查看: 3760|回复: 3
STM32控制步进电机
ID:308810 发表于 2018-5-2 18:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是我这几天写的,通过stm32来控制步进电机的转动,可以直接引用,注意修改引脚即可:
#include "stm32f10x.h"
#include "stm32f10x_gpio.h"
uint8_t phasecw[8]={0x08,0x0c,0x04,0x06,0x02,0x03,0x01,0x09} ;
uint8_t phaseccw[8]={0x09,0x01,0x03,0x02,0x06,0x04,0x0c,0x08} ;
void delay_ms(uint16_t time)
   uint16_t i=0;
   while(time--)
      i=3000;
      while(i--) ;
void Step_Motor_GPIO_Init(void
  GPIO_InitTypeDef GPIO_InitStruct;
        *(unsigned int *)0X40021018 |= (1<<3);
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHZ;
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOB,&GPIO_InitStruct);
void SetMotor(unsigned char InputData
    if(InputData & 0x08)
        GPIO_ResetBits(GPIOB,GPIO_Pin_6);
        GPIO_SetBits(GPIOB,GPIO_Pin_6);
    if(InputData & 0x04)
        GPIO_ResetBits(GPIOB,GPIO_Pin_7);
        GPIO_SetBits(GPIOB,GPIO_Pin_7);
    if(InputData & 0x02)
        GPIO_ResetBits(GPIOB,GPIO_Pin_8);
        GPIO_SetBits(GPIOB,GPIO_Pin_8);
   if(InputData & 0x01)
       GPIO_ResetBits(GPIOB,GPIO_Pin_9);
       GPIO_SetBits(GPIOB, GPIO_Pin_9);
void motorNCircle(int n
   int i=0;
   int j=0;
   int k=0;
   for(j=0;j<n;j++)
      for(i=0;i<64*8;i++)
          for(k=0;k<8;k++)
             SetMotor(phaseccw[k]);
             delay_ms(1);
int main(void)
   Step_Motor_GPIO_Init();
                motorNCircle(3);
void SystemInit(void)
        /*让编译器不报错*/
参与人数 1黑币 +5 收起 理由
362618281 + 5 绝世好帖!
ID:319662 发表于 2018-5-2 21:58 | 只看该作者
正在学习用32做激光雷达避障小车,学习一下思路哈哈哈
ID:260557 发表于 2018-5-8 09:32 | 只看该作者
很给力
ID:350346 发表于 2018-6-15 18:10 | 只看该作者
厉害了
