查看: 4993|回复: 0
求助,为什么proteus仿真LED不亮
#include<AT89X51.h>
  uchar code table_h[]={
0x1C,0x18,0x18,0x18,0x18,0x18,0x18,0x3C,
uchar code table_l[]=
{ 0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
        uchar i=0,j=0;
        void Timer_init();
        viod refresh_led();
       Timer_init();
       void Timer_init()
                TMOD=0X01;
                                TH0=(65535-500)/256;
                                TL0=(65535-5000)%256;
                                ET0=1 ;
                                TR0=1;
                                EA=1;
   void Timer0() interrupt 1
     {TH0=(65535-3000)/256;
          TL0=(65535-3000)%256;
          if(i>=112){i=0;}
          refresh_led();
          Void refresh_led()
          switch(j)
                 { case 0:P0=~table_1[0];
                     Break;
                         case 1:P0=~table_1[1];
                     Break;
                         case 2:P0=~table_1[2];
                     Break;
                         case 3:P0=~table_1[3];
                     Break;
                         case 4:P0=~table_1[4];
                     Break;
                         case 5:P0=~table_1[5];
                     Break;
                         case 6:P0=~table_1[6];
                     Break;
                         case 7:P0=~table_1[7];
                     Break;
                         default:
                         break;}}
                         P2=table_h[i+j];
                          i++;
                          if(7==j++)
                          {J=0;}
程序是这样的
电路图是这样的
电路图是这样的
