查看: 10463|回复: 18
51单片机洗衣机proteus仿真与源码设计(功能很全)
ID:320586 发表于 2018-5-2 17:04 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
分享我的单片机课设给51hei的朋友们,一个功能很全的模拟洗衣机仿真与源码,是51单片机控制的,有强洗按钮,弱洗按钮,标准洗按钮,甩干按钮.
液位传感器,排水阀按钮等功能一应俱全.
还带各种指示灯:
  1. /*-------------------------------
  2. 作者:小新
  3. --------------------------------*/
  4.
  5. #include <REG52.H>
  6. #define uchar unsigned char
  7. #define uint  unsigned int
  8. #define qiang_ledon qiang_led=1;
  9. #define qiang_ledoff qiang_led=0;
  10. #define biao_ledon biao_led=1;
  11. #define biao_ledoff biao_led=0;
  12. #define ruo_ledon ruo_led=1;
  13. #define ruo_ledoff ruo_led=0;
  14. #define piao_ledon piao_led=1;
  15. #define piao_ledoff piao_led=0;
  16. #define sgan_ledon sgan_led=1;
  17. #define sgan_ledoff sgan_led=0;
  18. #define jin_ledon jin_led=1;
  19. #define jin_ledoff jin_led=0;
  20. #define pai_ledon pai_led=1;
  21. #define pai_ledoff pai_led=0;
  22. unsigned char code Tab[11]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; //数码管显示0~9的段码表
  23. unsigned char int_time;        //记录中断次数
  24. unsigned char second;        //储存秒
  25. uint t=0,tt=0;
  26.    sbit k1=P0^0;
  27.    sbit k2=P0^1;
  28.    sbit k3=P0^2;
  29.    sbit sg=P0^3;
  30.    sbit hk1=P0^4;
  31.    sbit hk2=P0^5;
  32.    sbit ledon=P0^7;
  33.    sbit qiang_led=P2^0;
  34.    sbit biao_led=P2^1;
  35.    sbit ruo_led=P2^2;
  36.    sbit piao_led=P2^3;
  37.    sbit sgan_led=P2^4;
  38.    sbit jin_led=P2^5;
  39.    sbit pai_led=P2^6;
  40.    sbit p30=P3^0;
  41.    sbit p31=P3^1;
  42.    sbit beepon=P2^7;
  43.    sbit sm1=P3^6;
  44.    sbit sm2=P3^7;
  45. void delay2(void)
  46.    {
  47.   unsigned char m;
  48.   for(m=0;m<200;m++)
  49.         ;
  50.    }
  51. void delay1(int s)
  52.    {
  53.    int i;
  54.    for(;s>0;s--)
  55.    for(i=0;i<65;i++);
  56.    }
  57. void delay(uint i)
  58.    {
  59.    uchar j;
  60.    for(i;i>0;i--)
  61.    for(j=255;j>0;j--);
  62.    }
  63. void DisplaySecond(unsigned char k)
  64. {
  65.
  66.    sm1=0;        //P2.6引脚输出低电平, DS6点亮
  67.    P1=Tab[k/10];          //显示十位
  68.      delay2();
  69.      delay2();
  70.    sm1=1;
  71.    sm2=0;       //P2.7引脚输出低电平, DS7点亮
  72.    P1=Tab[k%10];         //显示个位
  73.      delay2();
  74.      delay2();
  75.    P3=0xff;     //关闭所有数码管
  76.    P1=1;        //显示个位
  77.      delay2();
  78.      delay2();
  79. }
  80.
  81. void beep()
  82.    {
  83.           p30=0;
  84.     p31=0;
  85.            t=0;
  86.         while(1)
  87.         {
  88.           beepon^=1;
  89.       delay(300);
  90.       if(t>=80) break;
  91.         }
  92.         beepon=0;
  93.         biao_led=0;
  94.     }
  95.
