0xfe)
  94.                                                         return 0;
  95.                                                 else
  96.                                                         return 1;
  97.                                         }
  98.                                 delayms(10);
  99.                         }
  100.                 aa=_cror_(aa,1);
  101.                 if(aa==0x7f)
  102.                                 return 0;
  103.         }
  104. }
  105. void left1()
  106. {
  107.         P1=0xfe;
  108.         delayms(200);
  109.         P1=0xff;
  110.         Buzzer();
  111.         Buzzer();
  112.         P1=0xfe;
  113.         while(1)
  114.         {
  115.                 if(beatscan()==1)
  116.                         break;
  117.                 delayms(20);
  118.         }
  119.         while(1)
  120.         {
  121.                 if(left())
  122.                 {
  123.                         if(right())
  124.                                 continue;
  125.                         else
  126.                         {
  127.                                 green++;
  128.                                 break;
  129.                         }
  130.                 }
  131.                 else
  132.                 {
  133.                         red++;
  134.                         break;
  135.                 }
  136.         }
  137.         Write_1602Score(red,green);
  138. }
  139. void right1()
  140. {
  141.         P1=0x7f;
  142.         delayms(200);
  143.         P1=0xff;
  144.         Buzzer();
  145.         Buzzer();
  146.         P1=0x7f;
  147.         while(1)
  148.         {
  149.                 if(beatscan()==2)
  150.                         break;
  151.                 delayms(20);
  152.         }
  153.         while(1)
  154.         {
  155.                 if(right())
  156.                 {
  157.                         if(left())
  158.                                 continue;
  159.                         else
  160.                         {
  161.                                 red++;
  162.                                 break;
  163.                         }
  164.                 }
  165.                 else
  166.                 {
  167.                         green++;
  168.                         break;
  169.                 }
  170.         }
  171.         Write_1602Score(red,green);
  172. }
  173. void pingpang()
  174. {
  175.         uint i,j;
  176.         Write_1602String(1,1,"    Welcome!     ");
  177.         delayms(10);
  178.         Write_1602String(2,1,"Wish you happy!! ");
  179. /*        for(i=0;i<16;i--)
  180.         {
  181.                 Write_1602Com(0x18);
  182.                 delayms(500);
  183.         }
  184.         delayms(2000);
  185.         for(i=0;i<16;i--)
  186.         {
  187.                 Write_1602Com(0x18);
  188.                 delayms(500);
  189.         }*/
  190.         aa=0xfe;
  191.         for(i=0;i<7;i++)
  192.         {
  193.                 P1=aa;
  194.                 BUZZER=0;
  195.                 delayms(50);
  196.                 BUZZER=1;
  197.                 delayms(50);
  198. //                Buzzer();
  199. //                Buzzer();
  200.                 P1=0xff;
  201.                 delayms(20);
  202.                 aa=_crol_(aa,1);
  203.         }
  204.         //aa=0x7f;
  205.         for(i=0;i<7;i++)
  206.         {
  207.                 P1=aa;
  208.                 BUZZER=0;
  209.                 delayms(50);
  210.                 BUZZER=1;
  211.                 delayms(50);
  212.         //        Buzzer();
  213.         //        Buzzer();
  214.                 P1=0xff;
  215.                 delayms(20);
  216.                 aa=_cror_(aa,1);
  217.         }
  218.         for(i=0;i<7;i++)
  219.         {
  220.                 P1=aa;
  221.                 BUZZER=0;
  222.                 delayms(50);
  223.                 BUZZER=1;
  224. //                Buzzer();
  225. //                Buzzer();
  226.                 P1=0xff;
  227.                 delayms(10);
  228.                 aa=_crol_(aa,1);
  229.         }
  230.         //aa=0x7f;
  231.         for(i=0;i<8;i++)
  232.         {
  233.                 P1=aa;
  234.                 BUZZER=0;
  235.                 delayms(50);
  236.                 BUZZER=1;
  237. //                Buzzer();
  238. //                Buzzer();
  239.                 P1=0xff;
  240.                 delayms(10);
  241.                 aa=_cror_(aa,1);
  242.         }
  243.         while(1)
  244.         {
  245.         red=0;green=0;
