查看: 2258|回复: 0
0-999秒表程序
ID:320838 发表于 2018-5-2 22:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <STC12C5A60S2.H>
#define ENLED P11
#define Interrupt
unsigned char code LedChar[10] =
{0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char LedBuff[6] =
{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
void T0init()
        TMOD &= 0xF0;
        TMOD |= 0x01;
        TH0 = 0xF5;
        TR0 = 1;
        EA = 1;
        ET0 = 1;
        TF0 = 0;
}void LED_Scan(unsigned long sec)
        static unsigned char i = 0;
        unsigned char j = 6;
        while(j)
                LedBuff[j-1] = LedChar[sec%10];
                sec /= 10;j--;
        P2 = ~0x07;
        P2 |= i%6;
        P0 = LedBuff[(i++)%6];
}void main()
        T0init();
        ENLED = 0;
                #ifndef Interrupt
                void TF0_Scan();
                TF0_Scan();
                #endif
#ifdef Interrupt
void interrupt_Scan() interrupt 1
        static unsigned int cnt = 0;
        static unsigned long sec = 0;
        TF0 = 0;
        TH0 = 0xF5;
        TL0 = 0x95;
        cnt++;
        if(cnt >=999)
                cnt = 0;
                sec++;
                if(sec >9)
                        P13=0;sec=0;
        LED_Scan(sec);
#else        void TF0_Scan()
        if(TF0 == 1)
                TF0 = 0;
                TH0 = 0xF5;
                TL0 = 0x95;
                cnt++;
                if(cnt >= 999)
                        cnt = 0;
                        sec++;
                        if(sec > 9)
                                P13=0;
                        sec=0;
                LED_Scan(sec);
#endif