  96. void f_qiang()
  97.     {
  98.          qiang_ledon;
  99.          t=0;
  100.          tt=0;
  101.      int_time=0;
  102.      second=00;
  103.          while(1)
  104.     {
  105.           if(tt>=400) break;
  106.       t=0;
  107.           while(t<80&&tt<=400)
  108.           {
  109.             p31=0;
  110.             p30=1;        //正转 4s
  111.         DisplaySecond(second);
  112.             }
  113.           t=0;          //反转 4s
  114.           while(t<80&&tt<=400)
  115.           {
  116.             p30=0;
  117.             p31=1;
  118.             DisplaySecond(second);
  119.             }
  120.      }
  121.           p30=0;
  122.           p31=0;
  123.      }
  124. void f_biao()
  125.         {
  126.           qiang_led=0;
  127.       biao_led=1;
  128.           t=0;
  129.           tt=0;
  130.       int_time=0;
  131.       second=00;
  132.          while(1)
  133.      {
  134.            if(tt>=400) break;
  135.            t=0;
  136.           while(t<60&&tt<=400)
  137.            {
  138.           p31=0;
  139.                   p30=1;        //正转3s
  140.           DisplaySecond(second);
  141.        }
  142.                 t=0;          //反转3s
  143.           while(t<60&&tt<=400)
  144.        {
  145.               p30=0;
  146.                   p31=1;
  147.                   DisplaySecond(second);
  148.                 }
  149.        }
  150.        p30=0;
  151.            p31=0;
  152.          }
  153. void f_ruo()
  154.     {
  155.           qiang_led=0;
  156.           biao_led=0;
  157.           ruo_led=1;
  158.           t=0;
  159.           tt=0;
  160.       int_time=0;
  161.        second=00;
  162.                 while(1)
  163.        {
  164.                     if(tt>=400) break;
  165.                  t=0;
  166.                while(t<40&&tt<=400)
  167.            {        p31=0;
  168.                         p30=1;        //正转2s
  169.                 DisplaySecond(second);
  170.                 }
  171.              t=0;          //反转 2s
  172.                while(t<40&&tt<=400)
  173.             {   p30=0;
  174.                         p31=1;
  175.                         DisplaySecond(second);
  176.                       }
  177.          }
  178.                 p30=0;
  179.             p31=0;
  180.        }
  181. void f_piao()
  182.         {
  183.            qiang_ledoff;
  184.            biao_ledoff;
  185.            piao_ledon;
  186.            t=0;
  187.            tt=0;
  188.        int_time=0;
  189.        second=00;
  190.                  while(1)
  191.           {
  192.                       if(tt>=400) break;
  193.                    t=0;
  194.                  while(t<40&&tt<=400)
  195.                {        p31=0;
  196.                         p30=1;        //正转2s
  197.                     DisplaySecond(second);
  198.                    }
  199.                    t=0;          //反转2s
  200.                  while(t<40&&tt<=400)
  201.                {    p30=0;
  202.                             p31=1;
  203.                              DisplaySecond(second);
  204.                        }
  205.              }
  206.           p30=0;
  207.       p31=0;
  208.           piao_ledoff;
  209.           }
  210. void pai_leds()
  211.      {
  212.             p30=0;
  213.             p31=0;
  214.                pai_led=1;        //排水阀灯亮 等待霍尔开关2
  215.             while(hk2);
  216.             if(hk2==0)  //如果闭合
  217.             pai_led=0;        //排水灯灭
  218.      }
  219. void jin()
  220.     {
  221.             p30=0;
  222.             p31=0;
