查看: 2935|回复: 0
SPI接口的TLC549串行A/D转换器接口芯片及编程实验
ID:321428 发表于 2018-5-3 17:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DAT        BIT P0.0
CLK        BIT P0.1
CS        BIT P0.2
        ORG        0000H
        LJMP        START
        ORG        0030H
START:        MOV        SP,#60H
        MOV        TMOD,#10H
        SETB        TR1
        SETB        ET0
        SETB        EA
        SETB        DAT
LOOP2:        MOV        30H,#00H
        MOV        31H,#00H
        MOV        R2,#00H
        MOV        R5,#05H
LOOP:        LCALL        TLC549_ADC
        ADD        A,30H
        MOV        30H,A
        JC        REL
        LJMP        TEL
REL:        INC        31H
        JNC        TEL
TEL:        DJNZ        R2,LOOP
        MOV        P1,31H
        MOV        A,31H
        CJNE        A,#80H,CEL
CEL:        JNC        LOOP3
        JC        LOOP2
        SJMP        LOOP6
LOOP3:        JNB        TF1,$
        CLR        TF1
        MOV        TL1,#0ECH
        MOV        TH1,#0FEH
        CPL        P1.0
        DJNZ        R5,LOOP3
LOOP6:        SETB        P1.0
        LCALL        DELAY
        LJMP        LOOP2
TLC549_ADC:
        PUSH        07H
        CLR        A
        SETB        CS
        CLR        CLK
        MOV        R7,#08H
        CLR        CS
        NOP
LOOP1:        SETB        CLK
        MOV        C,DAT
        RLC        A
        CLR        CLK
        DJNZ        R7,LOOP1
        SETB        CS
        CLR        CLK
        SETB        DAT
        POP        07H
        RET
DELAY:        PUSH        01H
        MOV        R1,#00H
        DJNZ        R1,$
        POP        01H
        RET
        END
