查看: 3499|回复: 0
单片机密码锁设计 包含c51程序及proteus图 功能齐全
密码锁仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
  1. #include <reg51.h>
  3. #define uint unsigned int
  4. sbit RS = P2^6 ;
  5. sbit RW = P2^5;
  6. sbit E = P2^7;
  7. sbit P3_0=P3^0;
  8. sbit P3_1=P3^1;
  9. uchar b,c,d,n,g=0,e=0;
  10. uchar o=0,t=0,m=0;
  11. uchar a[2][6];
  12. uint j;
  13. void fbusy(void);
  14. void write_command(uchar com);
  15. void write_data(uchar j);
  16. void LCD_init(void);
  17. void string(uchar ad ,uchar *s);
  18. void lcd_test(void);
  19. void input1(void);
  20. void panduan(void);
  21. void jinggao(void);
  22. void delay();
  23. void delay1(unsigned char x);
  24. void key(void);
  25. void delay(unsigned int k)
  26. {
  27.     unsigned int i,j;
  28. for(i=0;i<k;i++)
  29. for(j=0;j<121;j++)
  30. {
  31. ;
  32. }
  33.    }
  34. void fbusy(void)          //忙函数
  35. {
  36.
  37.       RS = 0;
  38.       RW = 1;
  39.       E = 1;
  40.   E=0;
  41. while(P0 & 0x80)
  42.    {E = 0;E=1;}
  43.    delay(1);
  44. }
  45. void write_command(uchar com)          //写命令函数
  46. { fbusy();
  47.    E = 0;
  48.    RS = 0;
  49.    RW = 0;
  50.    E=1;
  51.    P0 = com;
  52.    E = 0;
  53.    delay(1);
  54. }
  55. void write_data(uchar j)         //写数据函数
  56. {
  57.    fbusy();
  58.    E = 0;
  59.    RS = 1;
  60.    RW = 0;
  61.    E=1;
  62.    P0 = j;
  63.    E=0;
  64.    delay(1);
  65. }
  66. void LCD_init(void)          //LCD初始化
  67. { write_command(0x38);
  68.    write_command(0x01);
  69.    write_command(0x0e);
  70.    write_command(0x14);
  71.    delay(1);
  72. }
  73. void string(uchar ad, uchar *s)
  74. { write_command(ad);
  75.    while(*s>0)
  76.     { write_data(*s++);
  77.       delay(100);
  78.     }
  79. }
  80.
  81. void delay1(unsigned char x)   //大延迟函数
  82. {
  83.   unsigned char i,j,k;
  84.    do
  85. {
  86.   for(i=10;i>0;i--)
  87.    for(j=100;j>0;j--)
  88.     for(k=249;k>0;k--);
  89. }
  90. while(--x);
  91. }
  92. void key()           //键盘
  93. {
  94.   while(1)
  95.     {
  96.    if(m>2)           //输错三次
  97.    {
  98.   LCD_init();
  99.     for(t=0;t<100;t++)
  100.   {
  101.   P3_1=0;
  102.   delay(10);
  103.   P3_1=1;
  104.   delay(10);
  105.   }
  106.     jinggao();          //警告
  107.     delay1(5);
  108.     m=0;
  109.     input1();
  110.
  111.      }
  112.         P1=0xf0;
  113.   if(P1!=0xf0)
  114.   {
  115.    delay(150);
  116.    if(P1!=0xf0)
  117.    {
  118.     switch(P1)
  119.     {
  120.
  121.      case 0x70:b=0;break;
  122.      case 0xb0:b=1;break;
  123.      case 0xd0:b=2;break;
  124.      case 0xe0:b=3;break;
  125.                     default:break;
  126.     }
  127.    P1=0x0f;
  128.    switch(P1)
  129.    {
  130.     case 0x07:c=0;break;
  131.     case 0x0b:c=1;break;
  132.     case 0x0d:c=2;break;
  133.     case 0x0e:c=3;break;
  134.                 default:break;
  135.    }
  136.    d=(4*b+c);
  137.   if(d==10)           //更改键
  138.    {
  139.            delay1(1);
  140.    if(e>=1)
  141.    {
  142.    write_command(0x04);
  143.    write_data(' ');
  144.    write_command(0x06);
  145.           e--;
  146.          }
  147.    }
  148.
  149.     if(d==11)          //设置新密码
  150.    {
  151.    delay1(2);
  152.    g=1;e=0;o=1;
  153.    LCD_init();
  154.         string(0x80,"new code:");
  155.     if(e<6)
  156.       {
  157.       key();
  158.       write_data('0'+d);
  159.       a[g][e]=d;
  160.       e++;
  161.       }
  162.       for(e=0;e<6;e++)
  163.            {
  164.             a[0][e]=a[1][e];
  165.            }
  166.    LCD_init();
  167.         string(0x80,"Reset");
  168. string(0xc0,"Successfully");
  169.         delay1(2);
  170.         o=0;e=0;
  171.         input1();
  172.    key();
  173.    }
  174.    if(d<=9)
  175.   {
  176.      if(e<6)
  177.   {
  178.   write_data('0'+d);
  179.   a[g][e]=d;
  180.   e++;
  181.   delay1(1);
  182.   if(g==0&e>5)
  183.   {
  184.   e=0;g++;
  185.   delay1(2);
  186.   LCD_init();
  187.      string(0x80,"set");
  188. string(0xc0,"successfully");
  189.   delay1(2);
  190.   input1();
  191.     }
  192.   if(g>0&e>5)
  193.     {
  194.       delay1(1);
  195.        LCD_init();
  196.    if(o==0)
  197.    panduan();
  198.    if(o==1)
  199.    break;
  200.     }
  201.   }
  202.   }
  203.
  204. }
  205. }
  206. }
  207. }
  208. void panduan()
  209. {
  210.     n=1;g=1;
  211.    for(e=0;e<6;e++)
  212.    {
  213.      if(a[0][e]!=a[1][e])           //第一次输入与第二次输入不同为n=0
  214.   {
  215.    n=0;
  216.     }
  217.   }
  218.   if(n==1)            //相同
  219.   {
  220.      P3_0=1;
  221.       LCD_init();
  222.      string(0x80,"Right");
  223.      delay1(5);
  224.      input1();
  225.      e=0;m=0;
  226.       key();
  227.   }
  228.   if(n==0)            //不同
  229.   {
  230.      P3_0=0;
  231.       LCD_init();
  232.     string(0x80,"Error");
  233.      delay1(3);
  234.      input1();
  235.      e=0;m=m+1;
  236.      key();
  237.   }
  238. ……………………
  239. …………限于本文篇幅 余下代码请从51黑下载附件…………
密码锁.zip (137.74 KB, 下载次数: 54)
收藏收藏2 分享淘帖 顶 踩