  223.             jin_ledon;
  224.              while(hk1);
  225.             if(hk1==0)
  226.             jin_ledoff;
  227.      }
  228. void sgan()
  229.     {
  230.             sgan_ledon;         //甩干灯亮
  231.              t=0;
  232.         int_time=0;
  233.         second=00;
  234.              while(t<=400)
  235.             {
  236.                             p31=0;
  237.                         p30=1;
  238.                 DisplaySecond(second);
  239.                  }
  240.         sgan_ledoff;
  241.     }
  242. void sgan1()
  243.     {
  244.            sgan_ledon;
  245.             t=0;
  246.        int_time=0;
  247.        second=00;
  248.              while(t<=400)
  249.             {
  250.                            p31=0;
  251.                    p30=1;
  252.                DisplaySecond(second);
  253.                  }
  254.         piao_ledoff;
  255.         sgan_ledoff;
  256.         beep();
  257.             t=401;
  258.     }
  259. void f_an1()
  260.    {
  261.         qiang_ledon; //方案1灯亮
  262.         jin();  //进入强洗
  263.         f_qiang();         //循环20S
  264.         delay1(4000);//延时4s
  265.         f_biao();  //循环20S
  266.         delay1(4000);//延时4s
  267.         f_ruo();  //循环20S
  268.         ruo_ledoff;
  269.         pai_leds();
  270.         delay1(1000); //延时1S 进入甩干
  271.         sgan(); //甩干20s
  272.         sgan_ledoff;
  273.         ruo_ledoff;
  274.         piao_ledoff;
  275.         jin();
  276.         delay1(1000); //延时1S 进入漂洗
  277.         f_piao();  //循环20S
  278.         sgan_ledoff;
  279.         piao_ledoff;
  280.         pai_leds();
  281.         delay1(1000); //延时1S 进入甩干
  282.         sgan1();//最终甩干20S
  283.         delay(500);//延时
  284.         beep();
  285.    }
  286. void f_an2()
  287.    {
  288.         biao_ledon; //方案1灯亮
  289.         jin();
  290.         f_biao();  //循环20S
  291.         delay1(4000); //延时4S
  292.         f_ruo();  //循环20S
  293.         ruo_ledoff;
  294.         pai_leds();
  295.         delay1(1000); //延时1S 进入甩干
  296.         sgan(); //甩干20s
  297.         ruo_ledoff;
  298.         piao_ledoff;
  299.         jin();
  300.         delay1(1000); //延时1S 进入漂洗
  301.         f_piao();  //循环20S
  302.         sgan_led=0;
  303.         pai_leds();
  304.         delay1(1000); //延时1S 进入甩干
  305.         sgan();//最终甩干20s
  306.         delay(500);//延时5s
  307.         piao_led=0;
  308.         beep();
  309.    }
  310. void f_an3()
  311.   {
  312.         ruo_led=1; //方案1灯亮
  313.         jin();
  314.         f_ruo();  //循环20S
  315.         ruo_ledoff;
  316.         pai_leds();
  317.         delay1(1000); //延时1S 进入甩干
  318.         sgan(); //甩干20S
  319.         ruo_ledoff;
  320.         piao_ledoff;
  321.         jin();
  322.         delay1(1000); //延时1S 进入漂洗
  323.         f_piao();  //循环20S
  324.         sgan_led=0;
  325.         pai_leds();
  326.         delay1(1000); //延时1S 进入甩干
  327.         sgan();//最终甩干20s
  328.         delay(500);//延时5s
  329.         piao_led=0;
  330.         p30=0;
  331.         beep();
  332.    }
  333. int main(void)
  334. {
  335.   TMOD=0x01;       //方式1 16位计数器
  336.   TH0=-50000/256;   //设定初值
  337.   TL0=-50000%256;
  338.   EA=1;               //开总中断
  339.   ET0=1;             //开定时器0中断
  340.   TR0=1;             //启动定时器0
  341.   P2=0;
  342.   int_time=0;     //中断次数初始化
  343.   second=00;           //秒初始化
  344.          while(1)
  345.     {
  346.           if(k1==0)
  347.         {
  348.                 delay(10);
  349.                 if(k1==0)
  350.             {
  351.                         f_an1();
