查看: 5006|回复: 2
[求助]很难的一段程序,求助几天没人回答的出来,求单片机高手帮忙解释一下啊。
ID:30422 发表于 2011-8-16 21:26 | 显示全部楼层 |阅读模式
很难的一段程序,求助几天没人回答的出来,求单片机高手帮忙解释一下。
本人正在学,这段程序实在有难度啊,是关于pcf8591A/D转换的,主要是把display函数以前的解释一下就行,越详细越好,谢谢啦!
#include "reg52.h"
#include "pcf8591.h"
void init_t0(void);
void init_pcf8591(void);
void display(unsigned char d);
bit adcflag = 0;
unsigned char dspflag;
unsigned char tflag1;
unsigned char tflag2;
unsigned char code dsp_code_ca[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void main(void)
unsigned char adcvalue;
init_pcf8591();
init_t0();
display(adcvalue);
if(adcflag == 1)
adcvalue = adc_pcf8591();
adcflag = 0;
void isr_t0(void) interrupt 1
tflag1++;
tflag2++;
if(tflag1 == 16) //4ms
tflag1 = 0;
dspflag++;
if(dspflag == 3)
dspflag = 0;
if(tflag2 == 80) //20ms
tflag2 = 0;
adcflag = 1;
void init_t0(void)
TMOD = 0x02;
TH0 = 0x06;
TL0 = 0x06;
ET0 = 1;
EA = 1;
TR0 = 1;
iic_start();
iic_sendbyte(0x90);
iic_waitack();
iic_sendbyte(CHANNEL_3);
iic_waitack();
iic_stop();
delay(10);
if((dspflag == 0)&&(d>99))
P0 = 0xFF;
P2 |= 0xE0;
P2 &= 0x1F;
P0 = dsp_code_ca[d/100];
P2 |= 0xE0;
P2 &= 0x1F;
P0 = 0x20;
P2 |= 0xC0;
P2 &= 0x3F;
if((dspflag == 1)&&(d>9))
P0 = 0xFF;
P2 |= 0xE0;
P2 &= 0x1F;
P0 = dsp_code_ca[d%100/10];
P2 |= 0xE0;
P2 &= 0x1F;
P0 = 0x40;
P2 |= 0xC0;
P2 &= 0x3F;
if(dspflag == 2)
P0 = 0xFF;
P2 |= 0xE0;
P2 &= 0x1F;
P0 = dsp_code_ca[d%100%10];
P2 |= 0xE0;
P2 &= 0x1F;
P0 = 0x80;
P2 |= 0xC0;
P2 &= 0x3F;
[此贴子已经被作者于2011-8-16 21:40:35编辑过]
ID:31176 发表于 2011-9-8 23:19 | 显示全部楼层
是用什么显示的???
是不是那些是显示哪行哪列的指令啊
ID:31327 发表于 2011-9-14 21:02 | 显示全部楼层
我是代做毕设的,我QQ:834492956