  246.         Write_1602Com(0x01);
  247.         Write_1602String(1,1,"        Please select:  ");
  248.         Write_1602String(2,1,"1.Low 2.Mid 3.Hi");
  249.         while(1)
  250.         {
  251.                 if(Key_Scan()==1)
  252.                 {
  253.                         delayms(10);
  254.                         if(Key_Scan()==1)
  255.                         {
  256.                                 nms=60;
  257.                                 for(i=0;i<3;i++)
  258.                                 {
  259.                                         Write_1602String(1,1,"Please select:  ");
  260.                                         Write_1602String(2,1,"      2.Mid 3.Hi");
  261.                                         delayms(500);
  262.                                         Write_1602String(1,1,"Please select:  ");
  263.                                         Write_1602String(2,1,"1.Low 2.Mid 3.Hi");
  264.                                         delayms(500);
  265.                                 }
  266.                                 Write_1602String(1,1,"                ");
  267.                                 break;
  268.                         }
  269.                 }
  270.                 if(Key_Scan()==2)
  271.                 {
  272.                         delayms(10);
  273.                         if(Key_Scan()==2)
  274.                         {
  275.                                 nms=30;
  276.                                 for(i=0;i<3;i++)
  277.                                 {
  278.                                         Write_1602String(1,1,"Please select:  ");
  279.                                         Write_1602String(2,1,"1.Low       3.Hi");
  280.                                         delayms(500);
  281.                                         Write_1602String(1,1,"Please select:  ");
  282.                                         Write_1602String(2,1,"1.Low 2.Mid 3.Hi");
  283.                                         delayms(500);
  284.                                 }
  285.                                 Write_1602String(1,1,"                ");
  286.                                 break;
  287.                         }
  288.                 }
  289.                 if(Key_Scan()==3)
  290.                 {
  291.                         delayms(10);
  292.                         if(Key_Scan()==3)
  293.                         {
  294.                                 nms=10;
  295.                                 for(i=0;i<3;i++)
  296.                                 {
  297.                                         Write_1602String(1,1,"Please select:  ");
  298.                                         Write_1602String(2,1,"1.Low 2.Mid     ");
  299.                                         delayms(500);
  300.                                         Write_1602String(1,1,"Please select:  ");
  301.                                         Write_1602String(2,1,"1.Low 2.Mid 3.Hi");
  302.                                         delayms(500);
  303.                                 }
  304.                                 Write_1602String(1,1,"                ");
  305.                                 break;
  306.                         }
  307.                 }
  308.                 delayms(10);
  309.         }
  310.         Write_1602String(2,1,"   Begin now!   ");
  311.         delayms(1000);
  312.         Write_1602Com(0x01);
  313.         delayms(500);
  314.         Write_1602String(1,1,"Scores   G:R   ");
  315.         Write_1602Score(red,green);
  316.         while(1)
  317.         {
  318.                 if(((red-green>1)&&(red>=11))||((green-red>1)&&(green>=11)))
  319.                 {
  320.                         Write_1602String(1,1,"Congratulations!");
  321.                         delayms(1000);
  322.                         if(red>green)
  323.                         {
  324.                                 for(i=0;i<3;i++)
  325.                                 {
  326.                                 Write_1602String(1,1,"    Red Win!    ");
  327.                                 Write_1602Score(red,green);
  328.                                 P1=0xaa;
  329.                                 for(j=0;j<10;j++)
  330.                                         Buzzer();
  331. //                                delayms(500);
  332. //                                Buzzer1();
  333. ……………………
  334. …………限于本文篇幅 余下代码请从51黑下载附件…………
51单片机-乒乓球游戏.zip (51.13 KB, 下载次数: 41)
ID:1 发表于 2018-4-26 18:43 | 只看该作者
楼主您好 能分享个原理图吗?
ID:311903 发表于 2018-4-26 20:54 | 只看该作者
admin 发表于 2018-4-26 18:43
楼主您好 能分享个原理图吗?
原理图我再找找,不一定能找到了很久以前的了
