查看: 1910|回复: 0
stm8分享源码
ID:54014 发表于 2018-4-28 18:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/****************** (C) COPYRIGHT  风驰iCreate嵌入式开发工作室 *****************
* 文件名  :main.c
* 描述    :按键扫描
* 实验平台:iCreate STM8开发板
* 库版本  :V2.1.0
* 作者    :风驰  QQ:779814207
* 博客    :
* 修改时间 :2011-12-20
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
#include "led.h"
#include "key_scan.h"
#include "sysclock.h"
/* Private defines -----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
int main(void)
        /* 设置外部24M晶振为系统主时钟 */
        SystemClock_Init(HSE_Clock);
        Key_Init();
        LED_Init();
        //LED_Operation(LED_1, ON);
        while (1)
                /*  添加你的代码 */
                if (!Key_State_Check(KEY_1)) {
                        LED_Reverse(LED_2);
                if (!Key_State_Check(KEY_2)) {
                        LED_Reverse(LED_3);
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 风驰iCreate嵌入式开发工作室 *****END OF FILE****/
