查看: 17890|回复: 11
arduino ps2遥控小车基于无线模块
基于无线模块的遥控控制小车
手柄按键
发送字符
接收十六进制代码
小车动作
按键上或左摇杆上
“a”
0x61
前进
按键下或左摇杆下
“b”
0x62
后退
按键左或左摇杆左
“c”
0x63
左转
按键右或左摇杆右
“d”
0x64
右转
红圆圈
“e”
0x65
左原地转圈
粉方块
“f”
0x66
右原地转圈
绿三角
“g”
0x67
划弧度
左1或右1
“h”
0x68
左平移
左2或右2
“i”
0x69
右平移
右摇杆上
“g”
0x6a
45度左前
右摇杆下
“k”
0x6b
45度右后
右摇杆左
“l”
0x6c
45度右前
右摇杆右
“m”
0x6d
45度左后
标志位
“n”
0x6e
停止
arduino源程序如下:
  1. #include <PS2X_lib.h>  //for v1.6
  2. PS2X ps2x; // create PS2 Controller Class
  3. //right now, the library does NOT support hot pluggable controllers, meaning
  4. //you must always either restart your Arduino after you conect the controller,
  5. //or call config_gamepad(pins) again after connecting the controller.
  6. //不支持热插拔,连线后需要重新启动Arduino板
  7. int PS_LX;//PS2手柄左摇杆X轴数据
  8. int PS_LY;//PS2手柄左摇杆Y轴数据
  9. int PS_RX;//PS2手柄右摇杆X轴数据
  10. int PS_RY;//PS2手柄右摇杆Y轴数据
  11. int error = 0;         //连接正确与否的判断标志
  12. byte type = 0;         //ps2x.readType()转换判别标志
  13. byte vibrate = 0;
  14. int banduan=0;
  15. void setup(){
  16. Serial.begin(57600);
  17. //CHANGES for v1.6 HERE!!! **************PAY ATTENTION*************
  18. error = ps2x.config_gamepad(13,11,10,12, true, true);   //setup pins and settings:  GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
  19.                                                          //检查引脚是否有连接错误
  20.
  21. if(error == 0){
  22.    Serial.println("Found Controller, configured successful");
  23.    Serial.println("Try out all the buttons, X will vibrate the controller, faster as you press harder;");
  24.   Serial.println("holding L1 or R1 will print out the analog stick values.");
  25.   Serial.println("Go to [url]www*billporter*info[/url] for updates and to report bugs.");
  26. }  //0号错误的串口提示信息
  27.   else if(error == 1)
  28.    Serial.println("No controller found, check wiring, see readme.txt to enable debug. visit [url]www*billporter*info[/url] for troubleshooting tips");
  29.                   //1号错误的串口提示信息
  30.   else if(error == 2)
  31.    Serial.println("Controller found but not accepting commands. see readme.txt to enable debug. Visit [url]www*billporter*info[/url] for troubleshooting tips");
  32.                  //2号错误的串口提示信息
  33.   else if(error == 3)
  34.    Serial.println("Controller refusing to enter Pressures mode, may not support it. ");
  35.                  //3号错误的串口提示信息
  36.    //Serial.print(ps2x.Analog(1), HEX);
  37.    type = ps2x.readType();    //正确连接后串口提示的信息
  38.      switch(type) {
  39.        case 0:
  40.         Serial.println("Unknown Controller type");
  41.        break;
  42.        case 1:
  43.         Serial.println("DualShock Controller Found");
  44.        break;
  45.        case 2:
  46.          Serial.println("GuitarHero Controller Found");
  47.        break;
  48.      }
  49. }
  50. void loop(){
  51.    /* You must Read Gamepad to get new values
  52.    Read GamePad and set vibration values
  53.    ps2x.read_gamepad(small motor on/off, larger motor strenght from 0-255)
  54.    if you don't enable the rumble, use ps2x.read_gamepad(); with no values
  55.
  56.    you should call this at least once a second
  57.    */
  58. //用Read Gamepad函数读取按键值
  59. if(error == 1) //skip loop if no controller found
  60.   return;
  61.
  62.
  63.
  64.   /******************************************************
  65.    Guitar Hero Controller不是手柄选用的控制器
  66.   //Guitar Hero Controller
  67. if(type == 2)
  68. {
  69.   ps2x.read_gamepad();          //read controller
  70.    if(ps2x.ButtonPressed(GREEN_FRET))
  71.      Serial.println("Green Fret Pressed");
  72.    if(ps2x.ButtonPressed(RED_FRET))
  73.      Serial.println("Red Fret Pressed");
  74.    if(ps2x.ButtonPressed(YELLOW_FRET))
  75.      Serial.println("Yellow Fret Pressed");
  76.    if(ps2x.ButtonPressed(BLUE_FRET))
  77.      Serial.println("Blue Fret Pressed");
  78.    if(ps2x.ButtonPressed(ORANGE_FRET))
  79.      Serial.println("Orange Fret Pressed");
  80.     if(ps2x.ButtonPressed(STAR_POWER))
  81.      Serial.println("Star Power Command");
  82.     if(ps2x.Button(UP_STRUM))          //will be TRUE as long as button is pressed
  83.      Serial.println("Up Strum");
  84.     if(ps2x.Button(DOWN_STRUM))
  85.      Serial.println("DOWN Strum");
  86.     if(ps2x.Button(PSB_START))                            //will be TRUE as long as button is pressed
  87.          Serial.println("Start is being held");
  88.     if(ps2x.Button(PSB_SELECT))
  89.          Serial.println("Select is being held");
  90.     if(ps2x.Button(ORANGE_FRET)) // print stick value IF TRUE
  91.     {
  92.         Serial.print("Wammy Bar Position:");
  93.         Serial.println(ps2x.Analog(WHAMMY_BAR), DEC);
  94.     }
  95. }
  96. **********************************************************************/
  97. else { //DualShock Controller手柄选用的控制器
  98.     ps2x.read_gamepad(false, vibrate);          //read controller and set large motor to spin at 'vibrate' speed
  99.