  352.                 }
  353.         }
  354.         if(k2==0)
  355.         {
  356.                 delay(10);
  357.                 if(k2==0)
  358.                 {
  359.                         f_an2();
  360.                 }
  361.         }
  362.         if(k3==0)
  363.         {
  364.             delay(10);
  365.            if(k3==0)
  366.             {
  367.                     f_an3();
  368.             }
  369.         }
  370.          if(sg==0)
  371.         {
  372.                 delay(10);
  373.                 if(sg==0)
  374.                 {
  375.                    sgan1();
  376.                 }
  377.         }
  378. }
  379.         return 0;
  380. }
  381. void time0() interrupt 1 using 1
  382.    {
  383.      int_time ++;        //每来一次中断,中断次数int_time自加1
  384.     if(int_time==20)   //够20次中断,即1秒钟进行一次检测结果采样
  385. ……………………
  386. …………限于本文篇幅 余下代码请从51黑下载附件…………
上面的程序我仿真的时候 没有效果 求帮忙修改:
有问题的代码,求大神提供修改思路.7z (47.98 KB, 下载次数: 382)
另外大家可以参考这个,这个基本实现了,但是还是不完美:http://www.51hei.com/bbs/dpj-75453-1.html
收藏收藏12 分享淘帖 顶顶1 踩踩
ID:919394 发表于 2021-5-17 09:35 | 只看该作者
sbit ledon=P0^7;定义P0.7有什么用吗,仿真上没看到连有电路,可以解释一下吗
ID:84745 发表于 2020-7-22 21:37 来自触屏版 | 只看该作者
新手不懂那按键接电阻至5v,按下不是短路了吗
ID:312929 发表于 2020-7-21 09:14 | 只看该作者
aaaaaaa111 发表于 2020-6-10 10:50
你好你好,想要洗衣机程序呢
#include <REG52.H>
uint t=0,tt=0;
   sbit k1=P0^0;
   sbit k2=P0^1;
   sbit k3=P0^2;
   sbit sg=P0^3;
   sbit hk1=P0^4;
   sbit hk2=P0^5;
   sbit ledon=P0^7;
   sbit biao_led=P2^1;
   sbit ruo_led=P2^2;
   sbit piao_led=P2^3;
   sbit sgan_led=P2^4;
   sbit jin_led=P2^5;
   sbit pai_led=P2^6;
   sbit p30=P3^0;
   sbit p31=P3^1;
   sbit beepon=P2^7;
   sbit sm1=P3^6;
   sbit sm2=P3^7;
void delay2(void)
  unsigned char m;
  for(m=0;m<200;m++)
void delay1(int s)
   int i;
   for(;s>0;s--)
   for(i=0;i<65;i++);
void delay(uint i)
   uchar j;
   for(i;i>0;i--)
   for(j=255;j>0;j--);
     delay2();
     delay2();
   sm1=1;
     delay2();
     delay2();
   P3=0xff;     //关闭所有数码管
   P1=1;        //显示个位
     delay2();
     delay2();
void beep()                                                         //报警
          p30=0;
    p31=0;
           t=0;
          beepon^=1;
      delay(300);
      if(t>=80) break;
        beepon=0;
        biao_led=0;
void f_qiang()                                           //强洗衣
         qiang_ledon;
         t=0;
         tt=0;
     int_time=0;
     second=00;
          if(tt>=400) break;
      t=0;
            p31=0;
            p30=1;        //正转 4s
          t=0;          //反转 4s
            p30=0;
            p31=1;
          p30=0;
          p31=0;
void f_biao()                                                           //标准洗衣
          qiang_led=0;
      biao_led=1;
          t=0;
          tt=0;
      int_time=0;
      second=00;
           if(tt>=400) break;
           t=0;
          p31=0;
                  p30=1;        //正转3s
                t=0;          //反转3s
              p30=0;
                  p31=1;
       p30=0;
           p31=0;
void f_ruo()                //弱洗衣
          qiang_led=0;
          biao_led=0;
          ruo_led=1;
          t=0;
          tt=0;
      int_time=0;
       second=00;
                    if(tt>=400) break;
                 t=0;
           {        p31=0;
                        p30=1;        //正转2s
             t=0;          //反转 2s
            {   p30=0;
                        p31=1;
                p30=0;
            p31=0;
void f_piao()        //漂洗
           qiang_ledoff;
           biao_ledoff;
           piao_ledon;
           t=0;
           tt=0;
       int_time=0;
       second=00;
                      if(tt>=400) break;
                   t=0;
