查看: 6146|回复: 0
XTR110引脚图与电路图及pdf芯片资料下载
DESCRIPTION
The XTR110 is a precision voltage-to-current converterdesigned for analog signal transmission. It accepts inputsof 0 to 5V or 0 to 10V and can be connected for outputs of4mA to 20mA, 0mA to 20mA, 5mA to 25mA, and many othercommonly used ranges.
A precision on-chip metal film resistor network provides inputscaling and current offsetting. An internal 10V voltage refer-ence can be used to drive external circuitry.The XTR110 is available in 16-pin plastic DIP, ceramic DIPand SOL-16 surface-mount packages. Commercial and in-dustrial temperature range models are available.
XTR110引脚图:
XTR110功能框图:
XTR110电路图:
我现在想把XTR110芯片加入到multisim中去。。
完整的pdf格式文档51黑下载地址:
xtr110.pdf (603.07 KB, 下载次数: 12)