  100.     if(ps2x.Button(PSB_START))                      //start选中 //will be TRUE as long as button is pressed
  101.       Serial.println("Start is being held");
  102.     if(ps2x.Button(PSB_SELECT))                     //select选中
  103.       Serial.println("Select is being held");
  104.     PS_LX=ps2x.Analog(PSS_LX);           //把PS2手柄左摇杆X轴数据读到变量PS_LX
  105.    PS_RX=ps2x.Analog(PSS_RX);           //把PS2手柄右摇杆X轴数据读到变量PS_RX
  106.    PS_LY=ps2x.Analog(PSS_LY);           //把PS2手柄左摇杆Y轴数据读到变量PS_LY
  107.    PS_RY=ps2x.Analog(PSS_RY);           //把PS2手柄右摇杆Y轴数据读到变量PS_RY
  108.   if(PS_RX<5)                  //从左到右0~255,从上到下0~255
  109.   { banduan=1;
  110.         Serial.print("l");
  111.       }
  112.    if(PS_RX>250)
  113.    { banduan=1;
  114.         Serial.print("m");
  115.       }
  116.     if(PS_RY<5)
  117.   { banduan=1;
  118.         Serial.print("j");
  119.       }
  120.       if(PS_RY>250)
  121.   { banduan=1;
  122.         Serial.print("k");
  123.       }
  124.     if(PS_LY<5||ps2x.Button(PSB_PAD_UP)) //上                   //will be TRUE as long as button is pressed
  125.     {  banduan=1;
  126.        Serial.print("a");
  127.      }
  128.
  129.      if(PS_LY>250||ps2x.Button(PSB_PAD_DOWN))//下
  130.       { banduan=1;
  131.        Serial.print("b");
  132.       }
  133.
  134.          if(PS_LX<5||ps2x.Button(PSB_PAD_LEFT))//左
  135.       { banduan=1;
  136.       Serial.print("c");
  137.       }
  138.
  139.      if(PS_LX>250||ps2x.Button(PSB_PAD_RIGHT))//右
  140.      { banduan=1;
  141.         Serial.print("d");
  142.       }
  143.
  144.
  145.      if(ps2x.Button(PSB_RED))               //红圆圈
  146.          { banduan=1;
  147.         Serial.print("e");
  148.       }
  149.     if(ps2x.Button(PSB_PINK))             //粉方形
  150.        { banduan=1;
  151.         Serial.print("f");
  152.       }
  153.
  154.
  155.
  156.
  157.       vibrate = ps2x.Analog(PSAB_BLUE);        //this will set the large motor vibrate speed based on how hard you press the blue (X) button
  158.      if(ps2x.NewButtonState(PSB_BLUE))        //蓝叉叉
  159.         Serial.print("XX");
  160.     if (ps2x.Button(PSB_GREEN))              //绿三角   //will be TRUE if any button changes state (on to off, or off to on)
  161.      { banduan=1;
  162.         Serial.print("g");
  163.       }
  164.
  165.     if(ps2x.Button(PSB_L1) || ps2x.Button(PSB_R1)) //左1右1// print stick values if either is TRUE
  166.      { banduan=1;
  167.         Serial.print("h");
  168.       }
  169.    if(ps2x.Button(PSB_L2) || ps2x.Button(PSB_R2)) //左2右2// print stick values if either is TRUE
  170.      { banduan=1;
  171.         Serial.print("i");
  172.       }
  173.   if( banduan==0)
  174.       Serial.print("n");
  175.      else
  176.          banduan=0;
  177.
  178. }
  179. delay(50);
  180. }
遥控小车.rar (12.07 MB, 下载次数: 155)
收藏收藏5 分享淘帖 顶顶 踩踩
ID:18156 发表于 2018-9-9 16:29 | 只看该作者
看轮子应该是可以横向运动的。
ID:32574 发表于 2018-10-17 14:13 | 只看该作者
楼主厉害,轮子是叫什么名字?
ID:79544 发表于 2018-10-19 08:25 | 只看该作者
楼主  接收是用的什么模块?
ID:390585 发表于 2018-11-8 19:06 | 只看该作者
redtxd 发表于 2018-10-17 14:13
楼主厉害,轮子是叫什么名字?
麦克纳姆轮
ID:460190 发表于 2019-2-15 21:00 | 只看该作者
感谢分享
ID:448145 发表于 2019-11-7 12:22 | 只看该作者
感谢分享
ID:676603 发表于 2019-12-29 15:03 | 只看该作者
很棒,一会研究源码
ID:646222 发表于 2020-2-5 19:14 | 只看该作者
感谢分享
ID:652804 发表于 2020-2-25 21:37 | 只看该作者
感谢分享
ID:643484 发表于 2020-3-3 15:07 | 只看该作者
感谢分享
ID:171746 发表于 2021-1-26 16:57 | 只看该作者
有ARDUINO 小车程序吗?     哪个是51单片机的