               {        p31=0;
                        p30=1;        //正转2s
                   t=0;          //反转2s
               {    p30=0;
                            p31=1;
          p30=0;
      p31=0;
          piao_ledoff;
void pai_leds()        //排水
            p30=0;
            p31=0;
            while(hk2);
            if(hk2==0)  //如果闭合
            pai_led=0;        //排水灯灭
void jin()        //进水
            p30=0;
            p31=0;
            jin_ledon;
            while(hk1);
            if(hk1==0)
            jin_ledoff;
void sgan()        //甩干
            sgan_ledon;         //甩干灯亮
            t=0;
        int_time=0;
        second=00;
             while(t<=400)
                            p31=0;
                        p30=1;
        sgan_ledoff;
void sgan1()
           sgan_ledon;
           t=0;
       int_time=0;
       second=00;
             while(t<=400)
                           p31=0;
                   p30=1;
        piao_ledoff;
        sgan_ledoff;
        beep();
            t=401;
void f_an1()
        jin();  //进入强洗
        f_qiang();         //循环20S
        delay1(4000);//延时4s
        pai_leds();
        sgan(); //甩干20s
        sgan_ledoff;
        jin();
        f_piao();  //循环20S
        sgan_ledoff;
        piao_ledoff;
        pai_leds();
        sgan1();//最终甩干20S
        delay(500);//延时
        beep();
void f_an2()
        biao_ledon; //方案2灯亮
        jin();
        f_ruo();  //循环20S
        ruo_ledoff;
        pai_leds();
        sgan(); //甩干20s
        ruo_ledoff;
        piao_ledoff;
        jin();
        f_piao();  //循环20S
        sgan_led=0;
        pai_leds();
        sgan();//最终甩干20s
        delay(500);//延时5s
        piao_led=0;
        beep();
void f_an3()
        ruo_led=1; //方案3灯亮
        jin();
        f_ruo();  //循环20S
        ruo_ledoff;
        pai_leds();
        sgan(); //甩干20S
        ruo_ledoff;
        piao_ledoff;
        jin();
        f_piao();  //循环20S
        sgan_led=0;
        pai_leds();
        sgan();//最终甩干20s
        delay(500);//延时5s
        piao_led=0;
        p30=0;
        beep();
int main(void)
  TL0=-50000%256;
  EA=1;               //开总中断
  ET0=1;             //开定时器0中断
  TR0=1;             //启动定时器0
  P2=0;
  second=00;           //秒初始化
          if(k1==0)
                delay(10);
                if(k1==0)
                        f_an1();
        if(k2==0)
                delay(10);
                if(k2==0)
                        f_an2();
        if(k3==0)
            delay(10);
           if(k3==0)
                    f_an3();
        if(sg==0)
                delay(10);
                if(sg==0)
                   sgan1();
        return 0;
        int_time=0;    //中断次数清0
        second++;    //秒加1
   TH0=-50000/256;   //50000  =50ms中断一次
   TL0=-50000%256;
   t++;
   tt++;
ID:645807 发表于 2020-7-8 17:23 | 只看该作者
好像那个洗的时候 那个电机不会转
ID:795032 发表于 2020-7-8 13:10 | 只看该作者
运行了一下,甩干能运行,其他模式下电机不运转,有人有解决方法吗
ID:795032 发表于 2020-7-8 12:44 | 只看该作者
1979759100Ls 发表于 2020-5-13 17:42
洗衣程序方案一和方案二有问题,我已经修改了,有需要的联系我
你好,求修改后的程序
ID:772875 发表于 2020-6-11 10:53 | 只看该作者
能问一下这个要怎么操作才能让他正常运行呢,谢谢
ID:774548 发表于 2020-6-10 13:52 | 只看该作者
卫中豪 发表于 2020-6-10 12:50
代码复制,出错了
是不是篇幅不够,代码好像没完整
ID:773367 发表于 2020-6-10 12:50 | 只看该作者
代码复制,出错了
ID:774548 发表于 2020-6-10 10:50 | 只看该作者
你好你好,想要洗衣机程序呢
ID:312929 发表于 2020-5-13 17:42 | 只看该作者
ID:566697 发表于 2020-3-18 11:25 | 只看该作者
楼主代码能加解释吗 +1
ID:667778 发表于 2019-12-31 08:47 | 只看该作者
楼主代码能加解释吗
ID:678006 发表于 2019-12-30 23:35 | 只看该作者
很是实用  可以做洗衣机了
ID:576648 发表于 2019-7-2 19:19 | 只看该作者
真的是太厉害了
ID:547331 发表于 2019-5-26 08:47 | 只看该作者
有具体的分析嘛
ID:512559 发表于 2019-4-15 15:46 | 只看该作者
很是实用  可以做洗衣机了
ID:308395 发表于 2018-5-3 09:49 | 只看该作者
不知道是什么原理,但是一运行仿真,再按按钮,电机一直不转
